#76 |
Re: '68 C30 Cummins swap
Thanks guys!
I was able to get the slave rod finished, I used 3/8" allthread connectors that I opened up one end 1/2" deep so the slave rods could slip in and weld. Small piece of allthread and two jamb nuts and good to go. Reinstalled the cluster and filled the radiator hoping to fire up but can't find a non AC belt till Monday. ![]()
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
#77 |
![]() Join Date: Nov 2008
I did something similar the first time around but after heating up that garbage material when welding it gets really soft and it ended up getting tweaked when pushing on it with my foot.
I ended machining a rod for it and removing the factory rod from the master. The rod can rest in there, it doesn't need to be clipped in like how it comes. |
#78 |
Your end links and all thread looks beefier so it might be ok.
#79 |
Just looked at your build thread and it seems that you cut the rod on the thinner area where the switch was?
#80 |
Couldn't live with how I mounted the narrowed radiator so I removed the core support and will relocate the factory lower mounts.
#81 |
#82 |
6>8 Plugless........
![]() Join Date: Sep 2007
Very nice! Have you been enjoying the warm weather?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#83 |
Thanks! Been LOVING the warmer weather, was almost 70 last week!
#84 |
Was finally able to fire it up a couple weeks ago! What's a good video hosting site so I can add the vid here?
#85 |
#86 |
Oh yeah, that looks awesome!
#87 |
Thanks Ryan! I need WC SR’s or flip our camper mirrors for it so I can see the back of the box now!
#88 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Looks good and ready to work!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#89 |
Thanks, it’s almost ready to work. Need to fix the gearbox and should be ready to run.
#90 |
Been awhile...it’s on the road but never done!
#91 |
Those buckets look amazing!!!!
#92 |
so that clutch master bracket is the stock dodge piece adapted to your pedals?
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#93 |
Yes, bolted right on.
#94 |
#95 |
Well thanks to photobucket digging their own grave...
If anyone considering a swap needs pics of anything PM me.
