Closed Thread
Old 06-13-2018, 11:11 AM   #6851
Redneck Rydes
Redneck Rydes's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by Metaldoc View Post
How about some smoked pickled eggs, I also made another 10 lbs of jerky. I have a fishing weekend coming up.
Does that fishing weekend involve a trip to The Bay Of Quinte?
Redneck Rydes is offline
Old 06-15-2018, 05:41 AM   #6852
BRL
BRL's Avatar
Created twice the potential fuel & transmission leaks as I had before I started!
Apparently got to the old rubber fuel line just before it turned back into dust!
...can you imagine a rubber fuel line letting go, and coating the entire engine compartment with raw fuel, while you're buzzing down the highway @ 60... right before something decides to light it off!
...blow yer dang hood off for starters, then it will burn your poor little truck to the ground.
Hopefully you got out alright.
Performed a backyard tube job, and now all I have to do is make sure the band clamps stay tight...and probably change several small pieces of 2" rubber hose...um, roughly once a year.
90% hand bent and 10% tube bender tool (can you tell?)... Hey Shuddup! it's working alright!
BRL is offline
Old 06-15-2018, 12:40 PM   #6853
toolboxchev
Do I see toolboxes mounted under the hood or what!
toolboxchev is offline
Old 06-15-2018, 03:32 PM   #6854
Metaldoc
Metaldoc's Avatar
Not this time, I'm up above Havelock at Lost lake, bass hunting. I raising the bar again with 10 hour smoked pulled pork for that trip as well. Bad news on my engine as the crank needs to be ground. So with all the new parts and machining I'm over 1000 bucks again for round two. smoked food heals all wounds.
Metaldoc is offline
Old 06-15-2018, 05:49 PM   #6855
88gtstreetrod
Removed the 20x9 fronts and put 18x8 on to try to give it some more rake...
88gtstreetrod is offline
Old 06-15-2018, 05:56 PM   #6856
Mudflat
Care to share how to make those eggs?
Mudflat is offline
Old 06-15-2018, 06:15 PM   #6857
Metaldoc
Metaldoc's Avatar
boil, cool, and peel eggs. Do not poke or break the white parts, no yokes showing. Warmed my smoker to 80 F ,cold smoke temp, started some apple, hickory, and mesquite chips. Turned off the heat and cold smoked the eggs for ten or so mins. 4 cups vinegar, 1 1/2 tbsp. brow sugar, 4 tbsp. pickling spice, 2 tbsp. sea salt. Bring to a boil and fill jarred eggs. I add a tsp of scotch bonnet hot sauce I make. Seal them up and I( spin the jars around once a day for 5 days at least but a week is better and enjoy.
Metaldoc is offline
Old 06-17-2018, 07:49 AM   #6858
BRL
BRL's Avatar
Yep, I have stereo amplifiers mounted under the bucket seats, so I put the tools and fluids etc. under the hood.
Been rather convenient all these years.
BRL is offline
Old 06-17-2018, 08:07 AM   #6859
Jim Boy
Smile Re: What did you do to your truck today? Chapter II
I think it would be easier to go over to your place and just chow down. I mean you have already done the work eh. If we out here made the stuff and it didn't turn out right, your recipes would get a bad rap and that wouldn't be fair now would it. Just a lovely thought. Happy father's day. Let someone else do the BBQING today. Have a good one.
Jim Boy is offline
Old 06-17-2018, 12:18 PM   #6860
weq92f
weq92f's Avatar
Stabbed the cam!
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline
Old 06-17-2018, 12:32 PM   #6861
Metaldoc
Metaldoc's Avatar
Originally Posted by weq92f View Post
Stabbed the cam!
Roller tip cam?
Metaldoc is offline
Old 06-17-2018, 01:00 PM   #6862
3757chevy
3757chevy's Avatar
Stabbed the cam!
Must be putting that in your '67? http://www.compcams.com/11-422-8.camshaft
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Old 06-17-2018, 04:20 PM   #6863
weq92f
weq92f's Avatar
It's a roller! Going into the '67 along with a few other goodies.
http://67-72chevytrucks.com/vboard/s...d.php?t=755086
-klb
weq92f is offline
Old 06-17-2018, 09:05 PM   #6864
rjs53
Finished plumbing the rear brake line from shortening the frame. Then replaced the cab mount bushings and bolted the bed back together. Was worried what it might look like or if it would line up, but everything worked out. Next is making access to the fuel tank now mounted in the back of the frame.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline
Old 06-17-2018, 11:37 PM   #6865
NoStopN
NoStopN's Avatar
I finished tearing my replacement bed down. After that, I cut the bolts that hold my flatbed to the frame. I would have removed it but I didn't have anything strong enough to hang from the garage roof to remove it.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 06-18-2018, 11:06 PM   #6866
BruceKoukalaka
Just got it home, it was given to me for helping clean up a hoarder's home. It sat for 5 years (at least that's the last time it was plated).
BruceKoukalaka is offline
Old 06-18-2018, 11:53 PM   #6867
rjs53
Lets see it
2003 Dodge 2500
1969 C10
rjs53 is offline
Old 06-19-2018, 12:00 AM   #6868
3757chevy
3757chevy's Avatar
Originally Posted by rjs53 View Post
Lets see it
MIKE
Old 06-19-2018, 12:02 AM   #6869
VWNate1
VWNate1's Avatar
Thumbs up New Rig
Pictures or it didn't happen ! .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 06-19-2018, 12:51 AM   #6870
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Picked this up for my Highlander..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 06-19-2018, 04:15 PM   #6871
weq92f
weq92f's Avatar
Needed a dent in my front cover about a quarter of an inch deep right in the center where the cam sprocket button is. Took a measured swing or 3 with a BFH and an impact socket. Got quarter inch and a fraction more...so I had to beat on the inside of it too!
-klb
weq92f is offline
Old 06-19-2018, 05:22 PM   #6872
BruceKoukalaka
Here are the pics of my truck, it is a '69.
Old 06-19-2018, 05:33 PM   #6873
Metaldoc
Metaldoc's Avatar
-klb
Still clear the water pump?
Metaldoc is offline
Old 06-19-2018, 06:17 PM   #6874
Steeveedee
Who Changed This?
Steeveedee's Avatar
Sitting in line at the CostCo gas station yesterday, by the time I got to the pump the engine temp was about 210º (from 180º running on the road). Put a fan clutch on it today. Used the Hayden 2747 and gained about 1/2" more space from the radiator. The fan is at the front edge of the "tunnel", so we'll see how that works out. The new clutch is a lot heavier duty than what came off.
~Steven
Simi Valley, CA
Steeveedee is offline
Old 06-19-2018, 07:41 PM   #6875
weq92f
weq92f's Avatar
Haven't gotten that for yet! It should as it's the long pump and the cover is dented inward.
-klb
weq92f is offline
Closed Thread
