05-30-2018, 12:48 PM | #1 |
P30 Rims?
I have a 97 motorhome on a Ford chassis. The rims are 10 lug 7.25 inch pattern rims with a 16 inch diameter, which means the biggest tire that will fit is a 235/85/16. That doesn't leave a lot of safety margin on the load rating.
I know that some years of P30 trucks had a 10 lug 7.25 bolt pattern with 19.5 inch wheels. I'd like to find some used ones so I can upgrade the tires on my RV, but I need to know what years of P30s to look at. Anyone out there know what years the P30 had that bolt pattern? Thanks in advance!
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
05-30-2018, 01:02 PM | #2 |
Charlie Daniels w/ a Tq Wrench
Re: P30 Rims?
Not sure of the years on the P30, but I'm pretty sure the 90s-01 GM 3500HD trucks used the 10x7.25" pattern as well in a 19.5. Not sure on the hub bore, might want to check that to be sure as well.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
05-30-2018, 01:10 PM | #3 | |
Re: P30 Rims?
Thanks for the heads-up on the 3500 HDs.
05-30-2018, 02:09 PM | #4 |
Equal opportunity joke ofender
Re: P30 Rims?
Both of my 96 GMC 3500HD have them. I have a whole bunch of extra's but shipping would probably kill it. Here are some pic/ measurements if it helps you out. I come up with 5.25 hub 7.25 c2c lug pattern and 11/16 lug hole
Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
05-30-2018, 02:31 PM | #5 | |
Re: P30 Rims?
How far down the eastern shore are you? I'm right over the border in PA and could really use a spare. |
05-30-2018, 06:46 PM | #6 |
Re: P30 Rims?
I jumped on UPS to get an idea and shipping was over $700 based on an estimated weight. But the information really helps. Thanks.
05-30-2018, 07:16 PM | #7 |
Re: P30 Rims?
Fastenal would be the way to go if you have on nearby. I have used them several times and been very happy
Edit. I see there is one in Orem. I assume you would need 6 of them or 7? I can get a quote if you might be interested. Let me see how many I do have but I think it was 8 of them
05-30-2018, 07:43 PM | #8 |
Re: P30 Rims?
I would definitely be interested. I guess I could get away with 6, since the spare I have is within .02 inch diameter of the tires I would put on these rims. It would be kind of like a space saver spare.
05-31-2018, 06:43 AM | #9 |
Re: P30 Rims?
i will submit for a quote today
05-31-2018, 12:01 PM | #10 |
Re: P30 Rims?
The 19.5 10 x7.25 rims can be found on these units as well
P30 with straight I beam front axle Step vans. GP30HD = G van P chassis HD cut away only built 3 years or so. Class A motorhomes mid 70's until now As a side note these used the Dana 80 & HO110 rear with disk brakes. Thanks
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
05-31-2018, 12:23 PM | #11 | |
Re: P30 Rims?
Yeah, my rear is a Dana 80.
05-31-2018, 12:56 PM | #12 |
Re: P30 Rims?
The ford 450 F super duty with front leaf springs 87-92 ish maybe used 10x7.25 with 5.46 hub bore.
05-31-2018, 02:51 PM | #13 |
Re: P30 Rims?
I'm pretty sure those are 16 inch rims, though. But thank you.
05-31-2018, 07:50 PM | #14 | |
Re: P30 Rims?
Lots of confusion here. The f450 didn't come out until 99. It had 19.5" wheels and a metric lug pattern. Maybe you just mean super duty? I have family that has a 90. 14,500 pound truck. It has the same 16" wheels the OP is trying to get rid of. |
05-31-2018, 08:33 PM | #15 | |
Re: P30 Rims?
