Old 10-05-2017, 08:38 PM   #501
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Wire wheeling, scraping has been my business lately.
Got the frame mostly clean going over it with one of those paint stripper wheels and sanding to get clean metal. Doing it a section at a time so i can prime it before it has time to rust. Having it sandblasted would have been smarter. lol Also patched a piece of the frame where to p.o. done something torched it beat it something where the auto trans cross member bolts up. I also cut out the left over manual trans cross member ends they didn't remove.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-30-2017, 09:28 PM   #502
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Small update. I finally got the frame cleaned all the way and primed. Working on cleaning the front suspension parts now. In the what was i thinking... I seen the dust shield had some rust holes in it so i decided to make me some patch panels for it. It actually turned out pretty good was kinda a pain though. A little dolly and hammer work and it will be ready to clean up.
Proverbs 3:5,6
Old 02-20-2018, 08:26 PM   #503
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
After the work above on the dust shields i'm getting new. While cleaning them i found more holes. Sometimes i work harder than worth it to save a dime. But anyways i have been busy cleaning the rest of the parts for the suspension/frame. All primed up and ready for warm weather to spray some paint.
Proverbs 3:5,6
Old 05-19-2018, 09:42 PM   #504
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Frame primed and finally painted. Been working alot of overtime so I've been falling behind.
Proverbs 3:5,6
Old 06-13-2018, 06:36 PM   #505
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Springs, trailing arms, rearend bolted up, got me some shock relocaters also.
Proverbs 3:5,6
Old 06-18-2018, 09:02 PM   #506
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
I missed one of the front springs while I was cleaning parts. So I cleaned it and got it primed. Got pass. side a -arms , spring, spindle, bump stop installed.
Proverbs 3:5,6
Old 06-19-2018, 09:37 AM   #507
raggedjim
raggedjim's Avatar
Re: Lime Wife's 67
Don't make it too pretty, you won't want to drive it!
Just kidding, it's looking great. Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 06-19-2018, 07:30 PM   #508
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Don't worry no trailer queens here. (I don't have a trailer anyways ) Just want a clean, reliable, comfortable truck.
Proverbs 3:5,6
Old 06-30-2018, 09:50 PM   #509
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Driver side suspension installed, installed new dust shields ( sorry blurry pic). Installed rotors and painted calipers.
Proverbs 3:5,6
Old 07-05-2018, 04:19 PM   #510
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Calipers, shocks installed.
Proverbs 3:5,6
Old 07-11-2018, 06:57 PM   #511
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Rear shocks installed look good with the shock relocaters, also rear wheels got a rear roller lol. Put the tires on moving dollies for easy moveing. Picture of spare tire winch crossmember I built installed.Frame is little dusty been doing some wood work.
Proverbs 3:5,6
Old 10-14-2018, 08:10 AM   #512
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
When to install my spare tire winch and it doesn't' fit. I must have not checked when i welded in the two middle cross pieces so i had to remove it and cut out the angles. This time i made sure it fit before and after welding i also just used a straight piece instead of the angles looks better to me. Got it painted and ready to install.
Proverbs 3:5,6
Old 10-14-2018, 08:14 AM   #513
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Painted the sway bar and the brackets. Worked on removing the rivets to bolt the brackets in place loosely.
Proverbs 3:5,6
Old 10-19-2018, 07:50 PM   #514
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Sway bar is installed, re-installed my spare tire winch mount and installed the winch. Fits great now, brake lines are probably next.
Proverbs 3:5,6
Old 07-22-2019, 08:18 PM   #515
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Brake lines installed, bought lines for disk brake truck so had to move the bracket for the rubber lines where they meet the hard line. Still need some tweaking, but fit pretty good.
Proverbs 3:5,6
Old 07-22-2019, 08:22 PM   #516
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Been wire wheeling, cleaning the engine. Hopefully some paint soon.
Proverbs 3:5,6
Old 07-27-2019, 10:39 AM   #517
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
After many hours of prep we have paint.
Proverbs 3:5,6
Old 03-28-2020, 06:17 PM   #518
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Cleaned and painted the trans. Got some new mounts and installed both in the frame.
Proverbs 3:5,6
Old 03-28-2020, 07:38 PM   #519
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Started on the cab removed the front and back glass. Thankfully it looks solid, a small spot near the top. Near the same spot where there some pinhole rust spots in the cab.
Proverbs 3:5,6
Old 03-28-2020, 07:43 PM   #520
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Removed the gas tank,before the fireworks started lol. Cut out the spot where the pinholes were and started a patch. Still some tacking grinding to do. Not the most comfortable area to be working I'm a big guy so called it a day enjoyed outside with the kids.
Proverbs 3:5,6
Old 04-08-2020, 11:42 PM   #521
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Upper patches are done, the kick panel had some spots in it so i cut a section out and cut and fitted a patch for it out of replacement one. Passenger side needs done too. The previous owner had the rockers etc done don't know, why they left these. Fixing best way I can.
Proverbs 3:5,6
Old 04-22-2020, 07:21 PM   #522
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
While grinding the patch for the passenger kick panel, the grinder hit the floor and and knocked the paint off . I then noticed it wasn't metal under there but I hit bondo lol. So poked around found several thin spots while I'm here got to patch the floor.
Proverbs 3:5,6
Old 05-04-2020, 09:35 PM   #523
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Floor patch in progress, got it cut out, fitted and started tacking it in.
Proverbs 3:5,6
Old 05-05-2020, 07:41 PM   #524
rowdy11
Re: Lime Wife's 67
That Lime color is amazing!
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 06-17-2020, 10:15 PM   #525
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Lime Wife's 67
Thanks, the wife loves lime green. We both like bright colors, our house walls prove that lol.
Proverbs 3:5,6
