Old 06-17-2017, 06:15 PM   #101
ghalperin
ghalperin's Avatar
Re: 67 Plain Jane C10 396 build
I installed the front bumper and Marchal Amplilux French Headlights.
ghalperin is offline   Reply With Quote
Old 06-26-2017, 12:35 AM   #102
Jason7121
Jason7121's Avatar
It was very nice meeting you today at the brothers truck show. You have a great looking original truck and have got alot done in just a few months.
Jason7121 is offline   Reply With Quote
Old 06-26-2017, 07:07 AM   #103
drfloyd
I have a 72 12 bolt that I will likely never use. Is that 2.76/1 gear ratio common for those trucks or was it specific to the Saginaw transmission? I think the one I have was behind an automatic which I suspect will be a 3.11 or something lower.
drfloyd is offline   Reply With Quote
Old 06-26-2017, 10:26 AM   #104
ghalperin
ghalperin's Avatar
I really don't know much about the 2.76/1 gears. I thought I was buying 3.07/1. You should start a thread, someone else would know.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
Old 06-26-2017, 10:27 AM   #105
ghalperin
ghalperin's Avatar
Likewise, thanks for checking out my truck.
Glenn
Old 08-16-2017, 05:31 PM   #106
ghalperin
ghalperin's Avatar
I've been driving my truck almost daily. So far, so good.
Glenn
Old 08-16-2017, 05:51 PM   #107
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Really liking your truck. You must love driving it.
How about a pic of your buggy. Never heard of that make.
Tom Vogel is offline   Reply With Quote
Old 08-16-2017, 06:04 PM   #108
ghalperin
ghalperin's Avatar
Thanks. I've hauled several motorcycles, small refrigerators and been to Home Depot numerous times. I really love driving it.
My Burro is in storage, but it looks like this except it has two bench seats and the panels are raw aluminum:
Glenn
Old 08-16-2017, 07:22 PM   #109
rustytruck50
rustytruck50's Avatar
Lookin' good!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 11-08-2017, 10:59 PM   #110
ghalperin
ghalperin's Avatar
I picked up an AGR Power Steering Gear Box. I found it in the used parts board here for a great price and thought it was cool. It's brand new. Maybe it'll help my truck handle like a sports car.
From AGR's web site:
This Super Box 2 steering gear box is nearly identical in design, performance, and brute force to the Super Box 1, but they're engineered for the vehicle used as a daily driver. They have a firmer valving and appropriate ratio gearing for better handling and drivability at highway speeds. The ratio is the 16/13:1 with the 4 finger feel and 3.3ish turns lock to lock.
Glenn
Old 04-17-2018, 01:11 PM   #111
KevinK7
KevinK7's Avatar
Interestingly enough, for an older thread I've got a question where you left off... Power Steering : )
First, what an awsome build, the truck looks fantastic.
I see you have Power steering on the 396. What mounts did you use for the reservoir? ...they appear to be factory GM mounts (ie. Chevelle?)
Thanks,
Kevin
KevinK7 is offline   Reply With Quote
Old 04-17-2018, 03:32 PM   #112
ghalperin
ghalperin's Avatar
That is the 68 only 396 truck power steering reservoir bracket. It’s very hard to find and I paid too much for it. The bracket is supposed to be mounted on the fender, but I didn’t like the way it looked there, so I mounted it closer to the power steering pump
Thanks,
Kevin
Glenn
Old 04-17-2018, 03:38 PM   #113
KevinK7
KevinK7's Avatar
My mistake, ...I meant PUMP brackets (those on the block) that mount the pump.
I didn't even notice you had the remote reservoir, ...so you are running the reservoir-less pump?
I just got done doing over a '68 Camaro 396 and wondering why I couldn't use similar brackets. It's a whole lot tighter in the Camaro bay.
Old 04-17-2018, 04:05 PM   #114
ghalperin
ghalperin's Avatar
Those are the stock 69 396 brackets as used on a c30.
Glenn
Old 04-17-2018, 04:58 PM   #115
STICKBNDER
Attachment 1705986
how do you like the steering box?
STICKBNDER is offline   Reply With Quote
Old 06-26-2018, 11:45 AM   #116
ghalperin
ghalperin's Avatar
Brothers Truck Show & Shine 2018
Glenn
Old 06-26-2018, 04:00 PM   #117
dagnabbitt
dagnabbitt's Avatar
Does your truck actually have heater delete on the SPID? I've never heard of that! Would you share a pic of the SPID?
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-26-2018, 04:07 PM   #118
ghalperin
ghalperin's Avatar
Here’s my SPID. The only option is a delete.
Glenn
Old 07-03-2018, 11:29 PM   #119
Steeveedee
Who Changed This?
Steeveedee's Avatar
Attachment 1796340
It's an option because starting in about '59, vehicles were required to have a heater (and thus, defroster). I worked for a repair shop in '76 after I got out of the Navy, and the boss had a '58 Ford wagon without a heater. It was raining, and the windows were fogged up, so I had the driver's window down to let the car air out, when another car came by and splashed water into that car. I had to get a greasy shop rag out of my back pocket to wipe the windshield on the inside so I could follow him to the customer's house and take him back to the shop. It wasn't funny at the time, though.
~Steven
Simi Valley, CA
Old 04-02-2019, 08:12 PM   #120
Mainlymidyears
Was lucky enough to buy this outstanding truck from Glenn a few months ago with a few things to finish and some plans of my own...
I had a really neat shortbed fully polished vintage camper shell, but built for a stepside. So I was literally looking for a gangster window shortbed stepside hotrod patina truck to put under it when I found this one.
So far, ...and just because I have always wanted to run this set up, I have changed the wheels from all 6 inch to staggered 6/7 inch in all black (copo style), reversed the white walls and shrunk the front tire size down to 205/75's.
I was hoping to get the original Camper mirrors that came off the truck earlier in the build, but they had been sold. Couldn't believe my luck when I found the original period aftermarket NOS, NIP set on ebay. Only set I have seen before or since! Didn't even have to drill new holes.
Now it's time to really get to work. Need to install the new bed floor, finish the linkage on the T10 overdrive, and plumb the new blazer tank.
Thanks Glenn, awesome work.
And thx for the subscription 67-72chevytrucks.com.
Derek (new to the board, but not to C10s).
Mainlymidyears is offline   Reply With Quote
Old 04-02-2019, 09:15 PM   #121
68bowtie
68bowtie's Avatar
Cool. Subscribed to see how it turns out. Awesome truck to begin with!
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 04-02-2019, 09:32 PM   #122
KevinK7
KevinK7's Avatar
I just love this truck . ...shortbed 396, ...patina, ...just so cool
Old 04-02-2019, 10:30 PM   #123
nds1968
nds1968's Avatar
Nice buy, keep us posted with updates.
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 04-03-2019, 02:40 PM   #124
jcramsey
jcramsey's Avatar
Love this truck! Gonna look good with the camper on it!
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 04-05-2019, 02:35 PM   #125
weim55
Your camper shell in the background looks pretty neat! Is that all stainless steel? I followed the thread of the build for your truck and really enjoyed it. Have fun with your new ride! I have to ask, what are gangster windows (??)
Steve weim55 Colorado
weim55 is offline   Reply With Quote
