12-16-2017, 02:26 AM | #1 |
Finally got my cruise control working
Been messing with this thing on and off for a couple of years. 77 Chevy 3/4 ton Camper Special with factory non-resume cruise.
Basically it needed everything. I found a NOS diaphragm on eBay. Found some beaded pull-chain from a ceiling fan to connect the cable to the diaphragm. Got a new vacuum transducer, rebuilt from Oreilly's. Fixed a bunch of vacuum leaks. And finally I found a mess in the electrical wiring on the brake cruise disabling function. A previous owner had installed (badly) a brake controller that had been disconnected and taped off and once that was put back to normal, it worked. It needs adjusting because it speeds up about 4 mph after the cruise is enabled but it does work now.
77 Chevy K20 Longbed 86 GMC C3500 Dually 07 Silverado 2500HD All standard cabs |
12-16-2017, 05:48 AM | #2 |
Re: Finally got my cruise control working
I am glad that you got your cruise working it remined me about a 82 suburban I has working on. the factory cruise it wasn't working properly so I was fooling around with it one day I had just left out the driveway and the truck got up to about 45 mph so I pushed the button and when I did the vacuum diaphragm sucked up and it held the throttle wide ass open it jumped up to 60 mph quickly I tried not to panic but I was headed towards the hwy I tried everything to get it to stop but the suburban kept getting faster and faster I hit the brakes as hard as I could it did nothing it just kept going I cut off the key and that didn't work so I then had to shift it up into netural it was screaming running wide open at about 7000 rpm but I was able to get stopped before I had to stop at the hwy I just knew it was going to spin a rod or something but it made it thru and after that I took off the vacuum diaphragm off and thrashed it . lesson learned
4x4k30 if trouble was money i would have plenty |
12-16-2017, 07:36 AM | #3 |
That's good news.
When I bought my truck, mine didn't work either. But when I put a new Edelbrock Carb on, I saw the rod wasn't set to the side of the carburetor. It was missing the little clip that kept the rod from sliding back off.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
12-16-2017, 11:10 AM | #4 |
I had to get the cable connected to the carb too. Forgot to mention that in the OP.
