01-17-2018, 09:50 PM | #1 |
bbc retrofit roller update
Doing a cam swap on my BBC. Would like to get you all's opinion on the combination of parts...
BBC 1970 402 4-bolt block bored out .030 over ( .060 over 396 ) stock stroke piston dome at 10 to 15cc piston deck meets block deck at zero #063 Cast Iron heads, stock valves, 102cc combustion chambers ( may mill a bit ) will be adding long tube headers, 2 3/4 inch tubes dual plane Edel Performer II+ intake 1000 CFM MSD EFI TBI will be adding a 1" carb spacer 700r/1800 stall/3.73 posi compression is between 9:1 and 9.5:1 The cam we have chosen is the Comp xr276hr ( 224/239 Dur @.050, 110 LSA, 1900-5600 RPM: 410HP@5000, 467TQ@4000 ). A close second was the comp xr270hr. With this update, I'm looking for a gain in off the line performance ( may need more stall ) and mid range torque. Fire away please. No parts have been purchased yet, well except for the rocker arms -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-17-2018, 11:33 PM | #2 |
Re: bbc retrofit roller update
Maybe you should call Chris and see what he recommends.
http://www.straubtechnologies.com/ |
01-18-2018, 08:11 AM | #3 |
That’s a big cam for a small motor. Doubt you will have anything down low...
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-18-2018, 01:55 PM | #4 | |
What would you recommend as an alternative, better cam for this pile of parts? thanks, -klb
01-18-2018, 02:52 PM | #5 |
I should retract my statement as i don’t have really any experience with roller cams. I saw the 276 part, I had 274 or something similar flat tappet in a 468 and was a pretty nasty cam. So be even more so in a smaller motor.
01-18-2018, 03:39 PM | #6 |
It’s not always the duration that makes the cam nasty.
Wider lsa’s Will make it less lumpy. Try a cam with 112 or 114 lsa in the smaller bbc. An example of nasty idle is those created by the infamous thumper and motherthumpr cams which typically run lsa’s of 106 to 108 degrees. |
01-18-2018, 06:27 PM | #7 |
Location: Formerly MD and San Diego, now loving life in Arizona
Take a look at the Lunati series of cams. They have a good selection of various profiles that should work well for you and reasonably priced as well.
I put a 60211 roller in mine and it is working well. However, make sure you know all your specs. I gave my builder the wrong gear ratio (was told it was a 3.73 without verifying) and after the engine was built and installed, we discovered it was a 3.07 with a limited slip. My cam doesn't wake up until 2500 or more so what I am dealing with is an ok launch to highway speed, but an engine that wants to really go once I am at highway cruising speed... not exactly what I wanted, not the builders fault, but I will be changing the cam to one of the Lunati rollers that wake up at a much lower RPM. I am not going to change the rear end gears anytime soon as I love the 2600rpm at 70mph.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
01-19-2018, 12:38 AM | #8 |
60-66 Nut
IMO that is too big of a cam for a street driven 402, especially with EFI. I doubt that you will ever get it to run right with that big of a cam with a 110* LSA. I don't know what cam you have now, but that cam will not give you good low end to mid range power. More like mid range to top end.
01-19-2018, 09:51 AM | #9 |
I am not going FI on mine, but I just put together a pair of 427’s. First one I ran the Comp XN273hr which is 224/236@ .050 113 LSA and the second is the XM284hr which is 230/236 @ .050 112 LSA. I wanted extra exhaust duration to try and improve power through iron manifolds.
I know the marine cam is WAY too big for your motor, but for FI consider running the Comp smallest marine hr or the dedicated fi cam they offer. Both the xm and nX series have wider LSA which will help FI. Marine cams in general are easier on valve springs and designed for a smooth idle.
01-19-2018, 01:31 PM | #10 | |
What do you guys think of the xr270hr ( 218/224 Dur @.050, 110 LSA, 1600-5400 RPM: 383HP@5000, 453TQ@4000 ) with respect to my goals? Note the same RPM peaks for HP/TQ as the 276 cam. The HP/TQ graph provided by COMP for these two cams both spin out 350 lbs of TQ at 1500 rpm. Is that just marketing or am I missing something? Now I'm confused! -klb
01-19-2018, 08:52 PM | #11 |
The Comp TBI 266HR roller is 1000-5000 rpm 210/220 on 113 degree lsa. I would think using similar numbers would be good. Does the injection company make a cam recommendation? If so, I'd run that...
