Old 06-28-2018, 07:18 AM   #26
72gmguy
72gmguy's Avatar
Re: Soft Tops For 69 to 72 Blazer
Originally Posted by JDSurge View Post
Hey Guys, I have been searching on the internet for soft tops for my 72 blazer and found several companies that make them,
softopper.com, motorcityk5, and others, cost is $979
Has anyone purchased one of these. They say they are water tight, has fold down capablities, clear side and rear windows. Works in all four seasons. I was thinking about selling my hard top and buying one of these if I can leave it on all year. I only like driving it with the top down but sometimes rain gets in the way.
Let me know what you think.
JD
I purchased one a few years ago from softopper and am really happy with it. It started on my 70 but has since been relocated to my 72. Not water tight around the door glass in my instance but not too bad. Actually works better than I would have thought before purchasing it.
Attachment 1796736
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 06-28-2018, 08:54 AM   #27
JDSurge
I really like that top 72GMGUY. How does it handle when on the road around 60mph? Does it shake bad or anything?
Also, to everyone here, if I decided to sell my hardtop and get this convertible top, does anyone have an idea of how much the hard top would sell for?
Thanks guys, great site.
JDSurge is offline   Reply With Quote
Old 06-28-2018, 07:14 PM   #28
72gmguy
72gmguy's Avatar
Its a great top. No problem doing 60-70mph. A little noisy but very stable.
Jeremy
Old 07-07-2018, 06:09 PM   #29
Vegetta
Vegetta's Avatar
I've got one on my '71 and love it. No problem with interstate speeds. I put a header on that bolts through the existing windshield bolt holes so I didn't have to put screws in the metal. A guy on here makes them out of fiberglass. Rides a little higher in the front but no leaks either.
Vegetta is offline   Reply With Quote
Old 07-11-2018, 10:44 PM   #30
NJKelly
Do you know the guy that makes the fiberglass header? Have any contact information for him? Thanks
NJKelly is offline   Reply With Quote
Old 07-11-2018, 11:13 PM   #31
grillzy
I just purchased one. It now comes with a header bar that you screw into the windshield header- no buttons just a fast track. It fits very nice and flush and water tight there. It also has a bar that runs just behind the driver/passengers head and the top attaches to it via velcro wrap to help prevent flapping. I think it would not flap if I didn't have the hickey roll bar. It does flap some over 50mph on the roll bar.
grillzy is offline   Reply With Quote
Old 07-11-2018, 11:30 PM   #32
NJKelly
A Softopper?
Old 07-12-2018, 10:35 AM   #33
grillzy
yes
Old 07-12-2018, 11:51 AM   #34
NJKelly
Thanks for getting back to me, I'm going to have to check that out.
Old 07-12-2018, 01:57 PM   #35
grillzy
Here is a pic. Top fits very snug and flush with the drip rail. While installing I was like, this ugly alm strip I am going to have to take off and paint body colour. I am 5'8" After install I haven't even noticed it once except when I put the top on. I really don't see the aversion of drilling a few holes that nobody will ever see. The screws they send are stainless. If you are worried about rust there is oil for that. I had snaps up front on my last top. Can't say I like one over the other.
Old 07-12-2018, 03:21 PM   #36
NJKelly
Ok, so you're still making holes in the windshield frame. That's something I have a problem with. I've read some guys have made a modified bar that uses existing screw holes 2 fasten the snaps to, I would love to see pictures of that.
Old 07-12-2018, 03:42 PM   #37
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Me too
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 07-12-2018, 06:16 PM   #38
Vegetta
Vegetta's Avatar
If you get the fiberglass header you wont put any holes in the windshield frame
Old 07-12-2018, 06:26 PM   #39
Vegetta
Vegetta's Avatar
Guy's message board name is robs71k5 that designed the fiberglass header
Old 07-13-2018, 12:07 PM   #40
chevyguy_72
Vintage Evil
Yep and its a nice piece... but its pricey... and im not a huge fan of fiberglass... if there is a metal solution im more game... If Robs piece is the best option thats what i'll get...
Current Rides:
Old 07-15-2018, 03:37 PM   #41
Blazerowner
Blazerowner's Avatar
I made one for about 20-30 bucks using steel stock. I don’t have a picture when I made it but it was pretty easy to make. It’s two separate pieces and then I just screwed their aluminum header on to connect them. You can see it under the header. If you can weld it’s a fairly quick job.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 07-15-2018, 05:42 PM   #42
NJKelly
Originally Posted by Blazerowner View Post
I made one for about 20-30 bucks using steel stock. I don’t have a picture when I made it but it was pretty easy to make. It’s two separate pieces and then I just screwed their aluminum header to the connect them. You can see it under the header. If you can weld it’s a fairly quick job.
Looks great, I like the way you use the visor holes
Old 07-16-2018, 02:12 AM   #43
Blazerowner
Thanks, that was my goal. I wanted to bolt it on using the original top mounts.
Kirk
Old 07-16-2018, 10:08 AM   #44
NJKelly
I wonder if you could use that JB Weld stuff to join the pieces together?
Old 07-16-2018, 11:17 AM   #45
simicrintz
Don't think it would matter if it is 2 pieces or one. I run a soft top on my Jeepster occasionally and used the 2 piece system with no issues. Shouldn't be any different on these rigs.
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 07-16-2018, 01:14 PM   #46
chevyguy_72
Vintage Evil
Good Job... nice work
Current Rides:
