Old 06-11-2018, 04:22 PM   #1
kacy
kacy's Avatar
Vortec 350 ac retro fit
Has anyone swapped in the 96-01 serp brackets and made the AC work?
79 Corvette- 406/7004r Holley EFI
87 V10- 5.7L, Vortec heads, E110026, 410s 35s, 700r4
kacy is offline   Reply With Quote
Old 06-12-2018, 03:27 PM   #2
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: Vortec 350 ac retro fit
I bought a universal hose kit (fittings and hoses) with the compressor fitting from Vintage Air, made up the lines, and had them crimped at a local hydraulic hose shop. You need to 'clock' the hose to the fittings with masking tape and marker if they aren't straight fittings. Also a good time to change your drier and orifice tube.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 06-12-2018, 09:40 PM   #3
JustN
didnt 4.3 use same brackets from 96+? if so 96-13 then i think with better alt probably
JustN is offline   Reply With Quote
Old 06-17-2018, 01:08 PM   #4
bluex
bluex's Avatar
I went to the pull-a-part and got the top section of the hoses from a balzer. Then I had a local radiator shop weld on some crimp fittings so I could run them down and under the radiator.
bluex is offline   Reply With Quote
Old 06-17-2018, 01:33 PM   #5
bluex
bluex's Avatar
I use the AD244 140A from a 2000-2005 suburban/tahoe. It bolts right in and uses the same plug as a CS130D that was normally on these setups
