#201 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: 1972 Medium Blue Highlander Blazer Resto
I broke out a few other NOS pieces: AIR pump, grommets for the valve covers, oil caps, and bolt for the t-case shifter. Electroplating of El Paso did a good job on the rechromed shifter (http://www.electroplatingelpaso.com). I've got the chrome caps that cover the exposed division bars for the vent windows out for rechrome at the moment.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 10-29-2017 at 11:41 PM. |
#202 |
Carpe manana
I've been able to piece together the missing pieces for the CA emissions control that was original installed, which was most of it including manifolds, heat shroud, injection pipes, and this piece with the two hoses. Not sure what this piece (edit: diverter valve) is called but Im going to chase a better example and need to track down the gasket used to install it onto the pump.
Maybe corvette parts suppliers will have the gasket...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 10-30-2017 at 12:10 AM. |
#203 |
Carpe manana
Spent yesterday sorting out all the engine brackets and associated replated hardware. Inching closer. On a whim I carted home a reman A6 AC compressor: the harness connections are at 2:00 but OEM is on 11:00 - may send the original compressor out for a rebuild.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 11-01-2017 at 09:28 PM. |
#204 |
Carpe manana
Went with an internally regulated alternator. Resto mod I guess
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 11-01-2017 at 09:12 PM. |
#205 |
Carpe manana
Polished up the rubber hose to the carb spacer and used replated Oem tower clamps.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 11-01-2017 at 09:32 PM. |
#206 |
Carpe manana
Plug heat shields were replated. The tranny inspection cover would not pop into place: I suspect the nose cone for the starter doesn't match OEM. Sigh...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#207 |
![]() Join Date: Jan 2012
Loooking Goood!
#208 |
![]() Join Date: Feb 2008
Looks great as always.
#209 |
Looks great Pete. Moving along nicely. Are you sticking to the stock trans or thinking about upgrading to the 700R4?
When I was on the highway yesterday I kind of wish I did the 700R4 swap. When cruising at 65 mph my RPM's are about 2800 with the stock 3.07 gears that mine came with. Maybe sometime down the road I'll update mine to a 700R4.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
#210 |
Carpe manana
Thanks guys. Mike, since the th350 was original to the truck it was rebuilt and is bolted into place. The 3.07 gears were replaced with 3.73s and I expect to run 33" tires. It's going to generate some rpms on the hwy! I've got a 700r4 in my my k20 w 4.10s and it cruises at speed nicely w low rpm.
#211 |
I'm trying....
![]() Join Date: Oct 2013
Gosh...I sure do hate it when I miss an email alert. So much I've missed since Halloween. Great progress Pete. This is a special build. I'm tempted to say "keep up the great work"...but for you that's the same as saying: " Keep Breathing." Looks great!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#212 |
Very interesting thread Pete, all of yous (I know that's not a real word but I use it anyways!) are awesome Chevrolet folks!
#213 |
This is going to be an excellent restoration, nice work.
#214 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Hey Pete when you get it done to your standards and ever need cash the Blazer should come in handy.
https://www.ebay.com/itm/1972-GMC-Ji...53.m1438.l2649
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#215 |
Carpe manana
Build is gaining steam since the holidays. Since my last post I've rebuilt the vent windows and pulled more parts off the shelf for assembly.
What a hassle the vent windows are to build. I sent the chrome trim for replating and made use of some nos pieces.
#216 |
Carpe manana
But they turned out nice.
#217 |
Carpe manana
Doors and fenders on - AC box and misc other pieces ahead of the firewall.
#218 |
Carpe manana
I found this NOS heater core - had date of February 1972 on the box, which coincides with assembly month for this blazer.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 02-07-2018 at 01:09 AM. |
#219 |
Carpe manana
The medium blue is growing on me - I can't wait to see it in the sun.
#220 |
Carpe manana
Underdash harness installed - plug and play M&H. I was able to source the following NOS components: switches for the dash, wiper motor w pump, ignition relay, ignition bezel, AC controller, ash tray, dash pad, defrost vents, AC center vent, cigarette lighter, and a glove box light.
I'll get better pics soon.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 02-07-2018 at 12:42 AM. |
#221 |
Carpe manana
#222 |
Carpe manana
Greg with S/M Electrotech refurbished this truck FM for me and installed an aux coax jack. The underdash speaker is a working original. I placed some gaffers tape between the top of the chrome faceplate and the chassis - van radios had this and it reduces light bleeding through into the cab.
I'm using a NOS telescoping antenna correct for an AM radio: the fixed mast FM examples don't ever seem to clear a garage door.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 02-07-2018 at 12:20 AM. |
#223 |
Carpe manana
#224 |
Carpe manana
Mice had chewed the foam rubber flapper from the inside of my duct assembly. I found this replacement with a 1968 date on the invoice. With all the dust I assume this sat for decades on a shelf in PA.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 02-07-2018 at 01:16 AM. |
#225 |
Carpe manana
Board member FAA benny refurbished this AC box for me and did a POA conversion for R134. The original AC hoses have been exchanged but the OEM metal fittings were kept. The original brass nut is still in place on the suction hose.
