03-07-2018, 02:09 AM | #1 |
Rear End Question
Newbie here. I recently acquired a 72 c20 and I will modernizing the drivetrain and doing a full restomod. It’ll be a 5.3l mated to a 4l60e. My question is if I would be able to swap in a 2008 Escalade rear end with 3.42 gears and 6 lug in place of the 8 lug rear end. This would allow me to use modern stock Chevy wheels and have rear discs. The front would obviously be swapped to 6 lugs as well.
Thanks! |
03-07-2018, 03:36 AM | #2 |
Re: Rear End Question
I am sure the shock location would match up. But you could give it a try
Brian Ritter |
03-07-2018, 08:08 AM | #3 |
Time to do some measurements, I like comparing the width at the wheel mounting surface. If it’s within an inch or 2, you are probably good to go.
You will probably have to move around spring perches and shock mounts.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
03-07-2018, 11:51 AM | #4 |
I would focus my attention on a 14 bolt semi-float. Stronger than a 12 bolt
03-07-2018, 12:10 PM | #5 |
Yes you can put anything in there you want. Just get the spring perches installed correctly with the right pinion angle. You will more than likely need a new rear yoke for driveshaft but thats a given you will have the driveshaft redone anyways, along with redo shock mounts on rear end or truck, then the master/combo valve selection.
It can be done, but its not a simple deal. You may want to look into just swapping the axles to 5 lug and new discs. Its only $$ right?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
03-07-2018, 02:35 PM | #6 |
I may end up going the axle swap route and doing 5 lug. I was originally intending on using late model 6 lug wheels as I’ve got 2 sets that I’ve yet to sell off.
03-07-2018, 02:36 PM | #7 |
Yeah if it was a 70 or earlier that would be cool, but I'd try and keep it 5 lug.
03-09-2018, 01:28 PM | #8 |
What rear end is this?
03-09-2018, 02:05 PM | #9 |
20' Daredevil (Ret)
Pretty sure that's a Dana 44.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-09-2018, 02:11 PM | #10 |
I'm going to assume this isn't a stock Rear end. The build sheet has it with 4.10 gears and I'm just now shopping around for rear end disc conversion as well as wheels. What would be my options on rear disc conversion?
03-09-2018, 02:13 PM | #11 |
Post pics of the SPID and Build Sheet
03-09-2018, 02:21 PM | #12 |
Here it is.
03-09-2018, 03:39 PM | #13 |
That's a Dana 60 axle
03-09-2018, 04:08 PM | #14 |
Was this OEM or aftermarket? I apologize for all the questions. Just want to cover all my bases before I throw money into it.
03-09-2018, 04:18 PM | #15 |
That Dana 60 is OE and a little bit of a surprise as most Chevrolet's got the Eaton axle.
I would keep it. It's way stronger and has more aftermarket support than the AAM 8.5 axle in the Escalade.
03-10-2018, 09:19 AM | #16 |
Thanks everyone! I’ll be keeping this rear end and converting over to disc after I refurbish it
