Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 07-01-2014, 12:42 PM   #26
ripper70
ripper70's Avatar
Re: Garage interior finish
I used 1/2 sheetrock on ceilings and 3/8 plywood on walls then caulked seems on the walls and taped and textured ceilings.
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 07-01-2014, 12:56 PM   #27
Coach529
Coach529's Avatar
I did 7/16" OSB with a 3' tin wainscot and tin on the ceiling.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 07-02-2014, 05:18 PM   #28
Tinkermc
Nice job !!!
Tinkermc is offline   Reply With Quote
Old 07-13-2014, 03:48 PM   #29
Fleet '66
Active Member
Fleet '66's Avatar
I like that idea of the 3' metal Coach. I think I'll use that on my walls. I was already planning to use the OSB but the addition of the metal on the bottom would help protect from scrapes and bumps as well as moisture protection in case I want to scrub and spray out the floor occasionally.
Fleet '66
'66 C-10 SWB 350 w/3 spd OD 4:11's - driver/project...future T-5 trans upgrade
'64 C-10 LWB BBW near future project - "The Wife's Ride"
'58 "Apache"Stepside BBW w/'75 K-10 4x4 conversion 331 w/350TH and NP 205 transfer 3:73's - occasional driver/ show
Fleet '66 is offline   Reply With Quote
Old 07-13-2014, 05:59 PM   #30
ripper70
ripper70's Avatar
I did 3' of standing seam out of some old stuff i ripped off a roof doing a remodel.
1970 K20
1967 Blown Stepside
1989 Jeep Cherokee
1995 S-10
Old 11-03-2014, 10:40 PM   #31
Jim53066
Jim53066's Avatar
I used 1/2 in. OSB on the walls and tin siding on the ceiling. It is not finished in this picture, it has changed quite a bit since then.
You need to go to the garage journal and check out some of the garages there, you will spend hours (days) looking at them.
http://www.garagejournal.com/forum/index.php
Jim
Jim53066 is offline   Reply With Quote
Old 12-04-2017, 01:56 AM   #32
ryans69chevy
I was going through my old threads and found this one I totally gapped out... here is a pic of the garage after I got it all done.
Went with 1/2 cdx all around painted white and caulked the seam between the wall and ceiling. Turned out really good.
Ended up having to install more joists to make the garage 24" on center (was 48" on center). Also grinded the floor with my 4 1/2" grinder and painted epoxy.
ryans69chevy is offline   Reply With Quote
Old 12-04-2017, 03:23 AM   #33
In The Ten Ring
I wish my garage floor was flat enough to allow sanding! Seriously, my garage floor must have been poured during an earthquake.
Nice looking garage man.
In The Ten Ring is offline   Reply With Quote
Old 12-04-2017, 09:46 AM   #34
BossHogg69
motor exploder
BossHogg69's Avatar
That turned out really nice! well done
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-04-2017, 09:48 AM   #35
BossHogg69
motor exploder
BossHogg69's Avatar
Originally Posted by Truckseats View Post
I used 7/16" OSB. I'm very happy with the finished product.
How did you get the OSB to turn out that smooth? That looks very nice.
Adam
Old 12-05-2017, 12:33 AM   #36
ryans69chevy
Thank you guys. It looks a bit different in there now that I have many projects to keep myself busy!