The smallest marine cam is the same lobe patterns as your cam you referenced above,218/224, but it's on 112 deg LSA. 1600-5400 there rpm range. That's by far as big as I would go I think and no narrower than 112.
01-19-2018, 09:50 PM | #12 |
My EFI supplier ( MSD ) accepts LSA down to ( and maybe below ) 108 and durations out to 250. At least in the docco.
Quote: "Camshaft Selection There are three selections; Street/Stock, Mild and Performance. Select the cam that best suits your application. Camshaft Selection NOTE: If lobe separation angle (LSA) is less than 108° you may need to go to the next larger cam profile. If cam duration is longer than 250° the Atomic EFI will not be suitable for your application." I'm now leaning more toward the 270 roller cam. -klb
01-20-2018, 09:30 PM | #13 |
Seems like it's hard to go wrong then. Pick the grind you like a burn up the credit card!
01-20-2018, 11:42 PM | #14 |
Just be weary of the lifters you get. Mine were rebranded morels, and they sounded like a sewing machine. Kept getting all kinds of weird answers for fixes and they never quieted down. It drove me crazy I pulled the cam and lifters out and went with Isky.
01-21-2018, 05:19 PM | #15 | |||
I have the Morels as well. They do make noise. My "guess" is that it's the tie bar between the lifters. The original lifters were very quiet but they had the dog bone alignment bars that were not attached to the lifters. The noise initially bothered me but Ive gotten used to it. Could be the Comp Magnum roller tips too. Sounds like the solids on my Singer .....I mean Shovelhead
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
01-21-2018, 06:26 PM | #16 |
I'll be using COMP 854-16 roller lifters ( part of their full roller kit ).
I'v read so many accounts of noise related to these XE/XR ( roller ) cam kits. My machine shop warned me of some noise from the lifter "arms" that attach pairs of them to keep the roller tips properly aligned with the cam lobes. This is something I'm willing to accept for the benefits of the roller. I don't want the dreaded sewing machine clatter that has been reported. If the geometry of the valve train is correct, all the components are correct, clearances are proper and it's all installed right, there's no reason for the rest of the components to make any more noise than a non-roller setup. That is, aside from the harder/faster action of the valves. In many cases, these online forum discussions of noisy retrofit roller setups were resolved by a combination of proper lash adjustment ( sometimes a full turn after 0 lash, sometimes only a quarter turn ), run time and/or faulty lifters/rockers. Most of the discussions were from earlier times like circa 2006 through 2010 for example. Another thing I noticed was that most of the excessive noise Extreme Energy threads I looked through ( random sample from google ) were on small blocks. May not even matter. -klb
01-21-2018, 09:13 PM | #17 |
Mine were installed last year and it drove me nuts. I was told the lash, the weight of the oil, it needed more miles. None of it fixed it. Hydraulic rollers are supposed to be quieter than flat tappets. I haven’t run the engine with the new lifters (they are Johnson ones) but I think a lot of it had to do with how the bbc oiling system works. These Johnson ones are said to do better with less oil. I was told to run lighter oil with the morels, which went against my engine builders recommendations for the rest of the engine.
01-24-2018, 12:53 PM | #18 |
I'm committed now. The expensive bits have been ordered ( xr270hr along with the comp recommended lifters, springs and a set of pro magnum roller rockers ).
-klb
02-15-2018, 02:23 PM | #19 |
Had to lean the grill out about an inch and a half to get the cam out!
Before that, I discovered that a PO had tapped out one of the front main pulley bolts to 7/16 ( the next larger size ). That ended up costing me about 100 bucks because I had to modify the puller I borrowed from AutoZone ( 30 bucks ) and purchase a new balancer ( 70 bucks ) because there's just no way I'm putting the F'd up one back on there! The front cam bearing looks a bit worn but I'm going to assemble the top end back together without replacing the bearings and hope for the best! If I have problems, guess I'll have to pull the block out and freshen it as well then. -klb
02-18-2018, 09:46 PM | #20 |
Looking forward to hearing how it runs! That should be a good cam for your combo I think.
06-15-2018, 01:27 PM | #21 |
Life threw me a curve ball about mid January so I've put all this on hold for a while. Back on it not though. Got the block all cleaned up and ready for assembly.
-klb
06-17-2018, 08:21 AM | #22 |
It has a way of doing that...
Will be watching to see how it comes together.
06-17-2018, 11:59 AM | #23 |
some pics...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 06-17-2018 at 12:14 PM. |
06-17-2018, 11:47 PM | #24 |
My PVC press
06-17-2018, 11:48 PM | #25 |
And the button...
