Old 01-14-2018, 03:15 PM   #1
CentralPA
70 c10 build
I posted this in the welcome boards but here is a link to my build
http://67-72chevytrucks.com/vboard/s...d.php?t=754801
CentralPA is offline   Reply With Quote
Old 01-28-2018, 10:27 PM   #2
CentralPA
Re: 70 c10 build
We finished the trailing arms. Waiting for a package from Ridetech and we can finish up the rear.
Old 01-28-2018, 10:49 PM   #3
CentralPA
Re: 70 c10 build
The design/build of the center cross member was also started this weekend. Also sat a 350 on her for the first time to pull some measurements. I really stoked how everything is coming out. Ill keep updating as I get a chance.
Old 01-29-2018, 09:14 AM   #4
JohnJ@RideTech
JohnJ@RideTech's Avatar
Re: 70 c10 build
It looks like its coming right along. What wall thickness are you using for your cross member?
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 02-02-2018, 07:47 PM   #5
CentralPA
Thumbs up Re: 70 c10 build
1.75 x .125 DOM tubing ,it was originally bought for a roll cage on a RZR.
Old 02-05-2018, 12:28 PM   #6
CentralPA
Re: 70 c10 build
Well we worked on the cross member and finished the trailing arms. We also got the panhard bar on everything is coming together nicely
Old 02-05-2018, 12:32 PM   #7
CentralPA
Re: 70 c10 build
I'd say everything is pretty square and level.
Old 02-05-2018, 12:38 PM   #8
CentralPA
Re: 70 c10 build
Cutting the trailing arm brackets on the Plasma table
Old 02-10-2018, 10:32 PM   #9
CentralPA
Question Re: 70 c10 build
Finished up the panhard bar and we capped off the frame notch. Going to tear everything apart finish welding, and get it off the frame table on to the rotisserie !
Old 02-11-2018, 08:38 AM   #10
hewittca
hewittca's Avatar
Re: 70 c10 build
Coming along nicely. I like those trailing arms. How much of a drop is built into them?
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 02-11-2018, 02:22 PM   #11
CentralPA
Re: 70 c10 build
The front is 5" the rear is 7" but it is set up, if I wanted to, to bag it and lay frame. I'm going to stay with the coil overs though. Put that extra money in the motor !
Old 02-11-2018, 04:45 PM   #12
72 tigger
72 tigger's Avatar
Re: 70 c10 build
Nice detail work! Following along
72 tigger is offline   Reply With Quote
Old 03-01-2018, 05:27 PM   #13
CentralPA
Re: 70 c10 build
Here's the latest guys. Finished mounting rear shocks. It took a while to gather up the material and tooling needed to make the stainless top mounts, but they turned out great. Then it was tore down again to finish welding and grinding. Hopefully the next couple weekends it is ready to spray.
