Old 06-17-2018, 09:25 PM   #1
Rich69shortfleet
Halo headlights in the truck
I put APC halo headlights in the wagon. The halos are xenon and look good at dusk and at night (but you need full headlights at night, so...). The halogens are sealed capsules and look stock and yet provide great light.
I wanted to do halos in the truck but I want to use the halos as DTRLs and the APC xenons just aren't visible in bright daylight. So, I found a Delta light that has a ring of bright COB LEDs as the halo. They are supposed to be really bright halos. The headlights are replaceable H4 halogen bulbs. They are quite a bit more expensive than the APCs but I wanted bright halos so I thought I'd try the Deltas. While the APC lamps are all glass, the Deltas have a glass lens and a plastic reflector back. Not a big deal. The Deltas have a domed lens so look basically stock when off.
The fit was pretty easy but I did have to slightly modify the buckets to clear the large rubber seal they use to seal the H4s to the housing. The Deltas come much more ready to install with a premade harness containing the transformers, a ground wire and a hot lead. They can be wired in any number of ways but I chose to wire them into an ignition-on feed so they power on any time the ignition switch is on. I wired in a small hidden rocker switch so I can turn them off altogether if I so desire. The rim where the lens is joined to the reflector is thinner than on stock sealed capsules, so I had to add a ring of hanger wire to the inside of the headlight rings so the rings will hold the capsules snug to the buckets. Again, not a big deal.
I did find that the halos are much brighter, they provide a very pleasing white-blue glow even in bright daylight. The headlights are very clear and precise with a very clear upper cutoff on the low beam light so hopefully I won't get flashed by oncoming traffic anymore. The high beams are very powerful.
The pictures are in order; halos only, halos and headlights (low beams) and headlights only (low beams).
Rich69shortfleet is offline   Reply With Quote
Old 06-18-2018, 03:46 AM   #2
BCOWANWHEELS
Re: Halo headlights in the truck
Looks kiddie bud imo
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 06-18-2018, 04:34 PM   #3
Rich69shortfleet
Uh, yeah, thanks for all the great input.
I'm just glad to have DTRLs that really show up. Anything that can be done to help those texting drivers notice my vehicle and not pull out in front of me is a bonus in my book.
Old 06-18-2018, 06:33 PM   #4
BCOWANWHEELS
no offence intended. guess I,am just a pureist.
Old 06-18-2018, 11:00 PM   #5
cornerstone
cornerstone's Avatar
Looks way cool Rich. It's a real challenge, but don't mind all the sticks in the mud, otherwise known as "purists", there is no shortage here.
cornerstone is offline   Reply With Quote
Old 06-19-2018, 08:21 AM   #6
Rich69shortfleet
No offense taken.
To each their own. I have bone stock restored cars and hot rods, they are all fun and enjoyable. On the halos, it really wasn't about looks (though I like the looks) I just really wanted some kind of DTRL and these fit the bill with a little extra flair for flavor.
Old 06-19-2018, 11:06 PM   #7
Mollzyie
Mollzyie's Avatar
I think They look pretty cool on your truck man ! I like how u were able to get them to function as drls ... good write up thanks ����
M.A.G.A.
Mollzyie is offline   Reply With Quote
Old 06-19-2018, 11:25 PM   #8
Robznob11
Robznob11's Avatar
Well crap! I guess mine are kiddy too!🤨
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 06-19-2018, 11:50 PM   #9
weq92f
weq92f's Avatar
OP, first time I've seen this on our trucks! Good on you for putting it out there and owning it, yes sir.
I'm thinking that I kinda like it... the halo that is when it is just by itself. The lights look great!
Very cool.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-20-2018, 05:38 PM   #10
elorenzof
The Halo's look Great! Very nice
elorenzof is offline   Reply With Quote
Old 06-21-2018, 08:25 AM   #11
Andy4639
Old member
Andy4639's Avatar
I didn't get the halo's. I got the park & turn signals in the bottom.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-21-2018, 09:31 AM   #12
Rich69shortfleet
Those were an option too, but the ones I saw were halos with the addition of turnsignals as well all in the same capsule.
I like the fog lights!
Old 06-21-2018, 09:45 AM   #13
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Halo headlights in the truck
Everything on the truck is LED except the head lights they are H-4 bulbs.
Old 06-21-2018, 10:14 AM   #14
Rich69shortfleet
Same here.
Old 06-22-2018, 08:45 AM   #15
Custom 68
Custom 68's Avatar
Nice job guys, I like the idea and the look of the Halo lights.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-22-2018, 09:18 AM   #16
JustToxic
JustToxic's Avatar
I've been wondering how those looked on our trucks. Been wanting to put DTRL on mine when I get to that point.
I got a set of LED H4 bulbs off of ebay while back for a different vehicle and really like how bright they are at night. Ebay item number is 263350848213, if anyone is interested in LED's.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
