Re: Tbi vortec swap
GM makes a TBI vortec intake, they are very proud of it though! I've done a few, everything bolts in. I stopped using the TBI braces for the accessories than extend back & bolt to the intake. I think they make the vortec intake gaskets leak easier/quicker. Just my opinion.
Re: Tbi vortec swap
B.w. thanks for your input, did you run the ones that you have swaped without a chip, if so how did they run
Re: Tbi vortec swap
I used Dynamic EFI, EBL Flash (has since become EBL Flash II). You use a laptop to tune, can set up mild to wild.
I think with the stock Vortec cam you might get away with the stock computer but I don't know. |
Re: Tbi vortec swap
I've done this swap and here are a few things I can remember off the top of my head.
It will run like crap on the stock tune. I also use Dynamic ebl flash. Love it. It has a ton of bells and whistles for tuning. Your tbi fuel pump will not be enough psi. I just use am'96 vortec pump. I run about 18 psi fuel pressure. (Compared to stock TBI that was like 11 or 12 psi. So you will need an adjustable fuel pressure regulator or a different spring in stock regulator. Make sure you have a water pump with a bypass hose. Everything from your '87 will bolt to the l31 block. Use GOOD Felpro intake manifold gaskets! I use AC Delco R44LTS spark plugs. If I remember anything else I'll post it.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
Re: Tbi vortec swap
Thanks for the info, i guess i need to find someone to tune it after
the swap is complete |
#6 | |
Re: Tbi vortec swap
You can use an aftermarket intake and buy/build an adapter plate. You will have to fabricate or modify your throttle cable bracket. You will need a new tune, engines are radically different and it's never going to run right with the existing tune. |
