Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-20-2018, 08:15 AM   #2901
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Plan B, note to self, do not remove shielding
I have to move XIM box up 2 1/2" to clear cables from the XFI controller
[url=https://flic.kr/p/22v8c2U]20180118_120443
[url=https://flic.kr/p/23yTVSN]20180119_161857
My screw ups, are starting to get expen$ive
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-20-2018, 08:23 AM   #2902
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
Jim
see your steady at it i have a question going back a few of your posts did you purchase or bend your own brake lines im looking at Inline Tube has kits im going with the stainless
Jess
zicc1835 is offline   Reply With Quote
Old 01-20-2018, 08:42 AM   #2903
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by zicc1835 View Post
Jim
Jess
front, I had no problems. Rear, they provided wrong fitting at the union, or 'T', so I had to cut flare, and replace with correct size nut
Stainless can be a PITA to flare, but I read where annealing helps
Maybe, you could ask first what size nuts come with the part
frame and rearend are looking good on your project
SAFETY FIRST
AS usual, off topic
Jim
Old 01-20-2018, 08:49 AM   #2904
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
thanks , Jim
Old 01-20-2018, 09:01 AM   #2905
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thought I'd throw this little tidbit out there.
When sawing with my bandsaw, I heard a thump, thump, thought I broke some teeth, looked at the blade, and there was a build up of aluminum in the kerf. Talking to the manufactor, he had asked what lube I was using, I said none. Told me that was the problem, so now I spray the blade and problem is gone
[url=https://flic.kr/p/Jt7CQ2]20180112_123109
smells like grapes
SAFETY FIRST
AS usual, off topic
Jim
Old 01-20-2018, 09:03 AM   #2906
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
thanks , Jim
Dude, your welcome. That's what this board is all about
Glad you're getting quality time with your truck
SAFETY FIRST
AS usual, off topic
Jim
Old 01-22-2018, 07:34 PM   #2907
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
These are the two new harness, that I had to replace, they are for the LS series engines, but I have 350ci SBC
The original harness was set up for a crank trigger, so no go. Speaking to Jim at TPIS he's advised me that the new harness's will be an easier hook up. just repin for the firing order, and a step up voltage resistor. Also repin crank and cam sensors
The first harness shows the connecters that go to the crank and cam sensors
[url=https://flic.kr/p/22kxwKe]20180122_180308
SAFETY FIRST
AS usual, off topic
Jim
Old 01-27-2018, 11:02 AM   #2908
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/23MiLuu]20180127_090603
Rubber isolation blocks from McMaster-Carr, 1" 1/4-20
bottom blocks 10/32x3/4"
SAFETY FIRST
AS usual, off topic
Jim
Old 01-31-2018, 07:50 PM   #2909
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/23UxGyo]20180131_100335
I wanted to mount the isolation blocks towards the edges of the aluminum mount, but they were to short. So, I settled for one block in the middle, countersunk and full thread, using my handi-dandi counter sink tool, that has been laying in my toolbox for thirty years, cool, the way you can adjust it for depth
[url=https://flic.kr/p/K1Hq8n]20180131_163532
While I was sitting there, admiring my success of the week, poofff, my florescent light above my engine bay blows out. Now, we've all dropped one and know the out come. Carefully, undoing the bulb, it slips momentarily, and clanks the motor, no explosion, great! Bring the whole unit down to change out the other bulb. Put it in, and rehang unit, that is now working, it slips out of my hand, and the whole unit crashes into my motor. I'm stunned, as there is no explosion with shards of glass all over my engine compartment as well as some obnoxious gas we are not to breathe. I packed up and ended my day as I was sure I've extended my luck
Now, I can move on to the XIM box, and mount it with isolaters I got from Mcmaster-Carr
SAFETY FIRST
AS usual, off topic
Jim
Old 03-19-2018, 11:26 AM   #2910
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/Hbyd2b]20180319_104535
tired of tripping on tools and supplies while working
[url=https://flic.kr/p/Hbyd21]20180319_104544
SAFETY FIRST
AS usual, off topic
Jim
Old 03-25-2018, 08:54 AM   #2911
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
changed my mind again, and decided to stack my computers, I think this could be the last change, as I have to get on with the wiring
Mcmasters-Carr sent some U channel to be used to mount the top computer
[url=https://flic.kr/p/HjFqnS]20180324_16022
SAFETY FIRST
AS usual, off topic
Jim
Old 03-26-2018, 03:16 PM   #2912
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: PO has me PO'd
looking good.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-27-2018, 06:10 PM   #2913
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by my67chevytruck View Post
looking good.
