Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-18-2018, 12:13 PM   #2951
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/26vce8U]20180718_102107
Weii, it's not 1/4-20
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-18-2018, 12:28 PM   #2952
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
I’ll be home Friday and get one of mine out will see what it is .....memory says pan head philips
zicc1835 is offline   Reply With Quote
Old 07-18-2018, 02:09 PM   #2953
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: PO has me PO'd
Jim
They are 1/4" pan head sheet metal screws 1/2" long.
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 07-18-2018, 08:33 PM   #2954
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
good answers guys, good thing i didn't try to thread that 1/4-20 in. Now on the hunt for screws. OK, found some, at least I have a sample.
Thanks for the direction and time Guys. May have to post up a WTB in the classifieds or Fastenal
good memory Jess
SAFETY FIRST
AS usual, off topic
Jim
Old 07-18-2018, 08:42 PM   #2955
richard2717
Re: PO has me PO'd
Jim
I have a few extras if you need 2. Pm me your address and I will get them out tomorrow
Richard
Members I have met.
Old 07-18-2018, 08:46 PM   #2956
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Not sure as the bracket has welded nuts on it, that would mount the bracket thru dash, these may be machine screws
[url=https://flic.kr/p/29cyP9J]20180718_204220
SAFETY FIRST
AS usual, off topic
Jim
Old 07-18-2018, 08:51 PM   #2957
richard2717
Re: PO has me PO'd
Correct two of them that go thru the dash panel should be 1/4 20 and the two that are not threaded will be what I posted above.
Let me go get a picture of the complete unit
Members I have met.
Old 07-18-2018, 08:57 PM   #2958
richard2717
Re: PO has me PO'd
here are a couple pictures
Members I have met.
Old 07-19-2018, 09:19 AM   #2959
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/29hCAZK]20180719_091541
Thanks Richard for the offer of parts over the years, you have been a great help. bolts and screws should be here, but it's been 20 years since I took it apart
Chased the threads, and 1/4-20 seems to work. Of course, the PO used the wrong screw driver and screwed up the head
Found 1 screw, may have to hit you up for 1 screw
SAFETY FIRST
AS usual, off topic
Jim
Old 07-19-2018, 12:12 PM   #2960
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
knew it had to be in one of six
[url=https://flic.kr/p/26x3PLY]20180719_112800
now for install
SAFETY FIRST
AS usual, off topic
Jim
Old 07-19-2018, 01:19 PM   #2961
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/27V3p8V]20180719_131257
SAFETY FIRST
AS usual, off topic
Jim
Old 08-06-2018, 11:58 AM   #2962
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/L7au3p]20180806_113815
[url=https://flic.kr/p/28LEqVW]20180806_113844
Started to work on the FAST harnesses again, while some of the leads need to be used, not all of the XIM, the harness leads for the XFI are used while some of the XIM are duplicated( such as the MAP), but there may be more, as I hook this up
1 of the leads that are coming out of the XFI harness is for the crank sensor, that I won't be using, was told by FAST to just ignore or cut off, since my XIM harness has the leads for crank and cam sensors from my EFI parts, I've changed the connections so I can plug in directly to the 2 sensors
Now to hole saw(1 1/4") into my firewall, going to slice grommet and super glue back together, don't feel like depinning all the connecters to get it through grommet
Connections I am working on now;
DS and PS coil driver
Cam/ hall effects
Cam and Crank sensors
ground(-)
SAFETY FIRST
AS usual, off topic
Jim
Old 09-21-2018, 08:59 PM   #2963
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
With all the time and effort you're spending on this, that harness from FAST is cheap looking. Consider replacing that convoluted tubing with some braided sleeving from Wirecare Just a thought.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 09-22-2018, 09:21 AM   #2964
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
AJ, I agree with you 100%, but this was my last attempt to resolve the issue
[url=https://flic.kr/p/FPtFum]20180131_093349
Needless to say, after two new harness's, I'm taking baby steps....
I have the wrap you are referring too
Post #2901 was a debacle
SAFETY FIRST
AS usual, off topic
Jim
Old 10-06-2018, 10:00 AM   #2965
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Milestone of sorts....Shifter cart is running, will post up pics as soon as I can get them off of my Iphone, maybe some track time before winter flys
SAFETY FIRST
AS usual, off topic
Jim
Old 10-22-2018, 11:50 AM   #2966
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2ceMUgf]20181022_104141
[url=https://flic.kr/p/2cjgM5a]20181022_101915
[url=https://flic.kr/p/2aVwsqX]20181022_101709[
SAFETY FIRST
AS usual, off topic
Jim
Old 10-22-2018, 11:55 AM   #2967
richard2717
Re: PO has me PO'd
Jim
You got way more patience than I do. Looks like you moving right along though
Richard
Members I have met.
Old 10-22-2018, 01:31 PM   #2968
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2bdwtRu]20181022_132509
This pic shows where to insert tool, locking tab is at 12 o'clock, but only have insert about 1/8" to engage lock, then rock tool up and down. then install tool at 6 o'clock to remove wire
SAFETY FIRST
AS usual, off topic
Jim
Old 10-22-2018, 01:35 PM   #2969
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by richard2717 View Post
Jim
Richard
You made me chuckle, just can't get all the connecters through the size hole that's needed for the firewall grommet, don't know why they wouldn't put the grommet on the harness before the connecters
This the beginning of my build season
Have to go back and edit the pics for slplanng
SAFETY FIRST
AS usual, off topic
Jim
Old 10-25-2018, 12:14 PM   #2970
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/29zRZJo]20181023_105308[
[url=https://flic.kr/p/2b1rGjZ]20181025_094122
The tape wants to roll, memory. Found this gold plated tool in her toolbox( she passsed several months ago). A note hand written by her said "tools go to Jim" and her retirement clock. tools were gold plated when she retired from CPPC. She was the only woman in the engineering dept.. And her job was to repair broken wires the size of your hair. Company built guidance controls for the Apollo moon shot
[url=https://flic.kr/p/2b1sL5H]20181025_095736
SAFETY FIRST
AS usual, off topic
Jim
Old 10-28-2018, 09:45 AM   #2971
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/QjdAd1]20181027_115106
[url=https://flic.kr/p/2bm2Ak1]20181027_121149
[url=https://flic.kr/p/2bm14X9]20181027_115223
SAFETY FIRST
AS usual, off topic
Jim
Old 10-29-2018, 05:22 PM   #2972
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Date coded '67
[url=https://flic.kr/p/2cv93Sx]20181029_120152
Now I have to find some red and clear lenses
SAFETY FIRST
AS usual, off topic
Jim
Old 11-01-2018, 02:17 PM   #2973
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Cam/ Hall effect
[url=https://flic.kr/p/2cv6UWh]20181101_133758
[url=https://flic.kr/p/2bbLmP8]20181101_133725
[url=https://flic.kr/p/NPizUg]20181101_132518
SAFETY FIRST
AS usual, off topic
Jim
Old 11-02-2018, 05:18 PM   #2974
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
This is where it can be confusing, as the connectors look the same, but, there is a notch on the left one at the top and will not let them connect
I use my hemastats to keep the locking tabs from reengaging as you pry off on side
[url=https://flic.kr/p/2cAMx5k]20181102_113902
[url=https://flic.kr/p/2bd3ceZ]20181102_120842
you can see better the notch I am referring to in this pic
These are the cam and crank senser connectors
Started to install some of the wire care wrap, but didn't use tape to finish yet. I guess AJ was right, doesn't look as cheap
SAFETY FIRST
AS usual, off topic
Jim
Old 11-02-2018, 07:22 PM   #2975
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
You know it!
- AJ
