Old 01-27-2018, 08:23 PM   #76
harpo231
harpo231's Avatar
Re: 71 350 running hot coolant backup up problem
Gun i used in my thermoformers took temps 1 inch apart accurately , but it was 600 bucks
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 01-27-2018, 08:28 PM   #77
B. W.
B. W.'s Avatar
Don't give up on your temp gun yet! I use mine almost daily (I'm a mechanic) If you measure right at your thermostat you can actually "watch" the Tstat open & close (pretty cool) In so doing you can verify it is working & it's opening at the correct temp. Don't get too picky about exact numbers, if a 180° opens at 185° it doesn't matter, close enough.
to confirm your gauge is accurate you need to shoot the sender in the driver's head. From what you posted it's close enough.
So, from what you've posted, your engine & your gauge are doing pretty much what you thought all along. This is good to know.
My opinion (FWIW, everyone else has given theirs!) you've covered all the basics, some more than once. The one item you have not addressed is the radiator. You can look down the tank & it "looks" good but you cannot see down the tubes & these are what get clogged.
Take your new gun & shoot the radiator starting at the driver's top (hot coolant in) then shoot various points to the pass side bottom ( cooled coolant out) In perfect world, you want to see about a 50° drop across the radiator.
Time for a radiator (easy for me to spend your $ but it's still cheaper than an engine!)
side note: 50/50 mix (or any ratio) versus straight water will not make any difference. From the tech articles I've read, water with a "wetting" solution removes heat the best BUT the difference IN A PROPERLY OPERATING SYSTEM is negligable.
B. W. is offline   Reply With Quote
Old 01-27-2018, 08:35 PM   #78
Gregski
Gregski's Avatar
Originally Posted by B. W. View Post
... My opinion (FWIW, everyone else has given theirs!) you've covered all the basics, some more than once. The one item you have not addressed is the radiator. You can look down the tank & it "looks" good but you cannot see down the tubes & these are what get clogged.
I agree, I was always taught to replace parts if needed or suspect starting with the cheapest one first, hence the $7 dollar thermostat, then the $18 water pump, now we're ready to drop the $200 on the radiator, seems logical to me
I totally agree, and was trying to prove that to others in some of my tests
Gregski is offline   Reply With Quote
Old 01-27-2018, 09:13 PM   #79
Steeveedee
Who Changed This?
Steeveedee's Avatar
Originally Posted by Gregski View Post
so after she went back all together it was time to test, and to keep things fair and compare apples to apples, I put it all back to the way the General intended
FIRST TEST POST SHORT WATER PUMP SWAP
so 195* Thermostat, Short Water Pump, no bypass hose (heater core delete, remember) and running only water
RESULTS = Favorable but not there yet
the truck did not get hot idling in the garage after 15 minutes like it used to, it used to reach 205* just sitting there, I let it idle for 40 minutes and it just eventually got to 190*
so I took it for a TEST DRIVE...
and gosh darn it I saw it climb to 215* that aint right!!!
Classic symptom of a clogged radiator. Stays cool at idle, and gets hot going down the road, under load.
~Steven
Simi Valley, CA
Old 01-27-2018, 10:47 PM   #80
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 71 350 running hot coolant backup up problem
Anti freeze isn't in the radiator for cooling. Its to keep the water from freezing in the winter time and to lube the water pump and keep the system clean that's all.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-03-2018, 09:15 PM   #81
Gregski
Gregski's Avatar
so I may have discovered something that may save you some grief or at least save you some money if you ever experience something similar to this
but first let me tell you the last thing I did before this discovery
I went out and dropped $200 on a brand new cheap Spectra "Premium" radiator, of the plastic and aluminum variety
Old 02-03-2018, 09:17 PM   #82
Gregski
Gregski's Avatar
here is a closer look at the Spectra Premium A369 radiator
it measures almost exactly the same, except the top parts that are supposed to fit into the rubber mounts on both the left and right sides are too wide so I had to cut and use 5" strips of an old mountain bike inner tube to use as buffers between the metal brackets and the aluminum radiator instead of the stock rubber pieces
Old 02-03-2018, 09:20 PM   #83
Gregski
Gregski's Avatar
mandatory stare and compare of the old brass/copper radiator and the new plastic and aluminum one
Old 02-03-2018, 09:28 PM   #84
Gregski
Gregski's Avatar
So what are the findings?
So now with a brand new stock 195* thermostat, a brand new short water pump, a brand new plastic/aluminum radiator, running water only (for test purposes only)...
The truck idles fine in P-Park I think it was like 135* F after 15 minutes of just sitting there, it would slowly warm up more, but I decided to take it for a spin
It cruises at 185* F, however and here's what I recently discovered, when stopped at a stop sign or at a stop light, it will climb North of 200* F in just one minute, now this is in D as in Drive
OK, yeah so what? Well I decided to shift it into N for Neutral and sat at an isolated Stop Sign for five minutes and the truck never inched past 195* F, now that has to tell us something! Right?
I also tried it in reverse, I pulled into a parking lot and backed into a space and left the truck in R-Reverse and sure enough in just one minute it reached 200* F
your thoughts?
Old 02-03-2018, 09:49 PM   #85
harpo231
harpo231's Avatar
Sounds fine to me ,,, fer an ole truck !
