#6751 |
Re: What did you do to your truck today? Chapter II
Took me a second to figure out what I was looking at.
Working on a 68 Camaro with a friend helping out another friend and couldn't figure out whether the timing was off or maybe just carb. problems. ...it was an inconsistent dist. Carb. filled the whole dang exhaust system up with raw fuel...and then the distributor finally decided to do its thing and light 'er up! ![]() |
#6752 |
Re: BRL's Bondo & Body.
#6753 | |
#6754 | |
I remember that being done back in high school. Try that today and they'd think you was doin' a drive-by! My Goodness...how times have changed eh? ![]() |
#6755 |
I remember doing the same thing with my old 71 GMC ,load her up and KABOOM, blew the old Hush Thrushs apart
#6756 | |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
#6757 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Removed my bench saet and placed my buckets console in the truck. Next step get holes drilled for brackets and get original brace welded underneath the floor.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#6758 |
![]() Join Date: Nov 2014
The bench and the buckets, console look awesome!! Highlander Green Plaid is the best color in my opinion. You have some great seat choices there.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#6759 |
Finished assembling my transmission
#6760 |
I am installing a factory antenea which requires the removal of the cowl panel. I recommend you buy that rubber cowl gasket and all new hardware when doing this job and cleaning out the kick panel area and the rockers since you will have it this far apart. and also a good time to replace the glove box and its hardware as well
#6761 |
Got Power Booster and linkage painted and installed
#6762 |
![]() Join Date: Dec 2012
I finished the installation of an E Brake cover and lower steering column cover. Both were missing in my truck when I obtained it.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#6763 |
Finally got my exhaust manifold off! Just not exactly the way I was hoping it would come off...
#6764 | |
Poor manifold! But why, what did he do to you? You couldn't borrow someone's socket? 😆 |
#6765 |
Transported my freshly painted bug home today from my buddies shop.
Hopefully I'll get to my truck next. |
#6766 |
laying low
![]() Join Date: Mar 2001
Looks good. I need a bug to mess with.
#6767 |
Cleaned and clear coated Park Brake Assembly
#6768 |
Started work on my new shifter install. Working on a template now for the metal work
#6769 | |
![]() Join Date: Feb 2016
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#6770 | |
![]() Join Date: Feb 2009
I'll finish the pan tonight. Think I'll hit the top (technically bottom...ha!) and top edges first, with somewhat a heavy coat. Then work my way down. I'll be sure and post the final results. For the first hour or so it looks like crap man. Every imperfection revealed. I may have exaggerated brushes Vs shooting, but either way you can't go wrong here. Can't speak for the pan yet, but the cover looks sprayed. Shame I have to sand it ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#6771 |
![]() Join Date: Jul 2016
I started piecing my turn signal cam & associated parts back together. When I got to putting the brass parts onto the new cam, I noticed one of the springs on the front side had grown legs & walked off. I took a quick look, but didn't find it. Damn field mice will run away with anything that isn't nailed down.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
#6772 | |
![]() Quote:
#6773 |
Pulled the steering wheel and tightened the turn signal lever up, lock tighted it. Yesterday on the way to a cruise in Dad said “Aw man I forgot to tell you to honk the horn when we went by her house.” It was someone he knew. Literally as soon as he said that the horn started going off haha. I would love to have seen the look on my face, we just looked at each other and he said “Wasn’t me.” It was slightly comical considering it was a oohga horn. It would only go off in left turns hah. Luckily my switch wasn’t cracked or stripped.
68 C10 long-fleet, Long and low is the way to go. factory: 307 sbc, SM465 4-speed, 12 bolt 4.11 rear end. 75,000 original miles. Build:Ole Blue Millennial and can drive stick. ![]() "Too many people have opinions on things they know nothing about. And the more ignorant they are, the more opinions they have." -Thomas Hildern |
#6774 |
Started on my 4-6 drop from ece. Got the shocks, track bar and springs installed. Figured as long as I'm hear may as well replace the control arm bushings. Tomorrow ill start on the front end.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
#6775 |
Who Changed This?
![]() Join Date: Jan 2013
Set enough 60# sacks of cement just inside the bed at the back to make the mud flaps drag the ground, once yesterday and once today.
