12-26-2017, 06:27 PM | #1451 |
6>8 Plugless........
Re: post your 67-72 4x4
Very nice burb!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-26-2017, 09:09 PM | #1452 |
Carpe manana
12-30-2017, 07:03 AM | #1453 | |
and more pics? lol
1972 k10 396 8" suspension lift 3" body lift - build in progress |
12-30-2017, 05:03 PM | #1454 |
rusty project but still optimistic about its potential..
'72 K1500 Suburban 350/350/np205 300hp 350 4 bolt reman, Recon p/n 708502HO dana 44 front/12 bolt posi rear [unverified ratios] tuff country springs, rancho shocks, no blocks 15x8.5 western hurricanes/TSL 33s
I started out with nothing - and I still have most of it |
12-30-2017, 06:10 PM | #1455 |
[quote=Killer Bee;8118124]rusty project but still optimistic about its potential..
'72 K1500 Suburban 350/350/np205 300hp 350 4 bolt reman, Recon p/n 708502HO dana 44 front/12 bolt posi rear [unverified ratios] tuff country springs, rancho shocks, no blocks 15x8.5 western hurricanes/TSL 33s Nice one!
1972 K10 1986 K30 crew cab dually 2002 Z06 2007 Escalade |
12-30-2017, 10:56 PM | #1456 |
I do like that sub, just something about it, the Thornbirds help it's attitude.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
12-30-2017, 11:15 PM | #1457 | |
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT "Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C. "1968" C10 Shortbed project |
12-30-2017, 11:41 PM | #1458 |
thanks for the boost everyone
still waiting for reply to my email inquiry to Tuff Country regarding old p/n translation on the lift specs.. but either way, there was $1800 of '99 money put under there.. shocks are about all needs replacement I suspect.. maybe one of y'all know more about this? anyone know old numbers? I crapped out on google.. and yes it was known to all previous owners and titled as a '71 although we know different
01-01-2018, 08:51 PM | #1459 |
Most any brand add a leaf is about 3" max lift, so front could be a 4" spring lift, back looks higher than 3" though, maybe has a 2" block also, most add a leaves settle in at about 2.5" so could be 5-5.5" in back, hard to tell without being there.
Mudman.
01-06-2018, 07:47 PM | #1460 |
Picture I took last week of my daily driver when I got to work.
Daily Driver: 1972 K20 Project: 1967 Buick GS 340 |
01-06-2018, 09:18 PM | #1461 |
Now that's a daily, beauty. Making people jealous I bet.
Mudman.
01-07-2018, 04:34 AM | #1462 |
Subtle yet refined with hints of "go ahead and test me".
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
01-08-2018, 04:06 PM | #1463 |
7071lwb, very nice truck!
01-08-2018, 04:22 PM | #1464 | |
The Rancho Shock Part Numbers on your Invoice 9001 / 9112 are the 4 inch lift shocks for 1973 to 1987 Trucks, the front shocks are the same back to 1969 I believe, I believe the rear were different though, but the 9112's are so long, they probably fit anyway.
The invoice says SUP HD springs 01-255, these are Super Lift 6 Inch Lift front Springs for 1967 to 1972 Chevys. So the front shock may be a tad short... I see an add a leaf for the rear. We would sell a 4 inch block kit, and add a leaf kit when lifting Chevys 6 inches, I don't see a 4 inch block kit though. There is a Rancho steering stabilizer and bracket listed also. Hope this helps. Quote:
01-08-2018, 05:18 PM | #1465 | |
I guess I'd have to call tuff country, sent a courteous email and two follow ups a week apart.. seemed reasonable.. I'll take some pictures underneath and bounce that off your info to see where it's at.. previous owners may have made changes since that invoiced work but I don't recall seeing any blocks under there.. not my area of expertise by any means so all info much appreciated, thanks again!
01-08-2018, 10:07 PM | #1466 |
By the look of the stance of your Burb I would say is has a 6 inch lift. The front must be all springs, which I see it is. The rear can be all springs, or blocks and springs as needed. Definitely take a picture or two of the rear set up and we can see what you have. An add a leaf is uaually a sorter thick leaf found near the bottom of the spring pack. All the stock leaves will be the same thickness, except the bottom overload spring.
01-09-2018, 12:28 AM | #1467 |
All the add a leaf kits I buy are a full length minus about 1" each end than the top leaf, the super thick short leaf is an overload, but some companys "try" to seel them as an add a leaf but don't actually lift the truck any more than the thickness of the leaf cause the ends of it doesn't touch the spring above it.
Someone may have had a 4" block they used with the add a leaf in the rear. I keep a bunch of different heights in my shop. Guess you have to look. Mudman.
01-13-2018, 04:52 PM | #1468 |
1971 k10.I am the 2nd owner and have had the truck for the last 35 years. I just finished frame off. Truck has 64” atlas progressive leafs in rear and 54” up front. Cross over steering,King remote resevoir shocks,37” maxis razors on raceline monster rims. I made front bumper,cut down stock rear step bumper,warn 8274,rock sliders plus a ton of other stuff.
01-13-2018, 08:12 PM | #1469 |
That’s a nice looking truck
01-14-2018, 01:45 PM | #1470 |
What do you have for lift to clear the 37's, I have 5.5 f and 5" back to clear 35's but are 14.5" wide. Really like your truck a lot, was wondering about your bumper, nice job on it, works perfectly with the body.
Mudman.
01-14-2018, 07:47 PM | #1471 |
I am using 6” lift springs and the rims are 17x9 with4” backspacing.
01-15-2018, 11:26 PM | #1472 |
I see the big difference, the 6" isn't much different but the narrow rim and tire compared to my 12" wide rim and 14.5" tire is why I can't go taller, well happy with my 35's but think a narrower tire would be a bit more highway friendly.
Thanks. Mudman.
01-16-2018, 01:00 AM | #1473 | |
Good work!! |
01-16-2018, 06:09 PM | #1474 | |
01-16-2018, 06:17 PM | #1475 |
Not sure how it is with the 54s as I just finished truck. I have king shocks on it with compression adjusters and a Currie anti rock sway bar on the rear of the truck. I may add a anti rock on the front if it is really soft but the compression adjusters on the king shocks should help. To add the Currie sway bar to the front is super tight because the cross over steering uses a 2 wd steering box which puts the pitman arm opposite of the 4wd box. I will have to cut the sway bar arms and add bends to clear.
