Old 12-08-2017, 06:57 PM   #1
diamondg
diamondg's Avatar
1968 C10 Lift?
I would like to lift my '68 C10 to above 1/2 ton stock height (it is currently lowered with drop springs). Something similar to more of a 4WD stance/height. Any recommendations on the easiest, best, and/or cheapest way to accomplish this? Thanks
Before I tell you where I am, Sheriff, there's just one thing I wanna say. You must be part coon dog, 'cause I've been chased by the best of them, and son, you make 'em look like they're all runnin' in slow motion.
'68 C10 SWB V8 TH350 Factory 12 bolt posi
diamondg is offline   Reply With Quote
Old 12-08-2017, 07:54 PM   #2
harpo231
harpo231's Avatar
Re: 1968 C10 Lift?
How rough a ride can ya tolerate ?
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 12-08-2017, 08:03 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Re: 1968 C10 Lift?
I’m going to be doing this shortly myself. I’ll be using lift spindles in the front for 4”, and blocks out back for 2”, giving it a level stance that will clear 33” tires and maintain a factory ride and alignment.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 12-08-2017, 10:30 PM   #4
Re: 1968 C10 Lift?
What lift spindles can you buy?
Old 12-09-2017, 12:36 AM   #5
diamondg
diamondg's Avatar
Re: 1968 C10 Lift?
Sounds like lift spindles are the way to go. I have been told before some guys would use 3/4 springs to try and add some height but also sacrifice their ride at the same time. Thanks for the info.
Old 12-09-2017, 12:38 AM   #6
diamondg
diamondg's Avatar
Re: 1968 C10 Lift?
I wouldn't mind some pointers/pictures from your project if you're willing! Thanks again.
Old 12-09-2017, 12:02 PM   #7
Re: 1968 C10 Lift?
Yeah, spindles won't affect the ride. I don't think 3/4t or 1t coils yield more than an inch. I mean, look at a C/20. Does it sit like a 4wd? You can't get much lift in the suspension before killing geometry, ability to properly align. The tires have to play a roll in the taller look. I want to know about what spindles we can use.
Old 12-10-2017, 10:50 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Re: 1968 C10 Lift?
Pulled these from a junkyard (I would not have bought these new otherwise, lol). The blue paint should give away who makes them.... They are still being manufactured for the time being, probably soon to be discontinued. The kit they make consists of these 4” lift spindles for the front, 2” blocks and extended u bolts for the rear, and new shocks. It runs around $1300, and the spindles alone are $700
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 12-11-2017, 07:32 PM   #9
Re: 1968 C10 Lift?
I remember a company making them years ago but not sure of the name... Fabtech?
Old 12-12-2017, 11:34 AM   #10
stepn67
Junior Member
stepn67's Avatar
Re: 1968 C10 Lift?
I've searched, but can't find the original post, so my apologies to the original poster, but here is a list of parts I saved just for this:Install 1988 - 1998 Chevy 4 inch lift spindles.
Parts List:
88-98 Rough Country lift spindles
88-98 Raybestos PG ball joints
88-98 C2500 LD 6 lugs rotors and calipers
Moog 6454 HD springs.
Belltech 1 3/8" sway bar
73-87 C30 lower A-arm
73-87 C10 upper A-arm
stepn67 is offline   Reply With Quote
Old 12-12-2017, 11:45 AM   #11
raggedjim
raggedjim's Avatar
Re: 1968 C10 Lift?
This guy did his truck
http://67-72chevytrucks.com/vboard/s...light=2wd+lift
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 12-12-2017, 12:40 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Re: 1968 C10 Lift?
There is a write up in FAQ listing all the parts for using 88-98 spindles for the purpose of a disc brake conversion. A lot of people used to do this to keep 6 lug pattern up front, and using easy off the shelf parts. You can use 5 lug rotors as well. When I saw this lift kit on a truck in the junkyard, I remembered you can use the spindles on our trucks, so I pulled everything off...spindles, springs, upper control arms. Fabtech makes NICE stuff
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
