07-20-2018, 03:26 PM | #1 |
Re: Post Your Wheel and Tire Combo
I guess I'll be first.
16X7 TT2's with 4" backspace, 215/60/16 tires with MII front suspension, 2" drop spindles with coil overs, disc brakes, have 4-1/2" ground clearance at front crossmember. 17X8 TT2's with 3-1/2" backspace, 235/55/17 tires with Nova rear axle on leaf springs. Here's a pic...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-20-2018, 05:21 PM | #2 |
Went with smoothies. 16x8 235/60-16 all around. Mustang II IFS and stock in the rear.
07-20-2018, 07:35 PM | #3 |
Nice classic look!
Romans 10:9 - The Truth |
07-21-2018, 02:45 PM | #4 |
07-21-2018, 09:43 PM | #5 |
I have recently changed out the wheels and tires on mine.
Fronts are 215/70-15's 4.25" backspacing Rears are 255/60/15's 4.25" backspacing all suspension is 2nd gen Camaro, 10" diff. Front suspension I put on 2" lowering spindles, rear has 4 leafs/side with 1" lowering blocks. Also running a Gen VI big block for power. A Big block vs a small block will affect your stance.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 Last edited by my56chevytruck; 07-24-2018 at 10:15 PM. |
12-13-2019, 05:48 PM | #6 |
07-20-2018, 05:22 PM | #7 | |
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
07-20-2018, 11:19 PM | #8 |
Brian, thanks for the compliment. My rear springs are the stock rear springs from my 1994 S-10 blazer. I put 3" lower springs on my blazer and used the old springs on my truck. Since these are wider that the stock truck springs, I had to change the front and rear hangers. Truck rides nice. I know there are several vendor that sell complete kit to change to the wider springs, which require you to cut the old rivets from hanges and bolt in the new hangers. Oh, and I'm running a 2" lowering block...Jim
07-21-2018, 12:10 PM | #9 | |
Brian
