#1901 |
Re: My 52 GMC Build
can't believe all that room you had. looks way better for sure.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#1902 |
Re: My 52 GMC Build
Looks great! What's it do to ride height? Obviously you can still put in on the ground!
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
#1903 | |||
Re: My 52 GMC Build
I agree
Thanks Me too Quote:
Thanks guys it looks really good can't wait to get the duallys painted to match and see it outside.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#1904 |
Re: My 52 GMC Build
Oh snap. That looks really nice. I’m jealous.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#1905 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: My 52 GMC Build
That looks so much nicer than the iroc looking wheel brother!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#1906 |
Re: My 52 GMC Build
Thanks Matt Get working on yours I want to see some progress in October.
Ya I agree. Sometimes things just have to evolve.
#1907 |
Re: My 52 GMC Build
Ya I forgot I cut 3" off the bottom of the fenders too.
#1908 |
Re: My 52 GMC Build
Might have to meet up for some new photos
#1909 |
Re: My 52 GMC Build
Sounds good Dave. I could come out to your part of the world.
#1910 |
Re: My 52 GMC Build
Thought I would show all my fun shop seats for hanging out. Everything is on casters so they can be moved out of the way.
Caravan couch. It can recline all the way and is still stable. Step stool/seat Movie theater seats And the racing office chair.
#1911 |
Re: My 52 GMC Build
Rims look awesome ..nice seating section.. lol
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#1912 |
Re: My 52 GMC Build
I might have to use the caravan seats. As long as I don’t roll away or off. Lol.
#1913 |
Re: My 52 GMC Build
Lowered
All that is left to complete your set up is a fridge loaded with the beverage of your choice and a pot belly stove. Fun, fun, fun. Nut case Shop looks great....
Been there, wrecked that ![]() |
#1914 | |
Re: My 52 GMC Build
Thanks Corey
I have a full size fridge in the corner full of drinks/Beer
#1915 |
Re: My 52 GMC Build
So all last summer my hydro boost was leaking out the front seal, I just kept putting absorbant pads under it and toped up the fluid. So after a long search I found the right one for the right price. Bought a rebuilt one off amazon (no core charge) and a rebuild kit off ebay for $40 for the other one down the road.
#1916 |
Re: My 52 GMC Build
nice, gotta love the net.
#1917 |
Re: My 52 GMC Build
I was wondering where you been hiding. I thought maybe you were buried up in snow. Hope all is well. Good score on the hydro boost.
#1918 |
Re: My 52 GMC Build
Yes sir!! My parts guy was $100 more than Amazon, and I get garage discount.
Ya I have been catching up with other projects that took a back burner when I was building the shop. Now back on the truck for some maintenance. Not much snow up here at all actually 1/2".
#1919 |
Re: My 52 GMC Build
Hydro boost is back on and hooked up need to bleed the system when I start it up. Also changed out a few of my ignition switches that started to give me some trouble.
My shop has just a few projects on the go.
#1920 |
Re: My 52 GMC Build
don't think your'e gonna get that tire on the jetta,but if you did.........new build thread, haha
when you bleed the hydroost, what I have found to be helpful is to run the return line into a jug instead of back to the reservoir. that way the air bubbles don't get back to the pump and cause them to be aerating the whole system plus the power steering system, plus any debris in the lines or coming back from the hydroboost (?) will be captured. of course you need a buddy to keep feeding fresh fluid to the reservoir (I use an old 1 gallon plastic jerry can with the lid adapted so it will accept a 3/4 hose, that way it is easy for the reservoir checker to tip some more in). I find doing power steering systems and hydroboost systems this way makes the job much faster because the fresh fluid doesn't get bubbles in it from the returning fluid line which is usually a lot of air at first. since the system is re-using the fluid the pump takes the returning bubbles, makes them smaller and redistributes them back into the system.so you are getting aerated fluid re-distributed to compound the problem. also, there is a pressure reserve cannister (engineered to give a reserve power brake application should you lose the pump from broken belt or stalled engine etc) in the hydroboost that can possibly get bubbles in it so it will take longer to purge that as well. it takes longer to get them out and you need to let it sit for awhile inbetween each set of "runs" to allow the air to settle out/escape, then do it all over again. sure, you use a couple extra quarts of fluid but if your system is clean to start you could capture it in a clean jug and possibly use it for something. just a thought |
#1921 |
Re: My 52 GMC Build
sorry, shouldda said liters, fellow Canadian, not quarts. what was I thinkin......showing my age I guess....
still think the jetta would look cool with a 4x4 under it, haha |
#1922 | |
Re: My 52 GMC Build
As for the Jetta on a 4x4. It's funny you said that because I'm swapping that TDI into my Jeep next winter.
#1923 |
Re: My 52 GMC Build
Well rear dually rims are painted to match the front and my son and I put them on.
Whoever thought of the playing cards around the rim for painting need a pat on the back. OOOHHHH YYAA that it what the truck needed!!!!! ![]() Then I put the truck on the hoist for the first time. Aired out it rests nicely on the hoist.
#1924 |
Re: My 52 GMC Build
That looks great!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#1925 |
![]() Join Date: Mar 2011
Re: My 52 GMC Build
Looking good there buddy...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Tags |
bagged, build, diesel, gmc, hot rod |
