07-13-2018, 10:48 AM | #5526 |
Re: Restoring Rusty
These 10" wheel cribs are nice, too, especially when jack stands only get in the way. But you need a serious floor jack and/or a 4x4 to get the truck high enough.
Of course, a 12-ft ceiling and a lift would solve all my problems.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 07-13-2018 at 11:31 AM. |
07-14-2018, 07:48 PM | #5527 |
Re: Restoring Rusty
You're killing me smallz, I love it! Yeah gotta watch out for the garage door opener box too cause it likes to hit the truck cab, ha ha.
07-14-2018, 07:57 PM | #5528 |
Re: Restoring Rusty
so I pretty much came to realize that when it comes to big parts replacements it's a three day love affair:
Day 1 - disassembly and removal Day 2 - tinkering and chasing parts Day 3 - reassembly and installation So today was Day 2, this means usually lots of hours spent working with not much to show for. I learned that GM likes to make two different bell housings, ones for trucks and ones for cars, the truck ones have a slightly larger input shaft housing hole, my transmission came off of a car so although I could bolt it up to a truck bell housing it wouldn't be wise as the smaller input shaft housings would not properly center the trans on the bell so off with the car input shaft housing Last edited by Gregski; 07-14-2018 at 08:08 PM. |
07-14-2018, 08:00 PM | #5529 |
Re: Restoring Rusty
worth mentioning is that divit / gap for the juices to lubricate the front bearing I recon, this is important as the input shaft housing has to be clocked proper
07-14-2018, 08:05 PM | #5530 |
Re: Restoring Rusty - Saginaw Transmission Input Shaft Housing Part Number 3920738
I did procure a New Old Stock (NOS) truck input shaft housing, yes these are a bit harder to find and I recon less popular
Saginaw 4 Speed Manual Transmission Input Shaft Housing Part Number: 3920738 |
07-14-2018, 08:10 PM | #5531 |
Re: Restoring Rusty
and the mandatory stare and compare of the car vs truck Saginaw four speed transmission input shaft housings
(you notice how I spell stuff out and seem repetitive this is to aid the next generation of Shade Tree Mechanics STMs in their wrenching endeavors and searches on this forum) The Greg is all about giving back, ha ha |
07-14-2018, 08:16 PM | #5532 |
Re: Restoring Rusty
you will note that the truck input shaft housing came with an input shaft seal but not with the big round gasket itself, so we wasted half a day visiting all the local parts houses trying to find one...
this is where The Greg gets bent out of shape when his Pontiac and Mopar friends tell him, Chevy's are easy to work on and you can get parts at your local Walmart! [insert expletive here] so it was time to make our own gasket, using a Fel-Pro part number 3060 gasket assortment kit, thumbs up, using a ball peen hammer and a vice The Greg is most pleased with the result |
07-14-2018, 08:25 PM | #5533 |
Re: Restoring Rusty
after I replaced the input shaft housing the next thing I diddle daddled with was the reverse / backup light switch, mine had one of the blades broken off so I swapped it out with the one from the NP833 trans as they appeared similar in nature
oh and no parts houses had the one for the Saginaw and I tried late 60s / early 70s Camaros, Novas, Chevelles, etc. |
07-14-2018, 08:30 PM | #5534 |
Re: Restoring Rusty
and a stare and compare of the Saginaw 4 speed manual transmission reverse / backup switch and the New Process NV833 overdrive manual transmission switch
07-14-2018, 08:32 PM | #5535 |
Re: Restoring Rusty
and here it is installed, fits like a glove
07-14-2018, 08:37 PM | #5536 |
Re: Restoring Rusty
next I removed and examined the speedo drive, these are color coded and correspond to a cheat sheet that shows you the number of gears / gear ratios etc.
it's so much easier to pop one out off the truck then having to crawl under it and leak gear oil so I decided to do it now after I had it out and cleaned the plastic gear a bit I realized I could tell the color by just looking at the tip while it's installed but prior to the cleanup it was so black and dirty I couldn't tell what color it was, plus this way I could check it for brokerage and cracks etc. those black O rings love to leak, so a trip to my local ACE Hardware store is in my future for some replacement generic thicker ones |
07-14-2018, 08:40 PM | #5537 |
Re: Restoring Rusty
Next I transplanted the transmission mount and was again pleased that it bolted right up and just transferred over - thumbs up for sure
so far this is looking as an easy straight forward swap! New Process NV833 overdrive manual transmission top Saginaw Four Speed Manual transmission below it (one lock washer decided to skip the photo shoot!) |
07-14-2018, 08:43 PM | #5538 |
Re: Restoring Rusty
I realize this is boring, but like I said it's common Day 2 stuff, tons of work and not much to show for
Here I show you that the tail shaft yoke just transfers over as well, this is a dime a dozen TH350 yoke also I would like to add that I wanted to replace the rear / tailshaft seal but none of the parts houses had them locally and although it appears to be the same one as for the TH350 (makes sense as the same yoke fits) it is being transferred from another store Last edited by Gregski; 07-15-2018 at 09:45 AM. |
07-14-2018, 08:45 PM | #5539 |
Re: Restoring Rusty
and that concluded Day 2 Festivities, yes some day I will work on a work bench and not the floor, that day will come!
07-14-2018, 09:27 PM | #5540 |
Re: Restoring Rusty
Good job Greg!
I'm not 100% sure, but a hardware store o-ring may not like gear lube. Wouldn't surprise me if your speedo housing fits lots of different GM transmissions, like Muncie and TH350. So you could probably pickup an o-ring from a trans shop.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
07-15-2018, 09:43 AM | #5541 |
Re: Restoring Rusty
thanks for looking out bud, I will do some research on this, I appreciate it
07-15-2018, 09:57 AM | #5542 |
Re: Restoring Rusty
well it wasn't easy but I got her bolted up, I gotta be honest wichu at 46 years old I don't know how many more one man transmission swaps I got in me (minus a proper 4 post lift and a proper trans jack, ha ha)
07-15-2018, 09:59 AM | #5543 |
Re: Restoring Rusty
here I show you the trick I use to wiggle the transmission into final position once I lift it up with a jack
the stands and 2x4 work great with some tie downs, they only tipped over after it was already bolted up from all the fandangling, it's actually pretty sturdy otherwise peace! |
07-15-2018, 01:20 PM | #5544 |
Re: Restoring Rusty
Hmmmm… 46 and whining already!! Yeah, I've heard the story, "It takes all night to do what you used to do all night", too. But you know what? You get a little gear lube "in yer veins" and you won't quit wrenching. I'm 71, still playin' with my C10 (LSswap), and sure, you may need a little help from friends once in a while, but the smile on your face when the job is complete, is still the same no matter what your age.
07-15-2018, 05:09 PM | #5545 |
Re: Restoring Rusty
A few of us well-over-60 guys were reminiscing about the days when we could lie on our backs and "stab" a Saginaw or Muncie into the clutch & bellhousing without assistance or a jack. Hard to believe those transmissions have become so heavy over the years.
07-15-2018, 06:10 PM | #5546 |
Re: Restoring Rusty
07-15-2018, 06:12 PM | #5547 |
Re: Restoring Rusty
Man I swear up until about 45 I felt like a 20 year old, then as if somebody flipped a switch and my body started to break down, back, shoulder, knee now elbow, and don't get me wrong, I don't smoke, I eat clean and I exercise 6 days a week!
07-15-2018, 06:15 PM | #5548 |
Re: Restoring Rusty
so moving on, hesitated a bit before I had to notch the trans tunnel a bit on this numbers matching, one of 1,365,487 built by all left handed workers, non convertible, non C pillar, factory AC delete trucks - so there goes the concours d'elegance
07-15-2018, 06:21 PM | #5549 |
Re: Restoring Rusty
alright so I'm lovin' the HURST Goose Neck shifter rod, or swan neck you get the idea nice an tall and swoopin' and plenty of clearance (both between the dash and the bench seat)
so I go to put the icing on the cake (aka the 4 speed shifter ball) and the thread on the rod is 3/8"-16 Coarse... but the thread on the darn ball is 1/2"-20 Fine... go figure nothin's easy Last edited by Gregski; 07-15-2018 at 06:28 PM. |
07-15-2018, 06:33 PM | #5550 |
Re: Restoring Rusty
so I jump in my Seven-Fo' and bust a quick one to Home Depot, but they are useless and don't have any 1/2"-20 bolts let alone adapters
so then I hit Pep Boys (always my last choice for anything) but they do have a decent hardware selection so I give them a try that's where I buy this joke of a shifter ball that is so bad I return it the next day, but I just gotta show you what a piece it was... it has no threads its some crazy universal slip on setup that slipped right off the first time I went to grab a gear, when I returned it the guy at the counter didn't even bat an eye just gave me my money back |
