Closed Thread
Old 05-16-2018, 11:33 PM   #6751
BRL
BRL's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by stevenfromtexas View Post
blew this apart today.....
Took me a second to figure out what I was looking at.
Working on a 68 Camaro with a friend helping out another friend and couldn't figure out whether the timing was off or maybe just carb. problems.
...it was an inconsistent dist.
Carb. filled the whole dang exhaust system up with raw fuel...and then the distributor finally decided to do its thing and light 'er up!
BRL is offline
Old 05-17-2018, 12:05 AM   #6752
BRL
BRL's Avatar
Re: BRL's Bondo & Body.
Originally Posted by BRL View Post
BTW you guys, BRL's Bondo & Body is BACK IN BUSINESS!
BRL is offline
Old 05-17-2018, 12:33 AM   #6753
Metaldoc
Metaldoc's Avatar
i wish i could say i was racing somebody but i can't. not too sure why this happened. it has been running great, even took my little girl for a ride around the block last night. i backed it out of the garage and parked it under the carport so i could do the buff/polish thing. i was stopping for the day and was gonna pull it back in the garage. turned the key and it sounded like a cannon went off!!! i still have some ringing in my ears.....
I would check float levels and see if it's leaking gas after it's off. I just replaced my HEI distributor because the coil and play in the shaft was bad. It would stop sparking and fill the exhaust with raw fuel, spark again , then blow a big bang. I used to turn the key off while driving, load up the glass packs, pump the gas, then turn the key back on and blow flames. Yours sounds like it's leaking fuel into the exhaust after shut off.
Metaldoc is offline
Old 05-17-2018, 12:44 AM   #6754
BRL
BRL's Avatar
Originally Posted by Metaldoc View Post
...I used to turn the key off while driving, load up the glass packs, pump the gas, then turn the key back on...
Wow you are old!
I remember that being done back in high school.
Try that today and they'd think you was doin' a drive-by!
My Goodness...how times have changed eh?
BRL is offline
Old 05-17-2018, 04:45 AM   #6755
Redneck Rydes
Redneck Rydes's Avatar
I remember doing the same thing with my old 71 GMC ,load her up and KABOOM, blew the old Hush Thrushs apart
Redneck Rydes is offline
Old 05-17-2018, 12:23 PM   #6756
bill3rail
bill3rail's Avatar
Looks like someone ignited some fuel in the exhaust system!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline
Old 05-19-2018, 06:05 PM   #6757
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Removed my bench saet and placed my buckets console in the truck. Next step get holes drilled for brackets and get original brace welded underneath the floor.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 05-19-2018, 06:25 PM   #6758
SoCoC10
SoCoC10's Avatar
The bench and the buckets, console look awesome!! Highlander Green Plaid is the best color in my opinion. You have some great seat choices there.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 05-19-2018, 07:57 PM   #6759
wpavlis
Finished assembling my transmission
wpavlis is offline
Old 05-20-2018, 09:38 PM   #6760
mike16
I am installing a factory antenea which requires the removal of the cowl panel. I recommend you buy that rubber cowl gasket and all new hardware when doing this job and cleaning out the kick panel area and the rockers since you will have it this far apart. and also a good time to replace the glove box and its hardware as well
mike16 is offline
Old 05-20-2018, 10:21 PM   #6761
Trackbar
Trackbar's Avatar
Got Power Booster and linkage painted and installed
Trackbar is offline
Old 05-20-2018, 11:33 PM   #6762
OregonNed
OregonNed's Avatar
I finished the installation of an E Brake cover and lower steering column cover. Both were missing in my truck when I obtained it.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 05-20-2018, 11:49 PM   #6763
jojo-munson
jojo-munson's Avatar
Finally got my exhaust manifold off! Just not exactly the way I was hoping it would come off...
jojo-munson is offline
Old 05-21-2018, 06:26 AM   #6764
66clow
66clow's Avatar
Attachment 1786293
Poor manifold! But why, what did he do to you? You couldn't borrow someone's socket? 😆
66clow is offline
Old 05-21-2018, 09:23 PM   #6765
66clow
66clow's Avatar
Transported my freshly painted bug home today from my buddies shop.
Hopefully I'll get to my truck next.
