Old 05-10-2018, 06:46 PM   #1
hotwls13
What differential rear end do I have???
I was gonna replace the differential fluid in my new to me 1970 GMC LWB 1/2t. Don't see a drain plug or a fill plug (are they on the front of the differential?
Can we tell by outside pics what kind of gears etc I have?
My SPID is long gone (previous owner replaced the glovebox with chrome one). Original seat was replaced also so no paper/sheet in the back of the seat.
hotwls13 is offline   Reply With Quote
Old 05-10-2018, 07:09 PM   #2
Mike C
Mike C's Avatar
Re: What differential rear end do I have???
12 bolt truck. No drain plug. Fill plug is on passengers side of case in front of axle tube.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-10-2018, 07:12 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
You have to take the cover off to drain the diff. You can inspect the gears while you are in there.
~Steven
Simi Valley, CA
Old 05-10-2018, 07:34 PM   #4
hotwls13
Thanks guys. That wa s the only pic I had of the truck. After I posted it I figured fill must be on front. So if I have to take the cover off I’m also gonna need a new seal right? Any recommendations as to brand etc? Or just whatever my autozone has??
Old 05-10-2018, 07:50 PM   #5
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Fel-Pro RDS 13391...Any GL-5 MP Gear Lube in the 80w/90 will work...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 05-10-2018, 08:47 PM   #6
hotwls13
Awesome thanks for the details!!
Old 05-10-2018, 10:15 PM   #7
Boog
laying low
Boog's Avatar
turn
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-11-2018, 08:30 AM   #8
Mike C
Mike C's Avatar
Once you get cover off you can get gear ratio from numbers stamped on OD of ring gear. You will also know if it has a limited slip and if so you will need to buy the friction modifier additive.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 05-11-2018, 10:01 AM   #9
Knight72
Op, a factory Lsd will look like this.
72 C10 lwb fleetside aka Big Rhonda.
Still plugging away.
Build thread:
http://67-72chevytrucks.com/vboard/s...42#post8247142
Knight72 is offline   Reply With Quote
Old 05-11-2018, 11:08 AM   #10
Boog
laying low
Boog's Avatar
Turn
Boog
primer is finer
Old 05-11-2018, 11:16 AM   #11
hotwls13
Thanks guys. I'm a total newb at all of this. All of these gears look like drilling equipment to me. Haha.
So, I have a 12 bolt and when I get the cover off, where specifically are the numbers I'm looking for??
Just want to be sure I get all the info I need while in there.
Also, I picked up gear oil (80-90w) and the fel-pro gasket last night. What' proper procedure for putting the new gasket back on?? Do I need sealant as well? If so what type?
Just don't want to make things worse by getting in there and screwing something up.
I plan to take a bunch of pics but don't want to go back in if I don't have to.
Old 05-11-2018, 11:24 AM   #12
Knight72
Numbers in the red block. I don't believe felpro gaskets require sealant.
Build thread:
Old 05-11-2018, 12:09 PM   #13
69 MOD
69 MOD's Avatar
I'm not advocating not pulling the cover but if you jack the rear end up, put it in neutral and make a mark on your driveshaft you can make a very close estimate on gear ratio.
In one full rotation of your rear tire the driveshaft mark will go past 0 point X amount of times (short of 3 turns 2:54, just over 3 turns would be 3:04, 3-3/4 would be 3:73 etc.)
Backyard trick I picked up when I was a kid...
MOD
Chad
'71 GMC 2500 Custom Ol Blue
'72 Custom Deluxe Highlander Stuffed Olive
'73 Trans Am
'13 Silverado 2500 Duramax Storm Trooper
69 MOD is offline   Reply With Quote
Old 05-11-2018, 12:29 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If you decide to use a gasket sealer (I always do, gives me peace of mind), get Permatex 81182 -- it's made specifically for use with gear oil.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-11-2018, 12:33 PM   #15
hotwls13
Thanks again everyone for the tips. I usually drive new/newer vehicles, and usually have the maintenance done by a pro. So intentionally getting into stuff like this is not typical for me. haha
But, I want to know that the running gear is OK before I start driving it around and especially if I put my family in it. A good friend of mine who has been working on vehicles for over 50 years is my mentor and though he is kinda tired of working on them, he gives very good and important advice. He said "check and change the rear end oil" so that is getting done. Figure while I'm in there it's important to find out what I have.
