12-08-2017, 11:12 PM | #1 |
Carpe manana
Let's play name that part, bolt, harness, screw....
I figure this could be a good learning opportunity. Let's post up parts and pieces and name the application. Here's one: where does this rubber piece attach?
12-08-2017, 11:29 PM | #2 |
Re: Let's play name that part, bolt, harness, screw....
Airconditioning housing for condensation drain?
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
12-08-2017, 11:30 PM | #3 |
a/c evaporator drain and spring clamp
old money |
12-08-2017, 11:32 PM | #4 |
Carpe manana
Yes! Often missing. Here's the attachment location.
12-08-2017, 11:33 PM | #5 |
Carpe manana
Ok. Anyone familiar with these sheetmetal screws?
12-08-2017, 11:36 PM | #6 |
grounding strap screws
12-08-2017, 11:45 PM | #7 |
Carpe manana
These are the body-side ground screws that I'm familiar with - not all used a star washer but that's just my experience. Here are examples including that for the ground for the AC harness at the condenser box and those at the rad support, which differ from that below: http://67-72chevytrucks.com/vboard/s...1&postcount=54
The longer sheet sheet metal screws above were used for two applications that I'm aware of.....
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 12-08-2017 at 11:59 PM. |
12-08-2017, 11:56 PM | #8 |
Carpe manana
These are the screws used for the fan ground at the AC box and examples of those used for grounds at rad support. Replated in clear zinc.
12-08-2017, 11:58 PM | #9 |
Carpe manana
Here's the screw used for the battery clamp on my blue 72 blazer - similar to rad support ground screws but longer.
12-09-2017, 11:32 AM | #10 |
Carpe manana
Screws in post #5 are correct for mounting the console to floor pan and also used for some attachment points for AC and heater box - in cab side maybe?
12-09-2017, 11:43 AM | #11 |
Carpe manana
Ok. What about these screws....anyone?
12-09-2017, 12:28 PM | #12 |
Here's a hint...Some Blazer and Jimmy guys will have these others will not.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
12-09-2017, 02:11 PM | #13 |
Rear hatch screws?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
12-09-2017, 05:40 PM | #14 |
Carpe manana
Close! These are the top bolts for use on k5s w a single wall top. Not best example pic but shown below.
12-09-2017, 05:50 PM | #15 |
Carpe manana
How about the application for these nuts?
12-09-2017, 06:02 PM | #16 | ||
"I ain't nobody, dork."
Acorn nuts for West Coast Jr. mirrors.
Gary
12-09-2017, 06:04 PM | #17 |
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
12-09-2017, 06:27 PM | #18 |
Carpe manana
Yes! Camper mirrors and below eyeline. Did you know the threads are metric?
12-09-2017, 06:32 PM | #19 |
Carpe manana
Here's an obscure part (set of 4) I received in a parts lot. I honestly don't know exactly where these go. Spacer for what the rear lamp lens?? Between screw and lens?
12-09-2017, 06:34 PM | #20 |
Carpe manana
Parts tag...
12-09-2017, 06:48 PM | #21 |
Neat idea Deadhead. Here's something you don't see everyday.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-09-2017 at 07:02 PM. |
12-09-2017, 10:28 PM | #22 |
If that's what I think it is I wish I had a 5 gallon bucket full of them. 72 c10 part 2 per vehicle
12-10-2017, 12:22 AM | #23 |
I'm thinking that is the gas tank vent tube for a 71-72 truck. Goes up the passenger side of the cab between the back of the seat, just behind the door jamb, where all the jack tools are missing.
12-10-2017, 12:59 AM | #24 |
Yep, right above the missing parts......"Vent pipe assembly".
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-10-2017, 09:42 AM | #25 |
Carpe manana
What do you think they are???
