03-11-2018, 04:09 PM | #1 |
School me on oil pans
Needing an oil pan for my BBC Mark IV. There are so many choices out there I'm not 100% sure on where to start.
This engine is a 489 with a forged eagle 4.25" stroker kit. So I know I need a pan that will clear that much stroke. I've put a lot of money into this engine and I don't want to skimp on the oil system. I've found a moroso oil pan kit on Jegs that seems like a decent setup, but for a few more bucks I can get one with a windage tray and a crank scraper. These kits come with everything needed for the oil system. I want a pan that will clear my stock crossmember on my 2wd. I just dont know how deep of a sump to get and how many quarts capacity pan to get. I've been shopping in the street/strip category. Any other info I need to provide just let me know. Thank you. |
03-11-2018, 06:31 PM | #2 |
Re: School me on oil pans
Several oil pans on the market ranging to over 500 bucks....for street use, I would not spend the money, make sure the oil pan clears the crank and call it good. scrapers are not needed...unless you have tons of cash, buy it !!!!
03-11-2018, 10:00 PM | #3 |
If you are a subscriber, Engine Masters latest episode was about oil pans. They test factory stock and off the shelf Milidon with baffles. Basically it did make a difference of quite a few HP but all at high RPMs. I forget the exact numbers but it made a surprising difference. But, just as high RPMs.
There are other advantages but it really depends on your use and needs if it was worth it. Racing, absolutely! PS There was a lot of information on this show. If you are not Motor Trend Subscriber it will come out on YouTube in a few weeks. This was the last video they did and I think it would be well worth watching. You can see the results on the dyno and they talk a little about theory and practicality. I learned a lot watching it. Here is the teaser. https://www.youtube.com/watch?v=YhG9NZOiqqo Last edited by Kudzupatch; 03-12-2018 at 04:59 PM. |
03-11-2018, 11:18 PM | #4 |
60-66 Nut
If you installed a HV oil pump, you should have more than 5 qts of oil. If you don't have room for a larger oil pan, change the oil pump to a standard volume oil pump.
03-12-2018, 01:56 PM | #5 |
first off, what's it going into? truck/Car? Lowered bags? You don't want the pan's sump to hang down to low (below x-member) Thats how i would choose one and 7qt should do it. Plenty out there. 1st pic summit cheap 2nd milodon more $$$
1961 chevy K10 my build is------------61K10 build |
03-12-2018, 03:25 PM | #6 |
I'm running a 496 stroker kit in my 67 c10. I used a stock truck big block pan with no issues. don't think you need to worry about any clearance issues with the 4.25 stroke.
03-12-2018, 10:01 PM | #7 |
I will have to check out that episode when it comes out. I did watch the episode on air cleaners - pretty interesting stuff!
I haven't installed an oil pump. Actually haven't even bought one yet. I was probably just going to buy the kit which will come with the oil pump as well. This is going into my 69 2wd c10 pickup. I have 2 1/2" drop spindles with stock height springs. So it's not going too low. I guess I was never worried about it dragging on the ground or anything. I'm just worried about the pan interfering with my stock crossmember. Tiger joe - that is interesting... when I was looking at pans the details state on the site for stock pans that they aren't cleared for more than a 4" stroke. So I guess I started looking into the deeper pans. I guess I have the stock one on there now. Engine is on engine stand. I've turned it over a few times, never really felt the crank rubbing. How does your pan handle that engine? |
03-12-2018, 11:13 PM | #8 |
60-66 Nut
Trucks typically have a quite a bit of room for oil pans unless you move the engine forward unnecessarily. Since your truck is lowered, you don't want a pan much deeper than stock. One of the pans that 61K10 posted should work.
03-13-2018, 08:48 AM | #9 |
I bought Jeg’s street strip pan for my 427. $220
http://www.jegs.com/i/JEGS-Performan...50230/10002/-1
03-18-2018, 11:02 PM | #10 |
Which Oil pump pick up did you get ?
03-19-2018, 06:41 PM | #11 | |
03-20-2018, 08:52 AM | #12 |
It’s still on my engine stand! I’ll update when I get it installed finally. I think the F body pan is the one I went with because sump slightly shorter.
03-20-2018, 08:53 AM | #13 |
I bought whichever was recommended from Jeg’s for my pump.
03-20-2018, 03:05 PM | #14 |
motor exploder
http://vortecpro454.com/
Give Mark Jones a call - he is a master when it comes to oil control on big block chevy engines.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