Might be kind of a Duh question but, I'm guessing it's better to change/fill fluid while it's on level ground? Correct? But to see the side of the gear I may need to jack up the rear wheels to spin the gear??
I usually lift the rear with jack under the pumpkin. Should I put the rear on low jacks, pop cover off, drain, ID the gears, put cover back on, then drop wheels on the ground then add fluid?
Also, I've read where some people use a little RTV with the fel-pro gaskets?? Do or don't do that? And if I do, how long should I give the RTV to dry/set before filling with oil?
Lastly, what are the torque specs for the rear end bolts?
Old 05-14-2018, 12:19 PM   #16
hotwls13
Some external pics, hoping to get into the differential tonight.
Old 05-14-2018, 12:43 PM   #17
custom10nut
custom10nut's Avatar
Chiming in. I did this with mine last year, because the gasket failed. A light coat of the permatex will prevent any weeping.
On a side note:
Does anyone know where to get an "S-clip" these days?
We used to get them when I was a kid (like 35 years ago)
The clip will "tighten up" a one wheeler to make a poor man's posi
custom10nut is offline   Reply With Quote
Old 05-14-2018, 02:43 PM   #18
BCOWANWHEELS
forget gasket......... use permatex ultra black rtv. works a lot better as for diff lube use synthetic , you,ll never have to change it again ever. wash rear out with spray starting fluid.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 05-14-2018, 03:17 PM   #19
leddzepp
Moderator
leddzepp's Avatar
Light coat of permatex on both sides of gasket. Let it tack over a bit, then install. Bolts do not need much torque at all, whatever service manual says. I’ve never had a leaking diff cover in my life doing it this way.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 05-14-2018, 03:47 PM   #20
hotwls13
Ok thanks. Don't have a service manual. Did look in the pdf version, couldnt find torque specs for rear end. Friend said not tight, one handed on ratchet close to head of ratchet (if that makes sense).
Old 05-14-2018, 05:37 PM   #21
Steeveedee
Who Changed This?
Steeveedee's Avatar
Bolt torque for the diff cover is specified on page 464. Dana 60 gets 35 Ft-Lbs.
~Steven
Simi Valley, CA
Old 05-14-2018, 06:41 PM   #22
hotwls13
found it thanks. Page 646.
So I have a Dana 60??
Old 05-14-2018, 07:11 PM   #23
BCOWANWHEELS
12 bolt gm
Old 05-14-2018, 11:42 PM   #24
Ironangel
Ironangel's Avatar
No, you have a GM-12T (12-Bolt Truck) What manual are you guys getting page numbers from? My 72 Service Manual dont have page numbers...? 3/8-16 cover bolts get 35 ft lbs, 5/16-18 get 23 ft lbs, and the 1/4-20 cover bolts get 18 ft lbs. Your GM 12T cover bolts get 23 ft lbs. Make sure the cover mating surface is clean and flat, same for the carrier housing. Use a can or two of Brake Clean to spray the inside of the housing clean, dont forget the drip pan. Check your vent while your under there, a clogged vent will lead to seal leaks. Vents located on the top right of the diff housing. Make sure you place jack stands under the axle before you go to work under there. LeddZepp gave a good method for sealing the cover gasket. The Fel-Pro gasket # for the 12T is RDS 13391. "There is no reason not to use a gasket and several reasons why you should"
"Two Seventy Two's"
02 3/4 ton Express
Old 05-15-2018, 12:55 AM   #25
hotwls13
Here are the pics. I've got it all sealed back up, filling it back up tomorrow.
