Old 07-06-2018, 07:56 PM   #1
Cadillac Kid
Cadillac Kid's Avatar
1974 C10 A/C Hardline Routing
Hello everyone.
I have finally been replacing parts to get the factory air conditing working in my 1974 Chevy c10. I replaced the compressor with a pro6ten unit, and the condenser with a modern parralell flow unit. What I need to know is where the ac hardlines route once they go through the core support in the fron of the truck. I removed the original condenser when I did the cam about 5 months ago. I should have taken a picture of the hardlines before I scrapped it. Does someone happen to have pictures of the condenser and the a/c lines in the core support area? Or if someone could explain where they run to that would be great.
On my truck there is a line that runs from the bottom of the evaporator and goes through the passanger side core support, makes a 90 bend and then stops. On the drivers side the stock rubber hose from the compressor terminates at the core support. My new condenser has #6 and #8 fittings on the drivers side. I found a hose shop in my town that can make new hoses/lines, but I would like to give them a general Idea of what is going on. And I would like to know myself. Any input, and or pictures are really appriciated.
Thank you!
Keep on truckin'
Cadillac Kid is offline   Reply With Quote
Old 07-06-2018, 10:51 PM   #2
cruizin01
Re: 1974 C10 A/C Hardline Routing
Originally Posted by Cadillac Kid View Post
Hello everyone.
Thank you!
I can't help too much on a 74 as the later 70's ran both out the drivers side for the condenser hookup. Im surprised you found a parallel condenser that was setup that way. i couldn't find one when I was looking.
Checkout my build and scroll to post 66 it pay help you a little for the small lines at the core support.
'78 C10 Build
cruizin01 is offline   Reply With Quote
Old 07-07-2018, 08:17 AM   #3
This may help. This is my 81 and I think it is pretty much the same fro the 73-87. Anyways, on mine the two lines are actually different diameter fittings so they only went on one way. But the upper one goes to the compressor and the lower line from the condenser goes back to the evaporator.
Old 07-07-2018, 11:23 AM   #4
v30crewcab
v30crewcab's Avatar
#8 will go to compressor, and #6 will go the the evaporator.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
1974, a/c, c10
