Old 06-02-2018, 07:06 PM   #1026
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
Here’s one of the lil dude
Alex - Dirty AL "One Piece at a Time"
Follow me on Instagram alex.barr.ios
smokedat is offline   Reply With Quote
Old 06-02-2018, 10:22 PM   #1027
Mjminino
Mjminino is offline   Reply With Quote
Old 06-04-2018, 09:31 AM   #1028
aggie91
I'm just glad to be here!
aggie91's Avatar
Congrats!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-05-2018, 10:42 AM   #1029
LT7A
Congratulations on the new little smokedat!
Old 06-05-2018, 12:23 PM   #1030
Low Elco
Awwwwwwwww.... little feller! Congrats!
Low Elco is offline   Reply With Quote
Old 06-05-2018, 09:00 PM   #1031
smokedat
smokedat's Avatar
Thanks fellas.
Old 06-05-2018, 09:11 PM   #1032
smokedat
smokedat's Avatar
After a 5 month wait she finally arrived in style
Old 06-06-2018, 12:05 PM   #1033
aggie91
aggie91's Avatar
Holy $#I@ that looks beautiful! I bet it cost more than a good portion of my truck...LOL
Karl
The LST Challenge:
Old 06-07-2018, 10:55 AM   #1034
mcbassin
Still Learning
mcbassin's Avatar
Congrats on the new family member!
that steering wheel!
Old 06-23-2018, 11:43 AM   #1035
smokedat
smokedat's Avatar
moving the truck to different location to finish of the final body and paint. Will block it one last time then seal it and paint. I say about 3-4 weeks before we see some color.
Old 06-23-2018, 08:48 PM   #1036
z71se
Had you ever considered having the cab and body parts acid dipped?
77 C10 Silverado SWB - LS Swap, mechanical resto-mod
05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e
z71se is offline   Reply With Quote
Old 06-24-2018, 06:28 AM   #1037
Mjminino
Old 07-09-2018, 10:44 PM   #1038
superdav
I can fap to this
superdav is offline   Reply With Quote
Old 07-10-2018, 12:01 AM   #1039
smokedat
smokedat's Avatar
I have herd of this option but I already went down to bare metal. At this point I just need to block then paint
Old 07-10-2018, 12:02 AM   #1040
smokedat
smokedat's Avatar
Old 07-10-2018, 12:02 AM   #1041
smokedat
smokedat's Avatar
Originally Posted by superdav View Post
I can fap to this
ummm ok
Old 07-10-2018, 12:35 AM   #1042
smokedat
smokedat's Avatar
So I gave her a good blocking panel alignment and gaps and crease lines look great but as expected I had some flaws by the doors, as it got door dings for being in garage that was actively used. In some areas I exposed some metal and in others I exposed some filler. I will spray the exterior only hood, cab, doors, and bed as a surfacer once again with some house of Kolor kd3005 its a DTS surfacer/sealer. There KD 3000 line is all the same the last digit just means the tint, kd3005 is a blue tint. This primer requires an activator hardner. As far as I know they only sell this in quarts so I got 6. I will block her again then spray some PPG sealer.
Once I have the firewall painted I will install the engine just bolt the mounts and the transmission mounts. Then I will hang the front clip and continue with painting the exterior.
First objective after finishing paint is to glass the cab. I got new manual regulators and hardware from LMC, and for the front and rear I’m going with the clear flush fit from one piece products Fesler makes a real flush fit front glass but I think there pricing is off I can’t justify the cost. Another reason I’m kinda leaning toward the front glass from one piece products is because there located 1:30 Hrs away if I pick it up I can save on the shipping which is substantial at around $500 for front and rear. But I do love tha glass from Fesler. As for the door glass I will keep it original with vent window
Old 07-10-2018, 12:45 AM   #1043
smokedat
smokedat's Avatar
First is Fesler second One piece products notice the small rubber seal still allot smaller than stock
Old 07-10-2018, 07:13 PM   #1044
Mjminino
I am waiting for them to make one for my 66
Old 07-10-2018, 08:22 PM   #1045
LT7A
Originally Posted by superdav: I can fap to this
Originally Posted by smokedat View Post
ummm ok
superdav, please find a better way to express yourself. That was probably meant to be humorous and may fly on other types of forums but crosses the line here. People taking the time to let us see their projects should not have to deal with awkward comments like that.
Old 07-10-2018, 08:26 PM   #1046
z71se
I can fap to this
What does "fap" stand for?
Old 07-10-2018, 09:52 PM   #1047
LT7A
With regard to the forum, I'll say it doesn't have anything to do with trucks... At least for most of us anyway. Beyond that, Google can probably help you out.
Old 07-10-2018, 10:39 PM   #1048
z71se
Wow, I learn something new every day. I thought I was familiar with all the slang used these days. Added that one to my repertoire.
Old 07-14-2018, 11:15 PM   #1049
smokedat
smokedat's Avatar
Some parts arrived I got the regulators from Goodmark and the door seals from Precision door sills and a heavy duty dispenser gun from Albion B26 for the heavy weight glass adhesive, since I will be doing the install of all the glass .
Old 07-14-2018, 11:19 PM   #1050
smokedat
smokedat's Avatar
I’m waiting on the vent window seals handles and rivets. I will restore these add new seals handles and paint the frame. I have some PCL flat black from another job Il use for this. Il post some pics of this process.
73c10, c10, cheyenne, ls1, swap
