Old 12-29-2017, 08:48 PM   #26
CG
BlahBlahBlah
Re: 67 Camaro Build
Im not a big fan of Camaros but when you posted Grumps Camaro that brought back some fun memories. I think a 67/68 Camaro set up with the same stance and tire wheel combo would be really cool to bomb around in.
Old 01-02-2018, 11:45 AM   #27
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Originally Posted by Dieselwrencher View Post
Man, using the hoist is cheating, but I really like it. Maybe I could use a drive on to lift bodies off just like you did?
Ha, you know it, we use this lift as a body/frame elevator, paint booth, project storage, etc. it continues to be a great tool!
I think so too, that's the plan, a rake with some Cragar SS’s. Pizza cutters up front and some sticky's in tha back!
Building a jig/body cart that won't fall apart and is next up.
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 01-03-2018, 12:17 AM   #28
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 67 Camaro Build
Originally Posted by 7dee2 View Post
You betcha Chris! Don’t know of any personally but this 69 popped up on KSL a couple of days ago, https://www.ksl.com/auto/listing/4339502?ad_cid=4 might be something? Oops, and it's gone just that fast! That is where we found ours it was on KSL but they go really fast these days.
I called and texted on that as soon as I saw it. Poof, gone! We’ll keep looking.
Keep up the good work!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-06-2018, 12:51 PM   #29
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Bummer, that looked like it could have been a good'n! I’ll ask around and keep my eyes open for yah Chris, thanks.
Here's a little more jig/cart progress and then a planets are aligning kind of moment! Our new beauty tank has been on fumes and the second it was out our 10lb wire spool ran out also.
Brett
Old 01-08-2018, 11:18 AM   #30
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Some poly bushings, tub o’ grease and oil filter adaptor bolts showed up from Summit. Slid the subframe back under the car again with the new bushings prior to repairing the bad LR body mount hole. Toying with the idea of making our jig able to accept the subframe for front clip fitment later (?).
Brett
Old 01-10-2018, 12:23 PM   #31
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Placed an order a few days ago for some 13ga sheet after we were unable to source it locally. Speedy Metals was certainly spendy, Ha, I mean speedy (compared to the cost of a new subframe this was way cheap)! https://www.speedymetals.com/pc-2681...eel-sheet.aspx
Brett
Old 01-12-2018, 11:37 AM   #32
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Tank swapped and more wire in the machine, our little Lincoln is a happy camper. Here’s the first layer of subframe repair.
Brett
Old 01-13-2018, 12:03 PM   #33
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Second layer.
Brett
Old 01-13-2018, 12:34 PM   #34
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 67 Camaro Build
Nice work on that. Way better than buying new
-Chris
Old 01-13-2018, 06:34 PM   #35
Clyde65
Clyde65's Avatar
Re: 67 Camaro Build
Well done! Always wanted to have a welding talent!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-15-2018, 10:56 AM   #36
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Thanks Chris I agree, much better than buying new.
Thanks Clyde, it's coming along pretty good.
Flipped over for another pass, added some nice ugly weld on the end like the factory welds. Ha, thinking that'll do!
Brett
Old 01-15-2018, 10:21 PM   #37
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 67 Camaro Build
Nice work. Much better than the rust hole before.
Ryan
1969 Chevy milk truck
Old 01-17-2018, 10:22 AM   #38
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Thanks Ryan!
Hole’s been punched and subframe test fitted into the car, giving this particular repair a done stamp.
Brett
Old 01-17-2018, 12:02 PM   #39
rgunlock
rgunlock's Avatar
Re: 67 Camaro Build
Nice repair Brett. You weren't kidding about leaving the ugly welds on the end
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 01-17-2018, 09:53 PM   #40
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 67 Camaro Build
Looks factory, nice!
-Chris
Old 01-19-2018, 11:08 AM   #41
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Thanks Rick, as a friend likes to say “bigger the glob better the job”!
Thanks Chris, since we're only fixing one mount Mr. Picky Pants (me?) wanted to hide the repair.
Back to the jig, mentioned this earlier making both the front and middle supports height adjustable in case we want to add the subframe with its mounts at some point and still level out the body shell. All thread pieces are slotted and cut as long as the tubes so they can be recessed flush but not fall in.
Brett
Old 01-19-2018, 03:40 PM   #42
Dieselwrencher
Re: 67 Camaro Build
That's a very nice body dolly! Can you make one for my Camaro and my 40 Ford so I don't have to?
Ryan
Old 01-21-2018, 11:10 AM   #43
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Yepper, I’m thinking it’s gonna be nice! Hey Ryan, that is a good idea, but no..
Here’s how we’re anchoring the rear, using the old 2-piece frame bushings with the shoulders cut off for a closer flush mount. Then to the risers using the original shackles, it’s pretty dang snug and a bear to install but will hold the car very solid. Getting ready for a gusset party next!
Brett
Old 01-23-2018, 10:26 AM   #44
7dee2
7dee2's Avatar
Re: 67 Camaro Build
1, 2 & 6, gusset parties over, good times… I’m thinking this is gonna work with the subframe!
Brett
Old 01-24-2018, 10:30 AM   #45
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Argh! Too much heat, pulled the uprights inward towards the gussets dangnabit! The alignment holes up front don’t line up any more, it just barely fit through the subframe and the center support section was off by a knat’s a** of popping into its alignment holes. Cutting the tops off and am resetting them.
It's another Mr. Bean moment...
Brett
Old 01-24-2018, 11:17 AM   #46
rgunlock
rgunlock's Avatar
Re: 67 Camaro Build
Sucks when that happens! Can you tack a bar across the top to hold your spacing while you reweld the gussets?
Rick
Old 01-24-2018, 08:45 PM   #47
Dieselwrencher
Re: 67 Camaro Build
That's just how it goes isn't it? Oh well, you'll get it fixed up.
Ryan
Old 01-24-2018, 10:52 PM   #48
bryant6
Re: 67 Camaro Build
Big project... what’s been done looks pretty good. I'm so jealous
Bryan
1980 Chevrolet C20 LWB 2wd
2014 Harley Davidson Heritage Softtail
192.168.0.1
bullet force unblocked
bryant6 is offline   Reply With Quote
Old 01-26-2018, 01:21 PM   #49
7dee2
7dee2's Avatar
Re: 67 Camaro Build
Yeah, tacking a brace in place woulda, coulda, shoulda been a better idea. Or maybe leaving the cars weight on em?
It’s always something!
Thanks Bryan!
So, after cutting the four tops off, cleaning off all the not so old weld and trueing everything up again. With the weight of the car tacked them in place with lots of tacks then pulled and final welded them onto the uprights again. Once satisfied with the support to body fit again went ahead and welded up the rest of it. Yippy skippy, shell went right on without any drama this time!
Brett
Old 01-26-2018, 06:31 PM   #50
Dieselwrencher
Re: 67 Camaro Build
Nice! Is the body ready for paint yet?
Ryan
