Old 05-05-2018, 01:12 AM   #26
Captainfab
60-66 Nut
Re: gm create motor ?
A question I would ask is, is there a warranty if the engine is not installed in a '96-'02 truck or van and if it is not installed by an authorized shop?
Originally Posted by sweetk30 View Post
so do i buy the engine and run it for what it is ?
or do i . . . .
buy the cam and install it then run it and say to hell with the warranty ?
that is the BIG question . . . .
Old 05-05-2018, 06:56 AM   #27
sweetk30
sweetk30's Avatar
yes goes to 12 month warranty .
and i decided to just run it as is no cam swap at this time. K.I.S.S method for now.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-05-2018, 08:38 AM   #28
Kudzupatch
Kudzupatch's Avatar
When you decide let me know, I am debating the same thing.
Thought about putting on a 2 piece cam cover. Running it for a year and when the warranty was out doing the cam swap.
Kudzupatch is offline   Reply With Quote
Old 05-07-2018, 06:53 PM   #29
sweetk30
sweetk30's Avatar
placed my order today . should be here by end of the week at most . only few states away .
Old 05-07-2018, 08:12 PM   #30
PGSigns
PGSigns's Avatar
Look at the timing cover when you get it. Seems to me it needed a plug in the bottom and I machined one.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-07-2018, 09:50 PM   #31
sweetk30
sweetk30's Avatar
if so its for the crank sensor position.
Old 05-08-2018, 01:59 PM   #32
truckster
truckster's Avatar
Jimmy
I removed the reluctor on mine (I'm using HEI) and replaced the timing set with a Cloyes double roller. I finished it off with a stamped metal timing cover, just like any other SBC.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 05-08-2018, 02:06 PM   #33
garyd1961
I'm running the factory cam in mine with a Holley carb and headers. I don't see any need for a cam swap, it has plenty of get up and go.
garyd1961 is offline   Reply With Quote
Old 05-08-2018, 06:13 PM   #34
Tom
driving is in my blood
Tom's Avatar
Originally Posted by truckster View Post
But if you buy the L31 engine and the Ram Jet 350/HT383 cam you'll easily get that much power, but it will be in a lower power band and you'll have a roller cam.
So you think that a roller cam that doesn't break the 200*@.050 mark will make the same power as a flat tappet with 15* or more duration? The HT383 cam is lame and tiny. Great for a factory fuel injected engine, way too small to be really worth it otherwise.
Old 05-08-2018, 07:49 PM   #35
truckster
truckster's Avatar
Hot Rod Magazine dyno tested one and came up with 320 HP and 398 ft-lbs of torque:
http://www.hotrod.com/articles/how-t...l-block-chevy/
Old 05-08-2018, 09:35 PM   #36
sweetk30
sweetk30's Avatar
man .................. reading that now makes me want to do the cam swap again .
since its NOT going in a stock 96-00 truck and i am installing it my self . . . i might just say screw it and swap it and to heck with the warranty . . . .
oh the choices .
Old 05-08-2018, 11:18 PM   #37
Captainfab
60-66 Nut
Did you also change the balancer to an earlier one since you removed the reluctor wheel?
Old 05-09-2018, 12:38 AM   #38
truckster
truckster's Avatar
I did. I'll look up the Summit part number and post it tomorrow.
Old 05-09-2018, 02:30 PM   #39
Tom
Tom's Avatar
Put the same headers and 750cfm carb on a 350HO and they get 377hp
http://www.hotrod.com/articles/350-h...ckage-install/
That's a 50hp boost with the non-roller cam.
Old 05-09-2018, 04:10 PM   #40
mattfranklin
mattfranklin's Avatar
I really liked that article. If I weren't building my retro 1970 LT-1, I'd be following their guidance, but with the valve guide mods and a higher lift cam right away.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 05-09-2018, 04:15 PM   #41
mattfranklin
Congrats! Looking forward to hearing how it goes.
Old 05-09-2018, 05:09 PM   #42
garyd1961
That's good but you can get 300 hp and 375 ft-lbs of torque with the factory cam.
Another thing you can do is to swap out the intake rockers for 1.6 rockers and that will boost the hp.