Thank you, sir. your build came out awesome, much better metal work then mine
SAFETY FIRST
AS usual, off topic
Jim
Old 04-06-2018, 02:24 PM   #2914
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
upside down, backwards,inverted, and inside out....redundant
If you design something, make sure it is easy to work on....had to add two access holes to allow use of allen wrench for tightening of mounting bolts on XFI
XIM mounts on top of C channel
[url=https://flic.kr/p/238CZBu]20180406_114555
SAFETY FIRST
AS usual, off topic
Jim
Old 04-11-2018, 08:50 AM   #2915
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/25XstPS]20180410_091556
[url=https://flic.kr/p/23goonw]20180410_092439
I had read somewhere that soap will stop aluminum from cloging up disk, don't know if it is working, but my work shop smells like Irish Spring
SAFETY FIRST
AS usual, off topic
Jim
Old 04-11-2018, 10:10 AM   #2916
scott123
Re: PO has me PO'd
What color green is that?
Is that a factory color or aftermarket?
Scott
scott123 is offline   Reply With Quote
Old 04-11-2018, 07:02 PM   #2917
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Scott
Yes, it is a factory color, dark olive, with a small metalic flake in it, the only part of my truck with original paint
SAFETY FIRST
AS usual, off topic
Jim
Old 04-13-2018, 10:15 AM   #2918
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
My perferred method of drilling holes....center punch, or transfer punch, center drill, lubrication, and then drill size.
[url=https://flic.kr/p/264kyZ9]20180413_094748
SAFETY FIRST
AS usual, off topic
Jim
Old 04-13-2018, 01:47 PM   #2919
scott123
Re: PO has me PO'd
I had seen that color before just not with the metal flake.
I will look it up. I like it.
I had picked a dark jade green metallic but I like that color a little more.
Scott
Old 04-14-2018, 10:17 AM   #2920
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Scott
It is a micro flake, maybe called fire mist back in the day, and appears to be gold...have to look real close to see it
SAFETY FIRST
AS usual, off topic
Jim
Old 04-14-2018, 03:01 PM   #2921
scott123
Re: PO has me PO'd
I found it in an old sampling color chart. In the color chart the flake does not show up as much as in the floor board pics of this thread's blazer.
It looked somewhat aftermarket not factory.
Just caught my eye.
Did not mean to get the topic off track. LOL
Scott
Old 04-15-2018, 11:24 AM   #2922
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
here's another pic, maybe easier to see...there is a gold flake in there
Off Topic LOL....my whole build thread is filled w/off topic. just random thoughts of what I do every day
[url=https://flic.kr/p/J4bYLQ]20180415_112104
SAFETY FIRST
AS usual, off topic
Jim
Old 04-15-2018, 02:09 PM   #2923
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
Jim have you given any more thought to parting with a manifold that will work with the Sniper EFI system im contemplating......
Old 04-15-2018, 06:59 PM   #2924
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Jess, all I have are vortec manifolds...if you decide to change your heads, I would be more than happy to help out. Your engine looks killer with those valve covers. GMPP have dual mounting holes for vc's
SAFETY FIRST
AS usual, off topic
Jim
Old 04-16-2018, 07:19 AM   #2925
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
Thanks Jim May take the easy way out this go around use what’s there ..will see I won’t need an excuse to to take an ride out for a visit when weather finally turns
