Old 03-13-2018, 10:14 PM   #551
sdwolff98
Turning Wrenches Daily
Re: 1964 GMC 3/4 ton build :D
Got the tap shift board and usb power circuits mounted to the face panel just need to acquire my trans temperature gauge soon so it will be all complete.
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 03-14-2018, 12:34 AM   #552
Captainfab
60-66 Nut
Dayaaaaaammmm!
Originally Posted by sdwolff98 View Post
Captainfab ooohhhh yeah a grand for a new set from summit like these I got just happened to be at right place and time.
Sean
Old 03-14-2018, 12:43 AM   #553
sdwolff98
yeah love the specs on them 3 1.81 inch pistons in each caliper. the fronts that match them have 3 2 inch pistons
Sean
Old 03-17-2018, 11:03 AM   #554
sdwolff98
Well there was no other recourse lol kept loosing track of where I was putting some of my smaller project pieces and parts lol so went in and cleaned all of the drawers out sorted the trays and labeled the danged drawers. Finally can keep track what tray is where now lol.
Sean
Old 03-17-2018, 11:07 AM   #555
sdwolff98
Also got around to getting the bed off the 60's frame out back and placed it on a dolly. Disassembly is going well just have to finish cutting the rear bed welds to get the bedsides completely loose then it will be ready for sand/water blasting and ready to primer and paint. Some minor body work will be needed on the passenger side thanks to homeless people throwing stuff in the bed and banging up the sides :/
Sean
Old 03-17-2018, 12:34 PM   #556
sdwolff98
Well also got the e brake buttons in got lucky and found an autoloc kit on amazon and ordered not badly priced either complete with aluminum bezel 2 switches and 2 plug harnesses. Also linear actuator is in and sitting in a drawer ready to go. I need to look at how to mount it to the trans cross member but that''s just a lil issue to deal with in over all scheme of things
Sean
Old 03-26-2018, 07:18 AM   #557
sdwolff98
getting it closer to fully aligned. passenger side is dialed in and marked for drilling passenger side just needs a tad bit of out fender pressure to line right up. gonna be nice when finished
Sean
Old 04-14-2018, 06:41 PM   #558
sdwolff98
Well been busy working on little projects and gathering more stuff lol. I found that hot wheels at some point released 60-66 key chains lol so I got me one recently and put my truck keys on it lol. Also got the alternator in and mounted to the truck waiting on the AC compressor as well at the moment. Plus got the american billet hood hinges in and currently in the process of getting them mounted and checked out.
Sean
Old 04-14-2018, 06:44 PM   #559
sdwolff98
here is the alternator lol. Also picked up a tool for my buddy who is looking at building me a in bed gas tank cover made of matching oak with chromed bed strips to match the bed. It cuts the channel on the edges of the bed boards like the factory did. Also picked up a new larger compressor I am currently getting wired into the shop and ready to go for some projects that need more CFM then my lil shop compressor can handle. And lastly saw this bad ass engine cover a guy made with an old rotted out hood
Sean
Old 04-29-2018, 11:00 AM   #560
sdwolff98
well now that I got a compressor up n running with bigger lungs lol started sanding and restaining the bed wood to get it ready for the clear coat eventually. Got 3-4 more boards to finish then get clear coat in to start coating em down.
Sean
Old 04-29-2018, 11:07 AM   #561
sdwolff98
Also working on getting the engine ready to fire up and dealing with lots of little issues lol mounting the maf 4inch tube to big 3.5 inch tube to small grrr!!!!!! starter is mounted and ready to go, belt mounted up with accessories in place, new sensors all around. Just need radiator and hoses in place and a battery with a flip switch to start it up. that wake sure everything is gonna work properly lol. Still have to get the core support holes drilled and mounted again. Also hooking up the trans thermostat to the cooler as well.
Sean
The second picture is how the MAF issues has got me feeling today
Old 05-06-2018, 12:40 PM   #562
sdwolff98
Well getting further along on the bed wood its all sanded down and restained and looks much better now will be starting on the marine clear coat varnish tomorrow afternoon. More posts to come on that. Also got the wiring in for the battery starting and charging circuits and quite pleased with how it is coming along.
Sean
Old 05-06-2018, 12:42 PM   #563
sdwolff98
Here are pictures of the charging, starter, and fuse box power cables. found some neat tri way battery feeds through knu conceptz website.
Sean
Old 05-06-2018, 12:43 PM   #564
sdwolff98
more pictures
Sean
Old 05-06-2018, 11:23 PM   #565
Captainfab
60-66 Nut
Lookin' good Sean
Where did you find that mega fuse holder? I like that one better than the typical ones I have seen with the phony rubber cover.
Old 05-07-2018, 12:42 PM   #566
sdwolff98
Hey Captain,
Here is a link to them: https://www.mouser.com/ProductDetail/576-02981003ZXT
10 bucks for them at mouser not a bad price. The chevy police editions also had a 3 bank model of them as well.
Sean
Old 05-07-2018, 11:52 PM   #567
Captainfab
60-66 Nut
Thanks Sean
Old 05-25-2018, 02:44 PM   #568
sdwolff98
Well after futzing around and going back on forth between bench and truck got the lower heater and defroster valve in place on the truck. took a bit of contrapting to keep the hoses clear of all the belting stuff lol.
Sean
Old 05-25-2018, 02:47 PM   #569
sdwolff98
Also over last few weeks been working on the power cable setups and how to manage the multiple power feeds running through the engine compartment. At this time its 90% done. Still debating on using the clamps you see in the pictures versus a setup I found that uses plastic insulation inserts still looking at both options right now.
Sean
Old 05-25-2018, 02:55 PM   #570
sdwolff98
and lastly started getting the battery tray squared away lol have been building it over the past week and its coming out pretty nice. Still have some smoothing and shaping to do the the major weight support leg but quite happy with its turn out.
Sean
Old 05-25-2018, 02:58 PM   #571
sdwolff98
more pics of tray build
Sean
Old 05-25-2018, 03:29 PM   #572
sdwolff98
also got this lil gem in yesterday. 1965-1975 Canadian GMC parts panual hehehehehehehehe going to start looking at some of the few differences in here
Sean
Old 05-29-2018, 04:06 PM   #573
sdwolff98
Well start getting things reassembled and aligned for the body shop to start finishing the pain here soon. and oooohhhhh man the bed is turning out verrrrryyyyy nicely quite happy with this one!!
Aluminum core support is making some progress, battery tray 90% finished.. motoring right along. waiting on some parts to come in guy found that with minor mods a 93 electric window regulator from a chevy van will work in our trucks with a few minor mods will see what it requires and post it up on another thread
Sean
Old 05-29-2018, 11:30 PM   #574
Captainfab
60-66 Nut
The bed floor looks great Sean
Old 06-06-2018, 06:45 PM   #575
sdwolff98
Hey Captain,
Yeah it turned out gorgeous and also found a crystal clear bedliner to coat it with so it should last a long time!
Sean
