Accelerator cable bracket?
I searched through a lot of throttle cable bracket threads and have seen a lot of use of aftermarket style brackets. I was wondering if anyone has used a bracket off a GM car? I found this for a 69-72 Chevelle with a small block. GM #3992376
It looks like it’ll work for 72 truck with a small block. I have a manual trans so I don’t need the TV cable bracket. Anybody ever use one? |
Re: Accelerator cable bracket?
That could work as long as you have the grommet style cable attachment. It can be a trial and error deal. Try coming up with a pretty return spring setup for an Edelbrock!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Update: Just got this in the mail from Original Parts group. It will work well on a edlebrock carb. I had to file a little notch to fit around the casting on the base of the carb but the notch also acts to keep this bracket in place. In case anyone is looking to use this.
Cool, how about some pictures? I was thinking of using the same bracket
#5 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
![]() If you run your springs toward the front of the motor they equalize the strain on the throttle shaft in the carb causing less wear and prolonging the life of the carb casting. ![]()
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Here’s some pictures
Sorry for em bein cock eyed. Cell phone upload. Just tilt yer head.