66clow is offline
Old 05-21-2018, 09:35 PM   #6766
Boog
laying low
Boog's Avatar
Looks good. I need a bug to mess with.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 05-24-2018, 10:18 PM   #6767
Trackbar
Trackbar's Avatar
Cleaned and clear coated Park Brake Assembly
Trackbar is offline
Old 05-24-2018, 11:56 PM   #6768
OregonNed
OregonNed's Avatar
Started work on my new shifter install. Working on a template now for the metal work
Old 05-27-2018, 09:12 AM   #6769
HO455
HO455's Avatar
Originally Posted by 71CHEVYSHORTBED402 View Post
At risk sounding like I'm the owner, NO affiliation. That said BIG PROPS to POR-15 engine paint. First time I've done something like this. Some trials, and to be tribulations when done, or so is the plan.
This is after one coat on both pieces, I'll finish the pan tomorrow. The cover may have to wait.
IMO the coat is just as well done with applicators than out of a gun. At least my eyes can't see a difference, and I wore my glasses - for a change. Just as well have been dipped.
Installed a crank seal for the first time as well. I used a thin coat of RTV along the inside. Probably over-kill, but works.
That came out looking sharp!!! Good work and thanks for posting the applicator information.
RIP Bob Parks.
HO455 is offline
Old 05-27-2018, 01:42 PM   #6770
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Thanks....... After using a foam brush for a second coat on the pan, I'm back to using just brushes on the final coat. It's a bit thick for foam applicators larger than 1.5", IMP. I could reduce it, but I don't have "their" reducer and it's not worth the effort.
I'll finish the pan tonight. Think I'll hit the top (technically bottom...ha!) and top edges first, with somewhat a heavy coat. Then work my way down. I'll be sure and post the final results.
For the first hour or so it looks like crap man. Every imperfection revealed. I may have exaggerated brushes Vs shooting, but either way you can't go wrong here. Can't speak for the pan yet, but the cover looks sprayed. Shame I have to sand it
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 05-27-2018, 02:08 PM   #6771
NoStopN
NoStopN's Avatar
I started piecing my turn signal cam & associated parts back together. When I got to putting the brass parts onto the new cam, I noticed one of the springs on the front side had grown legs & walked off. I took a quick look, but didn't find it. Damn field mice will run away with anything that isn't nailed down.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 05-27-2018, 03:05 PM   #6772
Jim Boy
Smile Re: What did you do to your truck today? Chapter II
I hear ya. When old and can't see that well, magnetic tray for the small stuff is the only way to cruise. Make sure you can find the tray! Have a good one eh.
Jim Boy is offline
Old 05-27-2018, 06:41 PM   #6773
1968 baby blue C10
1968 baby blue C10's Avatar
Pulled the steering wheel and tightened the turn signal lever up, lock tighted it. Yesterday on the way to a cruise in Dad said “Aw man I forgot to tell you to honk the horn when we went by her house.” It was someone he knew. Literally as soon as he said that the horn started going off haha. I would love to have seen the look on my face, we just looked at each other and he said “Wasn’t me.” It was slightly comical considering it was a oohga horn. It would only go off in left turns hah. Luckily my switch wasn’t cracked or stripped.
68 C10 long-fleet, Long and low is the way to go. factory: 307 sbc, SM465 4-speed, 12 bolt 4.11 rear end. 75,000 original miles.
Build:Ole Blue
Millennial and can drive stick.
"Too many people have opinions on things they know nothing about. And the more ignorant they are, the more opinions they have." -Thomas Hildern
1968 baby blue C10 is offline
Old 05-27-2018, 07:02 PM   #6774
rjs53
Started on my 4-6 drop from ece. Got the shocks, track bar and springs installed. Figured as long as I'm hear may as well replace the control arm bushings. Tomorrow ill start on the front end.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline
Old 05-27-2018, 08:44 PM   #6775
Steeveedee
Who Changed This?
Steeveedee's Avatar
Set enough 60# sacks of cement just inside the bed at the back to make the mud flaps drag the ground, once yesterday and once today. I have a whole bunch of other stuff in the front part of the bed from the garage so that I can store the rental cement mixer inside, so that it doesn't grow legs overnight. That's a lot to mix up- about 50 sacks. Last time I rented a hopper full and dragged it home, and was done in a couple of hours. This took all day yesterday and half of today. That does include digging the trench, though.
~Steven
Simi Valley, CA
Steeveedee is online now
Closed Thread
