Old 03-13-2018, 11:04 AM   #1
SnS C10
SnS C10's Avatar
which front and rear diffs came on my suburban and will these fit?
Hey guys I was wondering what diffs came from the factory on my 86 2500 4x4 suburban? I found a set of diff covers local and was wondering if they would fit.
SnS C10 is offline   Reply With Quote
Old 03-13-2018, 11:42 AM   #2
Jsfucttruck
Re: which front and rear diffs came on my suburban and will these fit?
In 86 your 3/4 ton 4x4 would have a 8 lug, 10 bolt front axle and a semi-float 14 bolt from the factory.
Neither one of those is going to fit if you have factory axles.
Potentially, one of those(upper one) might fit if someone swapped a 14bff rear axle in.
Jsfucttruck is offline   Reply With Quote
Old 03-18-2018, 01:26 PM   #3
cal30_sniper
cal30_sniper's Avatar
A lot of 3/4 ton burbs came with 14bolt full float axles. Just have to crawl underneath and see.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress
73 Formula - 400/Doug Nash 4+1, resto on hold
86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale
01 Ram 2500 - 5.9L Magnum, daily driver
91 BMW 325i - Chumpcar series racecar
cal30_sniper is offline   Reply With Quote
Old 03-18-2018, 10:23 PM   #4
Jsfucttruck
I have a 78 k20 burb that came with a 14bff.
It was my understanding that 4x4 burbs after 81 did not come with 14bff or a BBC. K/V 20 series only came with semi float 14 axle with a sbc or diesel.
If it was a 2wd. You could get a 454 and a 14bff in one package.
Old 03-19-2018, 02:07 AM   #5
Irish1941
Irish1941's Avatar
Truth right there.
Pull off the hubcap and if there is a big hub in middle of the axle, 14bolt full floater. No need to crawl under it.
If that is what you indeed have then somebody swapped it in there.
Irish1941 is offline   Reply With Quote
Old 03-19-2018, 04:46 AM   #6
mongocanfly
mongocanfly's Avatar
mine has 14b semi rear ..not a ff.....and a corp 10b front...mines 91
1st pic is semi
2nd pic is full
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
