Old 04-16-2018, 09:28 PM   #701
longbed67
longbed67's Avatar
Re: Project: Turbo 250
Engine: 91.5 12 valve fully rebuilt balanced within 1 gram, stock bore, stock compression with the .010 head gasket,pistons fully coated ceramic top moly side ARP everything
Cam: Hamilton 182/214 with matching valve train with Smith bros push rods (was told by hamilton, good for 100 # of boost up to 5k rpm)
Fuel: New old stock VE pump with 3800 spring, THD Pin, M&H timing spacer, 6x.013 VCO Bosch injectors from THD, 2nd gen fuel pump upgrade from THD, stock high pressure fuel line diameter
Trans: NV4500 fully built and cryo treated by midwest trans
Clutch: American Powertrain highpressure ceramic single disk rated for 850 lb ft at 20k lbs towing
Exhaust: 4" 409 stainless mandrel bent turbo back straight pipe
It will be running compound turbos of a HE351CW wastegate bored to 1" secondary over a S475 with 1.15 turbine housing primary
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 04-16-2018, 09:34 PM   #702
longbed67
longbed67's Avatar
Motor/ trans is capable of putting some serious power to the ground (over 1000hp with the propane injection secondarys) but will be keeping it de-tuned to keep it clean and see what kind of fuel economy I can get. Going to shoot for around 400hp and 850 lb ft of torque
Adam
(608) 214-8706
Old 04-17-2018, 10:33 PM   #703
mjensen
mjensen's Avatar
Is it done yet? Sounds like a great powerplant!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 04-18-2018, 03:28 PM   #704
clay68c10
clay68c10's Avatar
That’s gonna be stout!
What about the 4bt wasn’t working for you? Not enough power?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-14-2018, 11:44 AM   #705
hotwls13
Originally Posted by longbed67 View Post
Also got the Curt Class IV hitch installed today and mocked up the rear bumper and brackets. It is the perfect height with my Class IV adjustable receiver.
I'm thinking of getting the Curt 14082 hitch for my 70 LWB 1/2t GMC. I will be using the sport bumper.
Do you have any pics with the flip up license plate and receiver hitch installed??
My bed is off right now (and also the bumper/brackets). It would be easier to install the hitch now, but I think it would be better for alignment if I wait til bed/bumper is installed.
You had to drill the 6 holes correct? Also, was the hardware provided sufficient?
Lastly, where did you get the flip up license plate holder?
Thanks,
Beautiful truck btw
hotwls13 is offline   Reply With Quote
Old 05-15-2018, 09:42 AM   #706
68Gold/white
Job well done!!!
I've always thought a Cummins would be cool in a street driven pickup. A friend had one in a 3/4 ton. He took out the original 6.2.
68Gold/white is offline   Reply With Quote
