03-26-2018, 11:44 AM | #1 |
Who should I buy a short block from?
I have a gen III LQ9 with a spun cam bearing. Thinking of buying a new LQ9 short block and moving my heads over.
Who would you recommend buying a short block from? ATK has one for $2399 free shipping? Thanks for the input. |
03-26-2018, 12:42 PM | #2 |
Re: Who should I buy a short block from?
shortblock for 2399? wow...I'd just get a complete pullout engine....and start over..or rebuild what you got....spun cam bearing is usually not detrimental to a block...
03-26-2018, 04:41 PM | #3 |
Machine shop said $500 to line bore and fix can bearing.
Now add clean and hone and deck. Then new pistons, rings, main bearings and installation. I think I end up more than just buying a short block. |
03-26-2018, 04:45 PM | #4 |
did you spin a cam bearing or a crank bearing?......
03-26-2018, 08:42 PM | #5 |
Cam bearing
03-27-2018, 10:44 AM | #6 |
Wow... I wonder how that happens. Debris in the oil that gets into the bearing? Just seems so unlikely that a cam could rotate a billion times over a couple of years and then one day just grabs the bearing!
Why would you need new pistons and all of that? LS motors run a long time... you'd think they could tear it down, fix the cam journal and bearing, and put it back together.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
03-27-2018, 06:13 PM | #7 |
Probaly poor maintenance but according to machine shop it is pretty common. I think truck it came out of had 170,000+ miles.
03-27-2018, 07:15 PM | #8 |
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-27-2018, 07:18 PM | #9 |
03-27-2018, 07:51 PM | #10 | |
ATK does have pretty good reputation and customer service though. Dealt with them commercially off and on for years Dan
Forgive my typos, big fingers and little Android digital keyboard....what a mess 06 GMC Sierra crew cab Z71 DD leveling kit, 34's, bumper, LED lighting. Still doing stuff to it. 67 El Camino Custom 300 Deluxe. In progress. 55 GMC 371 2 1/2 ton. Upcoming project. |
03-28-2018, 09:10 AM | #11 | |
03-28-2018, 10:45 AM | #12 | |
I would think at minimum you will need a cam and lifters, and all bearings/rings if swapping blocks. From there you might need pistons if they are scored and crank work if it is scored or damaged, which at 170000 plus miles with poor maintenance the chances of both of those is pretty high. I'd tend to think at this point you might be further ahead to use you engine as a core at a salvage yard and get a completely different engine. |
