06-09-2018, 11:02 PM | #1 |
Removing Radiator Support Rods
Hi Guys,
Silly question time, but I was wondering if anyone has any experience removing the rods connecting to the radiator support behind the grill on a '58? I'm not sure what they're called. I am looking to add a pusher fan to supplement my mechanical one on very hot days or when stuck in traffic, and I need a few extra inches to fit the one I have on hand. Just wondering if its a terrible idea or not. Thanks a lot, Wylie
Thanks, Wylie '58 Apache 3100 4-Eyed Work Truck |
06-09-2018, 11:20 PM | #2 |
Re: Removing Radiator Support Rods
Someone will get you the exact info as I don't have a 58, but a 48. But I believe they are the same and riveted on. You will have to grind off the head of the rivet and then knock the rivet out of the hole with a punch and hammer.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
06-09-2018, 11:41 PM | #3 |
My '58 has not had that brace for 10+ years, no problem.
06-10-2018, 12:27 AM | #4 |
And I never had them on my 48 since when I bought it in 74.
Brian
06-10-2018, 01:17 PM | #5 |
Cool guys, I figured I'd be ok but its better to check before cutting I've learned. Haha. Time to get out the death wheel then!
06-10-2018, 03:37 PM | #6 |
At worse case you will gain a few squeaks and rattles that you didn't have before. They do take some of the stress off the radiator or it does put a bit more on it when they are gone.
On the other hand we don't tend to drive our fixed up trucks over the rough roads and trails or fields that were the norm for them in their fist life. They may not be as necessary as the trucks probably don't get treated the way they did back then.
06-10-2018, 04:56 PM | #7 | |
Brian
06-10-2018, 07:09 PM | #8 | |
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
06-11-2018, 11:55 AM | #9 |
Good question. I was literally about to remove mine to install an A/C condenser and was unsure of my actions.
06-12-2018, 04:28 PM | #10 |
ok. i'll ask the obvious... do you have a shroud on your fan?
most fan shrouds are long gone by the umpteenth owner fyi this is what a oem tf shroud looks like not sure how a pusher will work with an oem puller it may just block the air in the off position rather than mess with the bracing holding the front end on use a shroud or use an electric puller no oem fan
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
06-12-2018, 04:50 PM | #11 |
"Very true, the engineers didn't put them there because they had nothing to do that afternoon."
That may be true, but it wouldn't be the first time something was added due to faulty science or changing science where we learn things we didn't know we didn't know. |
06-13-2018, 08:52 PM | #12 |
Thanks again guys,
The truck doesn't overheat except n very hot days or if I'm idling for a long time. I bought the electric fan when I went to Fitech EFI so the efi could control the fan and to free up a little power the non-clutch mechanical fan was robbing, but it didn't end up fitting as it hit the water pump pulley by a quarter inch. Anywho, I just had the fan sitting around and thought I might put it to good use. It's already in as of last night and working fine, no extra squeaks I've noticed yet!
