Old 02-27-2018, 08:02 PM   #26
_Ogre
_Ogre's Avatar
Re: Any Solutions to 55/56 Hood Oil Canning
apache hoods came with the brace down the center
it still flexes quite a bit anytime you get much over 80 mph
shop air compressor timer
Old 03-17-2018, 09:15 PM   #27
bosco
bosco's Avatar
Finally was able to install my fix for the hood oil canning. Appreciate everybody's help and ideas. Here's the final solution. Fits right up against the hood, used some dabs of silicon along the way to provide some vibration dampening.
bosco is offline   Reply With Quote
Old 03-17-2018, 11:18 PM   #28
MARTINSR
MARTINSR's Avatar
Right on, hopefully what you dabbed between them stays flexable. From the factory they use a soft foam because if what you put "glues" the two together you will end up with a "ghost line" on the top that you will be able to see.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 03-18-2018, 05:27 PM   #29
bosco
bosco's Avatar
Thanks. It fit really well. Yes the silicon is a soft when cured. Didn't use that much, just enough to eliminate any vibration.
Old 03-18-2018, 05:30 PM   #30
MARTINSR
MARTINSR's Avatar
Cool!
Brian
1948 Chevy pickup
Old 03-19-2018, 08:29 AM   #31
bowt1ed
Looks good bosco. I see you bolted the l bracket to the brace, in lieu of welding it.
Jim
bowt1ed is offline   Reply With Quote
Old 03-19-2018, 09:49 AM   #32
MARTINSR
MARTINSR's Avatar
Jim
Which was GREAT thinking huh! It looks good, he did an awesome job on that one, probably should start selling them.
Brian
1948 Chevy pickup
Old 03-19-2018, 12:28 PM   #33
bosco
bosco's Avatar
Jim
Yeah. My welding skills need some work. I used pan head bolts so they fit cleanly under the brace. Used lock-tite to make sure nothing comes loose.
