06-29-2018, 10:06 PM | #1 |
Almost done with my one owner GMC
Almost to the finish line just got A/C, a little tranny work, and bumpers to finish changing out and all bright work. Probably put new carpet inside and sound dampening and new window motors and enjoy. Went with fully built 6.0 LS, Ford 9” with 3.50 posi disc brakes and fully built GM 4L70e and 4” aluminum driveshaft. Yes this will be my daily driver should be fun...
06-30-2018, 12:17 AM | #2 |
Re: Almost done with my one owner GMC
Nice !!!!
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
06-30-2018, 07:09 AM | #3 |
Looks great - job well done! .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
06-30-2018, 07:53 AM | #4 |
Thanks fellas!
06-30-2018, 07:19 PM | #5 |
Wow! Really nice
07-02-2018, 12:53 PM | #6 |
Looks great! What size are the rear wheels? Did you have to modify the wheel tub to get them to fit?
07-02-2018, 06:41 PM | #7 |
07-02-2018, 06:54 PM | #8 |
Very nice.
07-02-2018, 07:43 PM | #9 |
How much drop are you running? It looks great - love the wide rear wheels!
07-03-2018, 10:01 AM | #10 |
I'm liking that one. Very clean looking.
07-03-2018, 10:33 AM | #11 |
Very nice!!
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
07-03-2018, 11:16 AM | #12 |
Love the rear setup.
'78 C10 Build |
07-03-2018, 02:43 PM | #13 |
07-03-2018, 02:43 PM | #14 |
Thanks everyone...
07-05-2018, 06:03 PM | #15 |
SO SO SICK......give us the deets on the tires and rims and are you running both fuel tanks tell us how that is set up............
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
07-06-2018, 02:12 PM | #16 | |
20x13 rears max backspace Mick Thompson 29x15x20 19x9 fronts 245/40/19 tires planning on changing to 45 series Not currently running both tanks but will be this fall probably. |
07-08-2018, 04:48 PM | #17 |
Very nice GMC truck.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
