08-15-2017, 06:40 PM | #201 |
Re: RnD Fabrication 1967-1972 Chevrolet & GMC early C10 / C20 / Blazer Radiators!
Unfortunately we don't have a way to do that. I believe Jiffy-tite has some types of disconnect fittings that may bridge the gap though.
09-17-2017, 06:54 PM | #202 |
back up
09-27-2017, 02:12 PM | #203 |
Any chance you could post the specs on your fans? Particularly CFM's and current draw, but the full specs would be nice. Are the fans American made as well? Thanks.
10-01-2017, 02:25 PM | #204 |
We have several dozen fans that we carry depending on diameter, depth, speed, etc and it varies on each application. I believe all of the fans are imported.
What we do is get engine / trans / application info, if there are any power adders, what the vehicle is used for, and location information. We use that to determine which fan(s) would be best suited and that is what we recommend. Available space also has a bit to do with it. |
10-13-2017, 11:37 AM | #205 |
bump
10-16-2017, 09:21 PM | #206 |
Have a 71 c10 with 4.8ls 4l60e how much for a radiator and fan set up with the ls ports on passager side and a trans cooler i currently have a griffin ls rad that has sprung a leak after only 4 years which sucks...
10-18-2017, 06:00 PM | #207 |
David, thanks for contacting us. The price with discount is $425 for the radiator, and we never charge extra for any of the following:
LS configuration ports Steam Port Built-in Trans Cooler For the fans, I'd need to know about how the engine is built (hp & torque), and if there are any power adders (turbo, supercharger, nitrous). Let me know and I can provide recommendations. |
10-18-2017, 10:00 PM | #208 |
Its a stock 4.8l i think it makes 280 hp
10-19-2017, 11:23 AM | #209 |
Ok, then our standard dual 12's will be fine. That is $220 after discount, and $75 for the controller with relay (not needed if you have a relay set up in your harness for fans). Shipping on that setup will be $55.
11-10-2017, 01:11 PM | #210 |
thanks for the orders!
11-14-2017, 10:49 PM | #211 |
Hello Sparky,
So I need the LS conversion radiator for my 70, and I have the smaller 3 row metal mounts with the rubber inserts. This will work with your radiator correct? Also, I need the tranny cooler and can you make the intake(upper hose connection the same size as the lower)? Thanks, |
11-15-2017, 12:25 PM | #212 |
Yes, that'll work with our setup. We make the LS ports on the passenger side and they are the same size inlet / outlet. We also include a steam port at no additional cost.
11-15-2017, 12:35 PM | #213 |
11-15-2017, 12:55 PM | #214 |
I had replied to your email earlier as well (but you may not have seen it). We make everything to order, and currently we're on a 1.5-2 week turnaround (maybe a little faster). Shipping is $65, and the radiator (after forum member discount) is $425. Let me know if you'd like to set up an order (I can email you the invoice with payment instructions).
11-15-2017, 01:06 PM | #215 | |
Thanks, |
11-19-2017, 02:47 PM | #216 |
Thanks for the order!
11-30-2017, 12:29 PM | #217 |
12-03-2017, 02:40 PM | #218 |
I had replied the other day, but just saw this as well. It'll be shipping out tomorrow and I already emailed tracking and a copy of the invoice.
12-17-2017, 04:18 AM | #219 |
Looking to get a radiator for a 1970 2wd blazer ls swap 5.3 stock with 4l60 trans would like it with trans cooler , steam port , fans and relay kit to 92807
12-17-2017, 02:12 PM | #220 |
birkinsb, thanks for contacting us. The price for the radiator is $425 ($450 retail), standard dual 12" fans are $225 ($245 retail), relay kit is $75, and shipping is $80. Total is $805 shipped after discounts.
Note that we never charge extra for a transmission cooler, changing the ports to LS application, or for the steam port. If you would like to proceed with an order, send me a private message with your email address and your full shipping address and I will put together an invoice and email it to you. Thanks and let me know if you have any other questions |
12-19-2017, 05:23 PM | #221 |
Sent you a PM with my email address and some questions.
Thanks |
12-22-2017, 11:28 AM | #222 |
replied, thanks!
12-29-2017, 11:06 AM | #223 |
bump
01-11-2018, 03:41 PM | #224 |
back up again
01-25-2018, 03:26 PM | #225 |
up top
