Gears
I have a 1964 c10 with a straight 6 An 4 speed on floor. I'm running 22 on rear An 20 on front. I run at 60mph turning 4K. Yea a little high. Looking to find a more highway gear. But don't no what to go with. Is there any other rear ends out there that will match up to mine. I'm not for sure what gears r in it now.
Posted via Mobile Device Last edited by Flip64; 12-30-2017 at 01:50 AM. |
![]() ![]() Join Date: May 2015
Re: Gears
welcome. ..holy cow!!! ....4000 rpm?...rim size has no effect on rpms....you need to know 4th grear in trans ratio, rear axle ratio, and tire diameter....you can plug numbers into calculator like this to find what you need for a axle ratio to get your rpms down....
http://www.csgnetwork.com/multirpmcalc.html
Re: Gears
you'd bout have to have a 5.13 rear ratio and 26in tall tire to turn 4k with a 1:1 final in the trans at 60mph
The Older Generation
Re: Gears
I will move this to the 60-66 truck forum. LockDoc
Re: Gears
Here we go again.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 12-30-2017 at 05:26 PM. |
60-66 Nut
Re: Gears
It sounds like your tach is not set to the 6cyl setting.
Re: Gears
Frist thing frist running at 4g will tear your motor apart.
![]() Join Date: May 2011
Re: Gears
Gear is the least of your problems. I'd start engine shopping, if that six is turning 4K, you're going to need one soon.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside |
