Old 07-11-2018, 05:35 PM   #1
Bryce80
Bryce80's Avatar
Diff Identification/Gear Ratio Help
Purchased a 1972 K20, digging in to find information on the rear end. Looking for any help on identification. Believe its an eaton, ratio unsure, locked unsure, etc. Been looking for identification with the numbers stamped on the front of the rear diff. Any help?
Bryce80 is offline   Reply With Quote
Old 07-11-2018, 06:30 PM   #2
weq92f
weq92f's Avatar
Re: Diff Identification/Gear Ratio Help
May or may not be correct but...
Looks like that number identifies the carrier.
Have a look at this link:
https://www.venturestruckparts.com/p...ier-ho72-ho52/
...and search for your casting number.
Have a look at this thread:
http://67-72chevytrucks.com/vboard/s...ad.php?t=25777
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 07-11-2018, 07:09 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
This thread I posted back in 2013 might help. See post #8 and #19 for a couple of the code locations used.
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
LockDoc
Leon
Old 07-11-2018, 09:38 PM   #4
Killer Bee
Killer Bee's Avatar
of course, opening it up is most accurate way to determine ratio, locker, etc..
but some external clues may clear up some of it and identify what it was at assembly time..
this thread has some info on Eaton HO52/72
https://www.stovebolt.com/techtips/a...Ton%20Upgrade/
there's a picture in that article of a 'locker tag' that I found on one of mine..
but note, the presence of the tag is the tell, the tag has no stamps or writing on it..
I found a date and ratio stamped in the ring gear..
Old 07-11-2018, 10:15 PM   #5
Bryce80
Bryce80's Avatar
Thank you for the info.
Old 07-12-2018, 05:16 PM   #6
Mike C
Mike C's Avatar
Dana put a tag on all of their diffs that show the gear ratio. So unless someone has removed the tag check your front differential cover. The front and rear must match on a 4 wheel drive, at least closely. For instance if you have 4.10 in the rear the Dana may have 4.09 in the front.
So look for the tag under one of the cover bolts and that should answer the question about what the rear ratio is.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-12-2018, 06:41 PM   #7
Killer Bee
Killer Bee's Avatar
^ great point! that's how I quick checked my K20 and K1500
71 K20 HD44 front
72 K1500 D44 front
