Closed Thread
Old 03-28-2018, 05:51 PM   #6501
66clow
66clow's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by Mts67C10K20 View Post
Is that possible a long bed cable on a short bed
Where the single cable joins the double is there any more adjustment?
Part code seemed to be sb. But I will make sure again everything is in place. But think it may be a LB cable.
66clow is offline
Old 03-28-2018, 05:54 PM   #6502
RodnRudy
RodnRudy's Avatar
Fired the engine for the first time after the rebuild yesterday and today finished everything up by putting the new valve covers and air cleaner on. Now on to pass. fender cup repair and re installing the fenders. Cruisin' season's coming up and I'm way behind.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 03-28-2018, 06:49 PM   #6503
RodnRudy
RodnRudy's Avatar
Originally Posted by 66clow View Post
Installed new springs for the rear brakes. Also installed the e-brake cables. Are theses routed correctly and my cable is too long. If I cut it what should I block the end off with?
In looking at your pics the cable should be running through the outer hole on the cross member, the one with the plastic gromit in it , then up to the curled wire hanger in the frame and then to the back down the other side the same ending at the other bracket that connects the two rear cables. That routing may shorten the cable enough. Hope this helps.
Phil
RodnRudy is offline
Old 03-28-2018, 08:47 PM   #6504
Metaldoc
Metaldoc's Avatar
This is my long bed e brakes
Metaldoc is offline
Old 03-29-2018, 12:24 AM   #6505
StruttinSoul
Originally Posted by stevenfromtexas View Post
dang!! hey there brother from WAYYYY south of you
where/who did your seats????. I am wanting the same style!!!
The seat covers are from Ricks Custom Upholstery
On a separate note, today I installed a jackrabbit original tunneau cover - love the way it looks!
StruttinSoul is offline
Old 03-30-2018, 11:05 PM   #6506
NoStopN
NoStopN's Avatar
I ordered some LED headlights on Monday & they arrived today. I was able to get one of them installed. Rusty screws held the other 3 up. Lol.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 03-30-2018, 11:12 PM   #6507
stevenfromtexas
stevenfromtexas's Avatar
front grill/bumper.....rear and front today.
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline
Old 03-30-2018, 11:21 PM   #6508
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Washed windsheild,wheels,tires,armor alled tires. Going to LEATHAL PERFORMANCE and DYNO open house in Jefferson City,TN.Looking for highest rear wheel HP! Probally have to be over 600RWHP to win.Speciallization in LS motors.Might get to see a Mustang blow the hell up!
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline
Old 03-31-2018, 12:28 AM   #6509
Metaldoc
Metaldoc's Avatar
Ceramic coated my exhaust manifolds and pulled all the lettering stickers off. Looking like it should for shiny side down truck.
Metaldoc is offline
Old 03-31-2018, 01:57 AM   #6510
69BUCKET
Radiator, shroud, fan, power steering lines, trans. Lines, torque converter bolts...
69BUCKET is offline
Old 03-31-2018, 08:25 PM   #6511
RodnRudy
RodnRudy's Avatar
Decided to tackle the rusty fender up today. I tried a different way to make the repop cup fit by lining up the wheel opening side then using a spot weld cutter I removed the piece on the rear of the cup and made relief cuts to "stretch" the front of the cup. More pics to follow
Phil
RodnRudy is offline
Old 03-31-2018, 08:30 PM   #6512
RodnRudy
RodnRudy's Avatar
I had to make one relief cut on the front of the cup to move it over and add a small piece of filler to the gap. Every thing lined up and time to start tack welding.
Phil
RodnRudy is offline
Old 03-31-2018, 08:39 PM   #6513
RodnRudy
RodnRudy's Avatar
By using this method I eliminated weld seams where they would show. I replaced the rear piece previously removed and finished up by grinding the welds, slinging on some filler, blocking and shooting primer. Tomorrow I'll wet sand the primer and rattle can some color to finish up the repair.
Phil
RodnRudy is offline
Old 03-31-2018, 11:05 PM   #6514
1968aj
today I installed new carpet , new retrosound laguna radio,and my $20 swap meet seat. also put a set of undercover 2 speakers. retrosound doesn't tell you assembly is required and instructions are not model specific. after many adjustments I finally got it in and I am pleased with the sound. I removed my factory bucket seats for my other project.
1968aj is offline
Old 04-01-2018, 12:11 AM   #6515
KQQL IT
At the body shop.
KQQL IT's Avatar
Drove ole reliable to get parts for my 99 that ate a fuel pump.
KQQL IT is offline
Old 04-01-2018, 06:48 AM   #6516
66clow
66clow's Avatar
Beautiful work and thanks for the tutorial!
66clow is offline
Old 04-01-2018, 09:07 AM   #6517
stevenfromtexas
got a few things in yesterday. side mirrors are on and the tricky fender emblems
disregard the oak pollen its everywhere right now
Steven
Old 04-01-2018, 02:08 PM   #6518
mosel70
Starting priming using Eastwood's Contour polyester filler-surfacer.
'70 Chevy C10
mosel70 is offline
Old 04-01-2018, 05:46 PM   #6519
OregonNed
OregonNed's Avatar
Painting brake drums and giving the wheels and tires a good cleaning.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 04-01-2018, 07:01 PM   #6520
RodnRudy
RodnRudy's Avatar
Sanded the primer on the fender cup and shot some Dupli Color on it. Doesn't match but it's down low and doesn't look too bad. After all she's a beater driver! Oh, and I got the left fender hung too.
Phil
RodnRudy is offline
Old 04-01-2018, 08:52 PM   #6521
NoStopN
NoStopN's Avatar
I spent yesterday driving mine to get & return parts for my '02. That's the most driving I've done in it since the day I bought it.
NoStopN is offline
Old 04-04-2018, 09:20 AM   #6522
beaterku
beaterku's Avatar
Finsihed up bolting together the rear frame and started setting up the brakes.
beaterku is offline
Old 04-04-2018, 09:32 AM   #6523
Metaldoc
Metaldoc's Avatar
Did you add some fade to the paint? I used to tell customers that I'm not able to match the old paint because they don't make "fade" to age it.
Metaldoc is offline
Old 04-04-2018, 11:39 AM   #6524
toolboxchev
I am working on that concoction. It takes years of research, driving in the rain, long days in the sun. Opp, better check the oil!
toolboxchev is offline
Old 04-04-2018, 10:34 PM   #6525
3757chevy
3757chevy's Avatar
I didn't do it, but I paid to have it done. I had a new windshield installed while I worked. My daughter had her '11 impala done at the same time.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Closed Thread
