Old 05-31-2017, 10:52 AM   #1
rockyrivermark
Rubber door bumper location and size?
Anyone got a pic of the rubber door bumpers on a truck.
I bought the kit but can seem to figure which hole is the location for the bumper.
See pic. Need locations for these 3.
Thanks!
Mark
rockyrivermark is offline   Reply With Quote
Old 05-31-2017, 12:20 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Rubber door bumper location and size?
Not sure why three. Both my 71 & 72 use two per door. You should have two holes. One above the latch plate, one near the bottom of the door jam. The correct bumper is the one on top in your pic.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-31-2017, 12:28 PM   #3
randy.powell
Two of those are for the tailgate. The lower two in your pic. One of each for both sides
randy.powell is offline   Reply With Quote
Old 05-31-2017, 12:52 PM   #4
rockyrivermark
There are 2 of each. I just took pick of one of each of them.
Old 05-31-2017, 03:06 PM   #5
Tim Christian
Tim Christian's Avatar
I am pretty sure they was three holes per side on the 67 and 68 if it still has the original rockers.
Tim Christian is offline   Reply With Quote
Old 05-31-2017, 10:24 PM   #6
FirstOwner69
FirstOwner69's Avatar
My '69 has always had 3 holes in each door jamb. However, from day one, only the top and bottom holes have had bumpers like the top one in the post 1 picture.
FirstOwner69 is offline   Reply With Quote
Old 12-05-2017, 08:44 PM   #7
MfBox
Really stupid question but how do you get those into the holes? mine seem too big to fit. I bought ones made for 67-72 chevy trucks.
MfBox is offline   Reply With Quote
Old 12-05-2017, 09:37 PM   #8
rockyrivermark
Dap of dish soap and they pop right in with screw driver or 1/4" socket entension
Old 12-05-2017, 10:32 PM   #9
MfBox
I tried this but it just seems like the pointed part is just too big. I press as hard as possible and it goes in a bit but can never get the whole pointed piece in. Just smashes down
Old 12-05-2017, 10:37 PM   #10
rockyrivermark
How about tiny flat head screw driver or pick and only push on the inner edge of the rubber where is locks in. If that makes sense
Old 12-05-2017, 10:47 PM   #11
FirstOwner69
I have had luck using silicone spray or silicone plumbers grease on the bumper and then pushing it in with a blunt Torx screwdriver or allen wrench of appropriate diameter inserted into the hole in the bumper.
Old 12-06-2017, 02:06 PM   #12
MfBox
I tried this as well. What size are the bumpers supppsed to be? Mine are 1/2 inch at the pointed part.
Old 12-06-2017, 02:44 PM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Mine are also 1/2"..... and just below that tapered section, the part that will rest in the hole, is 5/16".
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-06-2017, 02:56 PM   #14
MfBox
And you got it to fit? Must just need to lube it up and slam it in there.
Old 12-06-2017, 04:32 PM   #15
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Not yet, the truck needs to be painted before I put the new bumpers in. Just lube 'em up and press one side in with a small screwdriver, then work your way around.
- Mike -
RIP El Jay
Old 12-06-2017, 05:00 PM   #16
MfBox
Just pushed one side in and pressed and they popped in. Still messing with the top spot on each side but the doors already close alot easier. Thanks for the help
