Best way to run return fuel line
As part of my engine swap I need a return fuel line. Is there a different pickup or an unused vent on my current tank I can use?
Thanks!
James 1971 Blazer 350/SM465/NP205 1966 Chevelle 468/TH400 2009 Corvette Z06 built LS7 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Best way to run return fuel line
When I converted to fuel injection I ran the return line down the drivers rail.
There are no unused ports on the tank. I tried using the small vent line that runs beside the large fuel fill tube but that cause fuel filling issue's. I ended up making a "T" that went inline on the fuel fill hose. Worked great. It's just a piece of tubing with a barbed fitting screwed into it. I put JB weld around the barbed fitting just in case. It's never leaked...and it was cheap. I think Jeg's sells something similar though. ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
The ideal way would be to modify the sending unit to have the return in it.
You could buy a new sender and have a welder tig a 5/16" pipe in or whatever size you want in place. There are also pass-through style fittings that you can piece together your system with.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
Perfect, thanks for the ideas guys. I will be dropping the tank to clean it and replace the sender so I will likely go with the modification/welding route. BobbyK, the inline return is pretty slick. Sure saves a lot of work!
