Old 02-21-2015, 12:16 PM   #1
mpierce9
Hood won't sit flush
I can't get my hood to sit flush near the windshield. I've greased the springs and tried different springs with no luck. I've tightened all the hood spring holder bolts down tight bu for some reason this thing just won't sit flush.
Any ideas?
1975 Chevy Blazer.
mpierce9 is offline   Reply With Quote
Old 02-21-2015, 12:36 PM   #2
rich weyand
rich weyand's Avatar
Re: Hood won't sit flush
Did you lube all the pivot points? Silikroil or spray Lubriplate does wonders, but you have to hit every one of the pivots.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 02-21-2015, 12:55 PM   #3
mpierce9
I've covered it up with lube. I'm happy to try again and see if it helps. I'll let you know.
Old 02-21-2015, 01:12 PM   #4
Titomars
Titomars's Avatar
The hinge to fender mount points are adjustable. try loosening one side and lowering the hinge. But what I see in your picture is bad/bent hinges.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 02-21-2015, 03:10 PM   #5
83swb
Definitely bent hinges, I just bought new hinges for my truck because of the same issue. The cab I'm using was on a truck that was hit, its possible that your hood flew open at one time and bent them. Rockauto sells hinges for about $13 a piece.
83swb is offline   Reply With Quote
Old 02-21-2015, 04:48 PM   #6
Titomars
Titomars's Avatar
The common cause of bad hinges is lack of lubrication at the pivot points. It is also what causes our square body hoods to bend/buckle in the middle.
Old 02-22-2015, 02:47 AM   #7
bilfman
bilfman's Avatar
I had the exact same problem, was worn hinges. Got another set, problem gone. Had nothing to do with lube or adjustment.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 07-08-2018, 10:02 AM   #8
TKCR
TKCR's Avatar
I did some reading on the hood adjusting. Mine wasn’t as bad as the OP, but it was definitely off after putting a NOS hood on the truck. It ended up being a pretty easy fix. Looks a whole lot better. Now off to get some paint in a couple of weeks, FINALLY!!
Old 07-08-2018, 10:10 AM   #9
TKCR
TKCR's Avatar
Loosen these 2 bolts on the the hood, on both sides. Then with the hood open, push the hood up a bit further. This will make the back end of the hood, by the windshield cowl lower. It might take several tries to get the right location. The hood can be pulled forward or pushed back also, to make the hood flush with the fenders in the front.
Old 07-08-2018, 02:37 PM   #10
Bluestep
TKCR, that is a very old thread. Your advice is for '81 and up trucks, the OP's was a '75. They are completely different.
Bluestep is offline   Reply With Quote
Old 07-08-2018, 03:08 PM   #11
Pontiac1976
Pontiac1976's Avatar
just for the heck of it if you want to try this. I assume the original hinges were started to seized when opened. If you still have them and they are not worn out just seized try putting them in a bucket of submerged vinegar. let it sit for 6 hours then rinse with liberal amount PB blaster work the hinges well you may and have to attach them to a 2x4 5-1/2" ft and mount them in a vice. then re-lube
they should come back to life. re try them in the same mounting location.
good luck have fun.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-08-2018, 03:16 PM   #12
Pontiac1976
Oh the 6HR min but could take up too 24Hr's for the vinegar depending on the rust.
Old 07-08-2018, 04:12 PM   #13
TKCR
TKCR's Avatar
I realized it was an old thread, I just didn't want to have to start a new thread if this would help someone else out. Soooo, I guess I'll start one then.
Old 07-08-2018, 05:26 PM   #14
mpierce9
TKCR. I appreciate the feedback on this. I’ll take a look at my setup and see if your approach will help. I know it’s an old thread, but my hood still looks like it did in the original post. Thanks again.
Old 07-08-2018, 06:10 PM   #15
TKCR
TKCR's Avatar
I knew the hoods were different from the 70's to the 80's, but I just assumed the concept of the hinge adjustment would be similar. Hopefully it will help.
Old 07-08-2018, 09:15 PM   #16
truckin 79
The hinge where it connects to fender should adjust that. Loosen the 2 bolts but the 1 closest to firewall is the key adjustment. You want that rear bolt adjuster pushed down almost all the way. Test hood slowly though when making adjustments. It is key to lubricate hinges as well. I use a combo of axle grease and wd-40 on hinges.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 07-09-2018, 02:46 PM   #17
LT7A
TKCR, good work attaching to a previous thread. I routinely read threads much older than when this was initially posted. It puts relevant info in the same place for searches and even reached the OP!
Old 07-09-2018, 03:51 PM   #18
TKCR
TKCR's Avatar
Thank you for recognizing and mentioning that , especially since it was brought to my attention that this was an "old thread". But that's ok, that's why I posted it here, hoping it would help others especially the OP.
Old 07-16-2018, 12:55 PM   #19
nascarmikeb
It helped me out. I have re-installed my hood, "87 GMC r10 and I have too big of a gap at the rear of the hood. I have to figure out the correct adjustment to close that gap.
Mike
nascarmikeb is offline   Reply With Quote
