12-13-2017, 05:29 PM | #1 |
Custom Truck Lover!
installing side trim/molding
I have looked on YouTube and here. Anyone have links to a video or pictures installing complete side trim?
Squarebody guy |
12-13-2017, 11:32 PM | #2 |
Custom Truck Lover!
Re: installing side trim/molding
Bueller....... Bueller...... anyone?
Squarebody guy |
12-13-2017, 11:54 PM | #3 |
I’d be curious to see info as well. I may be inquiring a 61 without trim and would like to install.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
12-14-2017, 12:36 AM | #4 |
60-66 Nut
A quick look in the FAQ section revealed this..........
http://67-72chevytrucks.com/vboard/s...d.php?t=597891
12-15-2017, 03:58 PM | #5 | |
Custom Truck Lover!
Squarebody guy |
12-15-2017, 07:42 PM | #6 |
One foot in front of the other
Not any real tricks per say but I know for me the toughest one was the fender at the door. It helped to have one of the magnets on the end of the rod when you drop one of the nuts inside of the door.
12-16-2017, 12:41 AM | #7 |
60-66 Nut
If you are using Firefox or Chrome, you just need to download the photobucket fix they have. Then you can see all of the pics again.
12-16-2017, 10:43 AM | #8 |
Custom Truck Lover!
I can even come to you for computer fixes? Thank you. It worked perfectly.
Squarebody guy |
12-16-2017, 10:43 AM | #9 |
Custom Truck Lover!
Thank you.
Squarebody guy |
12-16-2017, 11:12 AM | #10 |
He's not the Captain for nothing.
12-17-2017, 08:19 AM | #11 |
that is a good writeup on doing trim. i did the photobucket fix for chrome and all good now.
12-17-2017, 11:52 AM | #12 |
My fenders had the holes, my replacement door did not, my cab did at the back. I ran a chalk line from tip of fender, through the cab holes and down the bed, keeping it straight and pulled tight, and then drilled the holes.
12-17-2017, 04:36 PM | #13 |
12-17-2017, 05:01 PM | #14 |
Custom Truck Lover!
I installed my pieces. 15 of the 16 pieces are OG and one in new. I learned a bunch. It depends on who makes the molding and where you buy your clips. With several companies selling, and sourcing from different places, the options are near endless. The mounting set I used was from LMC. The hole install took about 2 hours. If this was a "show truck" it would have taken much longer.
Squarebody guy |
12-17-2017, 05:13 PM | #15 |
Came out great. What tips/tricks can you offer now?
12-17-2017, 05:15 PM | #16 |
12-17-2017, 06:15 PM | #17 |
Custom Truck Lover!
I learned it depends on what product you use. The hardest part was getting the small clips in the skinny pieces. The LMC clips fit in two different ways. The clip should be horizontal and not vertical. Also make sure the clips ends can move freely before trying to press into body. If the ends are straight they will not cross each other.
Squarebody guy |
12-17-2017, 06:26 PM | #18 | |
12-17-2017, 08:37 PM | #19 |
Moderator
Great pics LT1, thank you.
12-18-2017, 02:45 PM | #20 |
Custom Truck Lover!
Squarebody guy |
12-18-2017, 10:09 PM | #21 |
Mine dont have any holes.
