01-07-2018, 10:24 PM | #1 |
Blazer bed cross sill
Does anyone have or know where i can get the bed floor cross sill that runs at the back of the rear wheel tubs and is recessed where it mounts to the frame.
Thanks |
01-08-2018, 08:36 AM | #2 |
Re: Blazer bed cross sill
The last blazer I just list all the cross sills appear to be in good condition I can check it out and get pictures if so. Let me know if that's something you would be interested in.
01-08-2018, 10:22 PM | #3 |
please if you dont mind and thank you
01-08-2018, 10:36 PM | #4 |
That part is not available for the Blazer. I purchased one to fit the pickup and modified it. Worked perfect !
http://www.billstruckshop.com/Catalo...2_Jan_2017.pdf Page 104 |
01-08-2018, 11:34 PM | #5 |
Its on the lift I will get some pictures tomorrow after work.
01-09-2018, 11:40 PM | #6 |
pics
01-09-2018, 11:43 PM | #7 |
more pics
01-10-2018, 01:22 PM | #8 |
That looks to far gone to bother with thanks for looking
01-10-2018, 01:24 PM | #9 |
hemi43 how much did you have to cut out of the truck cross sill to make it work on a 2wd blazer. Thanks for info
01-10-2018, 05:48 PM | #10 |
I can't remember, all I know is that it will work. Here's the only pictures I could find.
01-10-2018, 08:59 PM | #11 |
I've had this piece laying around forever, guess it served a purpose. I did the s[url=https://flic.kr/p/FexDg9]20180110_194838ame thing Hemi did, so I guess I cut off each end about 11"
sorry, been drinking for awhile, my typing is slurrrrrred
01-11-2018, 02:08 PM | #12 |
01-18-2018, 07:56 PM | #13 |
You could always get one bent up at your local sheet metal working place.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
01-18-2018, 08:28 PM | #14 |
does anyone have the measurements on this cross sill it will help in having one made. thanks
01-18-2018, 08:48 PM | #15 | |
Over bare metal I only use epoxy. The underside of my truck was sanblasted, sprayed with epoxy, then top coated with a satin urethane black from KBS coatings. This was a real nice product to use, and is very durable. The top coat is sprayed wet on wet so there's perfect adhesion between the two products and no sanding in between. https://www.kbs-coatings.com/KBS-Maxx.html |
01-21-2018, 04:16 PM | #16 |
Equal opportunity joke ofender
HVAC
I have a mint 71' floor hanging here on the wall. If the cross member you are talking about, is the one I have white arrow on, there is no recess in it where it bolts to the frame. The only one that recesses is the tall one in front of the tubs. The one I have arrowed is just a hat section 1" mounting lip x 1" tall x 1.625" across and 71.75" wide. If you need any other measurements let me know. Richard .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
01-21-2018, 09:50 PM | #17 |
thank you for the info on this