Old 05-09-2018, 06:07 PM   #43
chefk85
chefk85's Avatar
I just finished an L31 5.7 vortec swap. Crate from jegs. Have about 75 miles on it so far. It will roast the tires(which I'm trying not to do until its mnore broken in). Put a 600 cfm summit carb and some cheap long tubes also from jegs. Kept the factory cam. It has plenty of power. Before you do a cam swap try it out. The power is great and has plenty of low end grunt. Only gripe is a slight weeping from where the timing cover meets the oil pan. Hopefully the seals are going to swell a bit and that will stop. Not a leak or anything to worry about at this point. Also for the crank sensor hole on the bottom of the timing cover I used a .075 inch freeze plug. Tapped it in and threw some jb weld over it for good measure. Youre going to love this engine. A huge upgrade from any tired junkyard or original plus roller stuff to boot so no need for special zinc additive or oils. Good luck!
PS are they changing the format of this website? Keep having issues with it and it looks different.
chefk85 is offline   Reply With Quote
Old 05-09-2018, 08:36 PM   #44
sweetk30
sweetk30's Avatar
hay chefk85
what did you do for timming pointer and balancer mark or is there one on it ?
Old 05-09-2018, 11:15 PM   #45
chefk85
chefk85's Avatar
There is a timimg pointer molded into timing cover. There's a mark on balancer. I painted the mark white and when at Tdc it lines up with the pointer. That's 0 Tdc. I installed a msd timing tape with 0 on the tape on the balancer mark. Works great. I got a serpentine system from 98 junkyard vortec motor. You can see the mark and pointer just fine. Paid 100 for the serpentine system with the alternator. Bought a new water pump. If you need any help at all just ask. This forum has been a wealth of knowledge and help to me and if like to pay it forward. Good luck! Only thing I'll add is the alternator moved to the other side of the engine bay but it's not a big deal to run wires and there's some great electrical guys on here.
Chefk85
http://67-72chevytrucks.com/vboard/s...25#post7532025
71 Cheyenne K10. 283/Th350/NP205. 3.07s non posi. 31x10.5 Bighorns.L31 350 Vortec swap in progress.
79 Suburban K20. 350/350. 6" lift. 35x12.5 Toyos.
93 Burb K1500. 350/4l60e Parting out.
2001 Tahoe LT, 5.3, autoride, 265/75s, leather, loaded, family hauler, 243k miles!
Old 05-10-2018, 06:38 AM   #46
Kudzupatch
Kudzupatch's Avatar
hay chefk85
I have been looking at this and I plan on pulling the oil pan and installing a one piece gasket. I know a couple of people that swear by them. I am seriously thinking about replacing the replacing the timing cover with a 2 piece cover. I am looking at the Edelbrock and it comes with a timing marker.
Old 05-10-2018, 02:26 PM   #47
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Good read.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-10-2018, 08:35 PM   #48
franken
There's an engine masters on youtube where they take the lowest GM crate 350 put vortec heads, a cam and intake on it and make power. Sounds similar other than you already have vortecs. Here's a link.
https://www.youtube.com/watch?v=f7mvgf6_p1g
https://www.youtube.com/results?sear...engine+masters
Old 05-13-2018, 12:16 PM   #49
swissarmychainsaw
I'd put the cam in it and run it. It's a NEW SBC, what could go wrong??
Not to throw a wet blanket on this, but I recently acquired a truck with an LS2 with a ... CARB on it.
I love SBCs but I'm not going back. The LS motor makes so much more power, it's just glorious.
And you can do it for the same money... Just a thought!
swissarmychainsaw is offline   Reply With Quote
Old 05-13-2018, 03:19 PM   #50
supercheyenne
Wow how did I not see this thread?
Ordered mine from Ebay on 5/4/18.
Delivery is scheduled for Monday.
The only things I've ordered so far:
Motor 12530283
Flywheel SCA FP-350L-SFI
Intake Edelbrock 2116 (I'm running a Quadrajet)
My plan is:
cam/spring swap and replace the timing cover
Stock exhausts - If I have to replace I'll upgrade to Corvette manifolds
Perimeter bolt valve covers
Of course a fuel pump.
FYI: I've read that you don't have to change the balancer, just use the existing reluctor to make a spacer. I will let you guys know what I find out.
Also note: You need to change the gear on your HEI's. Hardened/machined steel Gears are available. You need to measure your shaft diameter to select the correct gear.
supercheyenne is offline   Reply With Quote
