Old 06-11-2018, 10:27 AM   #1
Coach529
Coach529's Avatar
Front Brake Woes......CPP Power Brakes Disc/ Disc
Last fall I started to notice some drag in the brakes after coming to a complete stop......nothing horrible but noticeable. Parked Henry and decided to investigate later.
Finally got around to it this weekend.
Put the front end up on jackstands and had my oldest boy stomp on the brakes and release them.....I could not move the the front tires for 5-6 seconds. Did this test for both sides.
Did the same on the back.....but those spun free immediately.
Any suggestions?
As always up against a deadline......huge car show this coming weekend!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 06-11-2018, 11:51 AM   #2
mikebte
Re: Front Brake Woes......CPP Power Brakes Disc/ Disc
I would remove the master cylinder and check the adjustment on the back side. Most often I have found the booster adjustment pushing on the master cylinder just a touch to much. Take a few turns off and test.
mikebte is offline   Reply With Quote
Old 06-11-2018, 12:10 PM   #3
Coach529
Coach529's Avatar
Thanks, I will give that a shot.
1949 Chevy 3600
Old 06-11-2018, 12:22 PM   #4
mikebte
I don't know why, but sometimes that little knob needs adjusted. Same thing happened on my 08, after 130K miles out of nowhere the brakes started dragging. Needed that nubber adjusted and all was good.
Old 06-11-2018, 12:42 PM   #5
Coach529
Coach529's Avatar
Probably have about 1000 miles trouble free on build, until this came up.
1949 Chevy 3600
Old 06-12-2018, 12:12 AM   #6
Coach529
Coach529's Avatar
Dialed the adjuster in......no change.
1949 Chevy 3600
Old 06-12-2018, 06:43 AM   #7
1project2many
Most folks seem to approach these problems by taking semi-random stabs at it. Testing with a method usually leads to faster success.
I'd be checking for residual pressure. Apply and release the brakes then open a bleeder to see if the drag goes away. It's easier if you have a helper applying pressure to turn the wheel while you open the bleeder. If there's residual pressure the brakes would release very quickly. If I found pressure I would look at which port of the M/Cyl the front brakes are attached to. If they are attached to the rear port I would suspect pedal or pushrod adjustment. If the front brakes are on the forward port I would try to isolate the combination valve as the source of the problem by repeating the first test but opening the brake line at the master instead of opening a bleeder.
If the problem isn't caused by residual pressure I'd look at the caliper slides and pad guides to make sure they allow easy movement.
1project2many is offline   Reply With Quote
Old 06-12-2018, 08:14 AM   #8
mikebte
Bummer, guess as mentioned. Start testing for pressure.
Old 06-12-2018, 01:20 PM   #9
Coach529
Coach529's Avatar
Thank you!!
1949 Chevy 3600
Old 06-12-2018, 09:38 PM   #10
Coach529
Coach529's Avatar
Pressure is being held by the Prop Valve.
1949 Chevy 3600
Old 06-12-2018, 11:26 PM   #11
mikebte
Good diagnosis, hope it going soon
Old 06-12-2018, 11:47 PM   #12
Coach529
Coach529's Avatar
Prop Valve ordered from Amazon......should be here on Thursday!!
1949 Chevy 3600
Old 06-13-2018, 11:39 AM   #13
1project2many
Good job. And the valve is easy to reach so it should be a quick fix.
Old 06-16-2018, 12:34 AM   #14
Coach529
Coach529's Avatar
Prop valve replaced......problem solved!!
1949 Chevy 3600
Old 06-16-2018, 12:09 PM   #15
Black_Sheep
Black_Sheep's Avatar
MiraclePieCo had trouble with his CPP prop valve too. Allegedly there was a “bad batch”
Black_Sheep is offline   Reply With Quote
Old 06-16-2018, 08:37 PM   #16
Coach529
Coach529's Avatar
I had issues when I originally installed this system. The original Prop Valve leaked and was replaced under warranty.
1949 Chevy 3600
Old 06-17-2018, 08:56 AM   #17
1project2many
We love the idea of going "all new" with parts, but I have learned that a used OEM part is sometimes better than a new aftermarket version. Maybe prop valves are going to end up in that category?
Old 06-17-2018, 07:55 PM   #18
mikebte
Great! Hope mine works when I get everything going. Been sitting for 3 months and I have not completed it yet.