Stan
67 swb BLU MULE
Old 02-03-2018, 09:52 PM   #86
bautino95
Active Member
I still think you should put a 180* t-stat
bautino95 is offline   Reply With Quote
Old 02-03-2018, 10:08 PM   #87
Gregski
Gregski's Avatar
I think in the long run I will, I am running a 180* thermostat in my '74 but that engine has the Vortec heads on it, which are prone to cracking under heat, just so you know I tried testing with the 180* earlier in the thread and it still ran hot, so the source of the ongoing problem must be dealt with first
Old 02-03-2018, 11:34 PM   #88
Steeveedee
Who Changed This?
Steeveedee's Avatar
OK, let me do the TL;DR version-
You have a new water pump, new radiator and new thermostat. Is this true? If so, check for a blown head gasket/cracked head, etc.
~Steven
Simi Valley, CA
Old 02-03-2018, 11:44 PM   #89
Andy4639
Old member
Andy4639's Avatar
I see what your getting to I think. The transmission is causing the rise in temp when in gear. The temp will be added to the radiator as hot transmission fluid passes through it.
I run a external on all of my vehicles.
Old 02-04-2018, 09:23 AM   #90
Grumpy old man
Grumpy old man's Avatar
Looking at your pictures your bypassing the heater core which would add about a gallon in volume , i would use a 180 thermostat and for a few bucks more the Champion all aluminum radiator that many guys use and like that fits well .
Old 02-04-2018, 02:12 PM   #91
clay68c10
clay68c10's Avatar
Two things I can think of
1. How much is your rpm dropping when you go from p/n to d/r? If the engine slows, so does the water pump. Might kick up your idle and see if it changes the result. The trans front pump is pumping fluid thru the cooler no matter what gear you select, so that’s probably a non issue.
2. If you are running Vortec heads, they have a different cooling passage setup compared to non Vortec heads. I don’t remember exactly, but it has something to do with the water pump bypass and how that is routed thru the block. If those heads are used on an old style block you have to accommodate for that. Might be worth a bit of research to ensure you aren’t chasing that.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-04-2018, 02:33 PM   #92
Gregski
Gregski's Avatar
You are asking the right questions, I just bought a brand new tach, so I will hook that up and see, I know I can do this with my Mac Tools digital timing light, but I am a one clown circus act, so its easier with a permanent tach. What RPM should it idle at? I read somewhere on automatics you wanna shift it into gear and check the idle RPM that way as well? I aint too versed in automatics, a stick man myself! ha ha
I am not running Vortec heads on this truck. I was talking about my '74 when I brought those up, but yeah you are correct the Vortecs require a bypass hose from the intake manifold to the water pump.
Old 02-04-2018, 02:51 PM   #93
clay68c10
clay68c10's Avatar
I’d set the idle to around 650 in drive and see what happens. What’s it idling at in gear now?
You may have to play with initial timing and idle screw adjustments (throttle plate and mixture) to get it so the neutral to drive rpm difference isn’t too extreme. Like add timing and lessen the throttle opening, or change up ported vs manifold vac to the can. The usual hide the salami carburetor adjustment game...
13 Tahoe LTZ
Old 02-04-2018, 03:14 PM   #94
Keystone_Hate
This may sound kinda silly but try jacking up the front of the truck. Get it as high as you can while still being relatively safe. Take off your radiator cap and see if ya get any bubbles. You might have a big air pocket stuck in the back of the engine. Just an idea.
Keystone_Hate is offline   Reply With Quote
Old 02-04-2018, 03:33 PM   #95
harpo231
harpo231's Avatar
Do a couple cartwheels and a backflip ,, that'll do it ...
Stan
67 swb BLU MULE
Old 02-04-2018, 04:29 PM   #96
Keystone_Hate
he's jumped through enough hoops already, this couldn't hurt.
Old 02-04-2018, 05:18 PM   #97
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Just a thought.Do you have the wire like, a coil spring in your lower hose? I know it wouldnt matter at idle, but when driving the hose could suck shut restricting flow?
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 02-04-2018, 07:15 PM   #98
garyd1961
No matter if you are running vortec heads or not a by-pass hose is a good idea. The factory put one it for a reason. The by-pass keeps the water circulating through the block and heads and eliminate hot spots.
garyd1961 is offline   Reply With Quote
Old 02-04-2018, 08:01 PM   #99
rockyrivermark
You can get a 3 core polished aluminum champion radiator on eBay now for $205 with free shipping
I just picked one up last month. Fit very good.
Good deal
https://m.ebay.com/itm/1967-68-69-70...gAAOxyBPZTid8U
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 02-04-2018, 08:11 PM   #100
Gromit
I did notice the 850 RPM idle speed you mentioned sounded about 200 RPMs high but since some people like what I would consider a high idle so I didn't want to judge.. I prefer a putta-put-put - maximum 650 RPM or as low as I can get it to run smoothly in that neighborhood. You definitely don't want your centrifugal advance coming in at whatever idle you wanna use.
Hey I may have been wrong about your initial timing being the cause of your overheating but just maybe I was on the right track with my second choice of the heat possibly coming from your TH350. If so it is too bad I wasn't smart enough to link your high idle with the trans fluid shearing forces maybe creating too much heat in the fluid. Maybe a sniff test of your fluid will help to tell the tale. Luckily you can drive it now just put it in neutral at the stoplights.
Gromit is offline   Reply With Quote
